orlyandico
Reged: 08/10/09
Loc: Singapore
608 bearings for CGEM worm new
      #5421067 - 09/14/12 02:41 PM
So I snagged an Aeroquest worm off the other site for a low price, I thought, what the heck.
Major problem, my periodic error (which was bad enough at +/- 25") has gotten worse! at +/- 34"
Maybe I shouldn't have put those allegedly "ABEC-5" skate bearings in there... (that I removed from a pair of skates)
Anyway I don't feel like putting back the stock CGEM bearings - which are lousy anyway.
My question is, what bearings do I use to replace them? I see the SKF part number 608-2RSH. But how different is this from say a 608-2ZJEM? do I need those exact bearings?
Also there are these pricey "full ceramic" bearings - will these do me any good?
brokenwave
Reged: 05/10/11
Loc: Scottsdale, AZ
Re: 608 bearings for CGEM worm new [Re: orlyandico]
      #5421233 - 09/14/12 04:27 PM
Ed Thomas at Deep Space Products could help you out,
He has a DYI Hyper Tune kit available, if that is something you were interested in.
DaveJ
Reged: 01/07/05
Loc: NE Ohio
Re: 608 bearings for CGEM worm new [Re: brokenwave]
      #5422016 - 09/15/12 08:54 AM
"DYI" = "Do Yourself In"
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: 608 bearings for CGEM worm new [Re: DaveJ]
      #5422226 - 09/15/12 11:40 AM
Yeah looks like I've done that.
Found some NKF "Japan" bearings and put them in. The periodic error is just as bad, maybe even a bit worse (probably within uncertainty limit).
Looks like it's lapping time. Toothpaste will probably do...
Mert
Reged: 08/31/05
Loc: Spain, Pamplona
      #5422243 - 09/15/12 11:58 AM
Do you have some sort of log-file to analyze the
mount's basic periods??
Typically the bearings influence but not in the amount
you have written!
Maybe you have put too much pre-load on the bearings??
I don't know the CGEM but likely mecanically it is not
too different from an EQ6.
Just my 2 worth
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: 608 bearings for CGEM worm new [Re: Mert]
      #5422270 - 09/15/12 12:17 PM
I have a bunch of logfiles.
Looks like it's not the bearings and it's not the Aeroquest worm.
It's the wretched 8/3!!!
On my original worm, the fundamental was 29" according to PECPrep (agrees with my old PEMPro run) and the 8/3 was 19" for a total PE of 42"
With the Aeroquest worm, the fundamental is 16" (much better!) but for some reason the 8/3 has ballooned to 24" (now making it larger than the fundamental) for a total PE of.... 40"
So much for that.
The Aeroquest worm does have a quantifiable improvement, but the 8/3 can't be helped. I don't even know if lapping the worm would do any good...
Mert
Reged: 08/31/05
      #5422416 - 09/15/12 02:07 PM
Do you have the layout of the CGEM gearing?
That is from the stepper-gear - X - X - Worm - Wormwheel.
How many teeth on the wormwheel? ( 180 ?? )
When you state 8/3 what do you mean?
This could be helpful analyzing with PECPrep.
Also some logfile of 5 cycles would help!
Right now I'm off to do some imaging tonight ( I hope )
orlyandico
Reged: 08/10/09
Loc: Singapore
      #5422420 - 09/15/12 02:12 PM
Mert, the CGEM has a very well known 8/3 harmonic (2.667X or a period of roughly 179 seconds = 479 / 2.667) due to the layout of the gears in the servo -
http://tech.dir.groups.yahoo.com/group/CelestronCGEM/message/7441
Some CGEM's have a small 8/3 term (8") and some have a large term like mine. This cannot be corrected by PEC because it's out-of-phase with the fundamental (and the CGEM only has 88 PEC cells).
Alph
Reged: 11/23/06
Loc: Melmac
      #5422469 - 09/15/12 02:54 PM
Where can we find them?
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: 608 bearings for CGEM worm [Re: Alph]
      #5423219 - 09/16/12 02:17 AM
here ya go Alph...
stock gear, Meade DSI (9.6x7.5 um pixels), Vega, 432mm FL
https://dl.dropbox.com/u/63497702/PE/PHD_log_26Aug12_Vega_DSI_Z70.txt
Last night, also Vega, also 432mm FL, with the Aeroquest worm
https://dl.dropbox.com/u/63497702/PE/PHD_log_15Sep12_Vega_DSI_Z70_Aeroquest.txt
Last night, Altair, with the Aeroquest worm
https://dl.dropbox.com/u/63497702/PE/PHD_log_16Sep12_Altair_DSI_Z70_Aeroquest.txt
14 registered and 23 anonymous users are browsing this forum.
