Privacy Policy |
Please read our Terms
of Service | Signup and
Jason1970
Reged: 05/25/09
Which Ascom driver for HEQ6PRO
#5425927 - 09/17/12 05:48 PM
Hello
I'm trying to connect my SynScan to my laptop. I do have the RJ11 cable.
I am trying to find out which ascom driver I should use.
I have checked Ascom website but non seem obviours to me.
Can someone help me locate these?
Thank you
Jason p.s Im assuming I require an Ascom driver for this....
scirocco1
Reged: 05/05/09
Loc: Cluj,Romania
Re: Which Ascom driver for HEQ6PRO
[Re: Jason1970]
#5426753 - 09/18/12 06:15 AM
Hello, You need a Serial->USB converter, plug it into the synscan's rj11 port (you have the connecting schema in your manual). Afterwards you must put your synscan in pc-direct mode. Install ASCOM 6.1 (http://download.ascom-standards.org/ASCOMPlatform6SP1.exe) and EQMOD and you will be (hopefully) able to connect to your mount. Or instead the Synscan + USB/serial adapter, you can buy an eqdir adapter.
Reged: 07/06/07
[Re: scirocco1]
#5426840 - 09/18/12 07:43 AM
Uh...not really. To just control the mount through the HC with a computer you do NOT have to put it in PC Direct. That is ONLY for EQMOD.
OP: You want the Celestron driver. Install it and you will find one of the mount choices given in the chooser will be Synta (right at the end).
scirocco1
Reged: 05/05/09
Loc: Cluj,Romania
[Re: rmollise]
#5428730 - 09/19/12 05:28 AM
yes, sorry, my bad (i always work with eqmod).
24 registered and 24 anonymous users are browsing this forum.
