SL63 AMG
Reged: 12/21/09
Loc: Williamson, Arizona
ASA DDM85X-SL - Keeps getting better
#5427735 - 09/18/12 04:18 PM
A year and a half ago I purchased an ASA DDM85XL-S.
It was a big leap for me, not so much due to the cost, but mostly due to the learning curve. Not only was there a huge learning curve for the mount, but I started from scratch knowing little to nothing about astronomy, astrophotography, mounts, collimation, cameras, filter wheels and most of all, image processing.
I kid you not; there were no gradients in my knowledge, just pure green (me)!
Enough of that, let's talk about the mount.
First, I encourage you to read my review of the ASA DDM85XL-S Direct Drive GEM
It's not the best writing in the world, but I think it gets the point across...this is an excellent mount for astrophotography!
So I find myself, a year and a half later, becoming quite knowledgeable on this mount...and it keeps getting better.
I recently upgraded my Autoslew software that controls the mount with version 5.1.0.0 and the plate solving software to Sequence version 9 by Dipl. Phys. Dr. Philipp Keller.
Dr. Keller has made major improvements to the software, specifically in the Advanced Pointing model of Autoslew and the Multipoint Local Precision Tracking portion of Sequence.
What seemed like required an advanced degree in astrophysics to operate and understand can now be down quite easily by a greenhorn like me. All of the advanced pointing and modeling functions are now completely automated.
I am now consistently able to achieve polar alignments equal to or less than 6 arcseconds in both axis in about a half hour after setting up the mount and then create a substantial pointing model within another 30-45 minutes. Once completed, I can select an object, create a MLPT model in 2-12 minutes depending upon the length of my exposures and the number of iterations I select and then I can achieve 20-30 minute subs with no periodic error, no backlash and most importantly, no guiding.
The pointing accuracy is very good but it is the tracking capabilities that are absolutely amazing.
When I am done imaging for the night, I simply park the scope, cover it and it's ready for the next evening of imaging.
If I need to shut off the power or remove the laptop for any reason, that's cool too. I make sure I point the scope at a star in the eastern horizon, synch to that star and then Autoslew calculates the angular offset between the synched star and the encoders home position. It then uses your coordinates, date and time and that angular offset to determine exactly where to point after you power up and perform a HomeFind. In other words, it never forgets where it is positioned once a 30 second home find is performed on power up.
Here are some images of the mount and some taken using the mount. They are a combination of 10 and 20 minutes subs with no periodic error, no backlash and most importantly, no guiding.
Alph
Reged: 11/23/06
Loc: Melmac
Re: ASA DDM85XL-S - Keeps getting better
[Re: SL63 AMG]
#5427851 - 09/18/12 05:12 PM
I have written off the ASA DDM mounts for a couple of reasons: - Payload capacity, DDM60 too little, DDM85 too heavy - Subpaar machining. Those mounts don’t look they are worth the money. - Difficult to operate mechanically. The azimuth adjustment range is too small. The lack of easy axes locking mechanism makes OTA mounting a royal pain in the … - Frequent problems with PID parameters. Many users reported tracking errors after 10 minutes or so of continues tracking (no manual axis movement). ASA has no fix yet. - Price is way too high - Poor customer support. - Shipping the DDM85 to ASA for repairs is very expensive.
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
[Re: SL63 AMG]
#5427898 - 09/18/12 05:34 PM
Thanks for the well written report. It looks like you got a great mount.
Peter
SL63 AMG
Reged: 12/21/09
[Re: Alph]
#5427914 - 09/18/12 05:45 PM
I think you need to do your homework, or at least keep up with the progress of ASA.
ASA DDM60 - 55lbs
ASA DDM85 Basic - 100lbs
ASA DDM85 Standard - 143lbs
ASA DDM85 Premium - 220lbs
Subpar? Based upon looks? These mounts are CNC machined and high quality.
Not sure how much you think you need, but after pointing the mount near polaris, lighting polaris up with the laser, there really isn't much adjustment needed. I think what they offer is overkill. I simply hold up my pinky finger at arms length against polaris on the Kochab side and spot the laser to the other side of my pinky. I find myself polar aligned within 5 to 8 arc minutes every time, then run a sequence plate solving 10-15 stars and my polar alignment is typically less than an arc minute and often within 6 arc seconds if I am really maticulous about centering stars in the crosshairs of the CCD image.
Using a metric #8 hex tool to tighten a locking bolt is a pain? Seriously? I have no trouble mounting my Astrotech 12" RC all by myself. I find it much easier then setting up a Celestron CPC1100 for mount, especially on a wedge!
This issue is fixed in Autoslew 5.1.0.0. There are now presets depending on the size and weight of your system. Only minor adjustments are needed from the preset. Once you set the values and balance the scope using the wicked cool software balancing system, you save your scope to a profile and forget it. I change scopes and with a click all my settings are spot on.
I am not sure what you mean by "no manual axis movement" but if people are having tracking issues after 10 minutes, then they aren't setting up properly. If you do a good polar alignment (30 minutes) and make a good pointing model (30-45 minutes) then use MLPT for tracking, you can't miss. 20 minute unguided subs are easily attainable even for a beginner like me. The images in my post speak for themselves. For those that need to autoguide, you can do that too, but really, it is unecessary unless you want subs greater than 40 minutes.
Too high is relative. By the time you buy any other mount, add all your guiding accessories, you'll spend as much as a DDM60. My images speak for themselves. It's worth every penny!
My experience is different. There is a time zone difference and a language barrier, but when I had an issue with an early model DDM60, I traded up and ASA brought my DDM85 NEAF, used it as a demo and gave me a great discount!
You got me here!
If you have never owned one, how can you comment on service and support, machining, etc, etc?
herrointment
Reged: 03/12/11
Loc: North of Hwy. 64
[Re: SL63 AMG]
#5428048 - 09/18/12 06:46 PM
We all have opinions....
SL63 AMG
Reged: 12/21/09
[Re: herrointment]
#5428065 - 09/18/12 07:01 PM
True, but which opinions have value? Opinions based on actual use and fact or opinions based on heresay and conjecture?
I don't mind anyone giving an opinion even if it is negative, but when that opinion is given as a deliberate attempt to completely discredit a product when it is obvious the person giving the opinion has no direct experience with that product, that opinion has little value.
I wanted to be sure to make that clear my rebuttle above.
If you look at the images it's quite obvious the product does exactly what it is designed to do and does so even while in the hands of an inexperienced operator...like me.
psandelle
Reged: 06/18/08
Loc: Los Angeles
[Re: herrointment]
#5428094 - 09/18/12 07:24 PM
Hats off to you for having a great mount. I've been keeping my eye on the ASA mounts (and their scopes) for a while, but always thought that using them mobile might be a bit much. You've shown it not only can be done, but that it's working very well.
Cool and congrats!
Paul
Psyire
Reged: 06/24/07
Loc: 55* North
[Re: psandelle]
#5429200 - 09/19/12 01:06 PM
Dave, Thanks for the update/review! I've been watching these mounts for quite awhile as I'm seriously thinking about a 'big' upgrade in the near future. ASA is definately on my list..
orion69
Reged: 05/09/10
Loc: Croatia
[Re: Psyire]
#5429351 - 09/19/12 02:34 PM
Dave, I'm very interested in ASA DDM60 mount, price is NOT that high for mount of that quality, payload capacity is enough for me (max 6" refractor) and Austria is not very far. So probably my next mount, thanks for review!
Knez
petely
journeyman
Reged: 01/06/11
Loc: England
[Re: Alph]
#5429554 - 09/19/12 04:53 PM
I suppose all things are relative. Where I am the DDM85 compares favourably with the paramount ME in terms of payload and price.
Nezar H
Reged: 08/11/11
Re: ASA DDM85X-SL - Keeps getting better
[Re: SL63 AMG]
#5460808 - 10/08/12 03:11 PM
I expect that your IQ is very high .. I'm very pleased with your participation and your comments! and really motivated me to rather more effort to get to a better level than I am now.
GoodLuck and I wish for you all the Best.
Nezar.
Mkofski
Reged: 07/19/11
Loc: Greenfield, Indiana, USA
[Re: SL63 AMG]
#5460840 - 10/08/12 03:30 PM
No way to argue with the results! Your pictures are stunning! If I am ever in the position to spend $20K on a mount, I'd certainly consider one of the ASA offerings. That reminds me I need to start buying lottery tickets.
korborh
Reged: 01/29/11
[Re: SL63 AMG]
#5461545 - 10/09/12 02:10 AM
SL63, congrats on the mount and those great images!
How long have you been able to image unguided and how well is flexure modeled ? Do you find it worth the time and effort of modeling rather than autoguiding? Do you see any flexure in 30min images?
SL63 AMG
Reged: 12/21/09
[Re: korborh]
#5462066 - 10/09/12 12:52 PM
At this time, the longest unguided subs I have taken with the mount are 1200s (20m) using the MLPT tracking with Sequence 9.
I am confident I can do 30 minute unguided subs and I may very well try it next week during the new moon cycle. I just need to find an object like my LBN438 image where I need deep exposures.
I am using a complete ASA system and I don't have much flexure. All of the components are either screwed together or attached using 6 screws. Everything is very well machined and fits tightly.
Sequence 9 and Autoslew will measure the flexure and collimation error of the system. I have never seen these numbers very high. The neat part is unlike hysteresis; flexure and collimation error can both be measured and thus corrected by software. That's exactly what the ASA software does!
With regards to the time spent modeling the system versus guiding, I definitely find it worth the time. In fact, this wouldn't even be a question if I were in a permanent observatory because I would do it once and forget it. Unfortunately, I have to setup every new moon cycle but I leave the system setup for up to 10 days at a time.
It takes me just a few hours the first night to setup, dial in my polar alignment, model the system with a large pointing file and then I only have to run an MLPT model for each object I image. The MLPT model takes less than 15 minutes for about 30-40 images.
So the answer to your question is, yes I think it is worth the time. I never have to worry about finding a guide star, thin clouds blocking my guide star of any of the guiding issues. They simply do not exist for me. There is, however, a bit of a steep learning curve to figure all this stuff out, but with more people using the ASA mounts, there are a lot more helpers out there to get the next guy started.
Personally, I think someone spending two nights with me could learn this system quite well. There are a lot of steps each with many details that must be remembered, but none of it is so complicated that the average guy cannot understand it, figure it out and repeat it.
Here is an image of LBN438 that was made with 20 minute unguided LRGB subs binned 1x1
LBN438 High Resolution
johne
Reged: 11/10/06
Loc: Prescott, AZ.
[Re: SL63 AMG]
#5463525 - 10/10/12 10:14 AM
Just sticking my nose in here for a second...
I happened to have the pleasure of spending some time with Dave and his ASA system last night. I have a Paramount ME (which I am very satisfied with), but Dave's ASA is simply amazing and accurate. The mount is incredibly fast and whisper quiet when performing slews, expecially when compared to the ME. LOL, the focuser was louder than the mount. I'd say you need to be alert and keep your wits about you when slewing, lest you get "whacked in the head", if you're not paying attention.
jmiele
Patron Saint?
Reged: 12/04/10
[Re: johne]
#5463548 - 10/10/12 10:25 AM
This is great to hear. These mounts have shown great potential in the hardware for some time. Now that the software is sorted, it seems they are performing wonderfully. Dave's results are stunning. BTW Dave, the processing is also super! Getting solid data is just the first part. His images are great.
Best, Joe
morten
Reged: 07/22/08
Loc: Denmark
[Re: jmiele]
#5475593 - 10/17/12 06:01 PM
Kudos Dave. What excellent photos. I considered the ddm60 in 2010, but felt that it was immature and went conservative with a ap900. Your description of your journey is a fantastic read. It seems that you set up on a tripod on each session. How long does it take you to get the mount aligned and running?
BPO
Reged: 02/23/10
Loc: South Island, NZ
[Re: morten]
#5478226 - 10/19/12 04:08 AM
Nice write up and images.
jjongmans
Reged: 02/11/12
Loc: The Netherlands
[Re: BPO]
#5484767 - 10/23/12 04:13 AM
I ordered an ASA DDM60 PRO 7 weeks ago to update my EQ6. I did a lot of research and also looked at other mounts like 10Micron, Mesu, Paramount and Astro-Physics. The improving results of the ASA pioneers (like SL63 AMG) helped me decide to choose the ASA. I'll receive it in the next 2 weeks, when the custom pier is ready. I'm going to use it with an GSO 10" RC, with a FL of 2000mm@f/8. I hope to get 30 min. unguided subs with this setup.
morten
Reged: 07/22/08
Loc: Denmark
[Re: jjongmans]
#5485363 - 10/23/12 02:03 PM
congratulations!! I can't wait to hear about your experiences.
