rick-SeMI
Reged: 01/08/11
Loc: Michigan - USA
OIII Filter Choice
      #5432485 - 09/21/12 11:00 AM
Does anyone know of a site that shows the spectrum (wavelength) in nm that is allowed for the different OIII filters ?
Right now my choice for OIII is either the Baader, Lumicon or Orion 1.25 inch filters.
M97 the Owl Nebula is the target with an Orion XT10i.
Which OIII filter would be best suited for this one?
I figure if it is good for M97, it should be pretty good for the other nebula's ?
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
Re: OIII Filter Choice new [Re: rick-SeMI]
      #5432514 - 09/21/12 11:19 AM
There are many websites that show test results for particular filters, but in the case of your 3 choices, from wide at the top of the list to narrow at the bottom, they are:
Orion (about 15nm, IIRC)
Lumicon (about 12nm)
Baader (about 8.5nm)
The Baader "clips" the 496nm O-III line at about 50% transmission, but since the primary emission in the O-III lines is at 501nm, that doesn't seem to hurt that much.
Frankly, all 3 filters are good, so you won't lose with any of them.
But the Baader will likely give the maximum contrast.
In a small scope, the extremely narrow bandwidth will darken the sky and stars and make the field perhaps unaesthetically dark.
Sometimes there is a reason for a slightly wider bandwidth.
Not only do we want an enhanced nebula image--sometimes the "context" is important, too.
Ernest_SPB
Reged: 11/13/10
Loc: St.-Petersburg, Russia
Re: OIII Filter Choice new [Re: Starman1]
      #5432545 - 09/21/12 11:40 AM
I find Baader OIII too much dark for visual application.
It looks cutting some quote of useful light from OIII objects. I had possibility to compare it with Lumicon and saw that the last produced brighter and more contrast image over the most OIII nebulae.
OIII from Baader is preferred by my collegue who deal with astronomical photography.
Scanning4Comets
Markus
Reged: 12/26/04
Re: OIII Filter Choice new [Re: Ernest_SPB]
      #5432647 - 09/21/12 12:43 PM Attachment (24 downloads)
The Baader O-III works extremely good on the Veil and other targets. I own the Celestron which is the Baader re-branded. The Lumicon indeed has a wider bandpass as I did a test with a friend in a dark sky situation, and I found the Lumicon slightly better on M-17 and a few other targets. However, I see no point in selling off my Celestron / Baader O-III for a touch wider bandpass.
The Baader O-III would be a good choice if you're on a budget, The Orion the same and the Lumicon is the filter of choice over ALL others IMHO if you don't mind spending top dollar for all of your gear....and we all know it can get rather costly.
One more thing to take into consideration is the 2" filter threads. Some of them are funky and screwing them onto eyepieces in the dark can be a battle in frustration. For now I am putting my Celestron O-III and Orion Ultrablock on extension tubes so I don't have to screw them onto eyepieces.
Dyslexic Nam, (Shaun), has his filters on a 2" Orion Filter Wheel, which I may end up going with.
SEE HERE
You can also get an Astrocrumb Filter Slide which is also a great way to change filters.
SEE HERE ALSO
Don Pensack is absolutely right.
Traveler
Reged: 08/19/07
Loc: The Netherlands
      #5432682 - 09/21/12 01:06 PM
Don't forget to look for an Astronomik OIII filter as well.
rick-SeMI
Reged: 01/08/11
Loc: Michigan - USA
      #5432706 - 09/21/12 01:24 PM
Don,
Found a few spectrum diagrams.
OIII Group A, B and Narrow Band
http://www.karmalimbo.com/aro/pics/filters/o3a.jpg
http://www.karmalimbo.com/aro/pics/filters/o3b.jpg
http://www.karmalimbo.com/aro/pics/filters/narrow.jpg
rick-SeMI
Reged: 01/08/11
Loc: Michigan - USA
Re: OIII Filter Choice new [Re: Scanning4Comets]
      #5432710 - 09/21/12 01:27 PM
Markus,
The Lumicon OIII which normally sells for $140 is on sale for $99.95
David Knisely
Reged: 04/19/04
Loc: southeastern Nebraska
      #5432772 - 09/21/12 01:58 PM
Here is a site that has some of the current OIII filters transmission curves:
http://www.astroamateur.de/filter/oiii.html
I still like the Lumicon OIII (if you can get one), but the DGM Optics OIII or Thousand Oaks OIII are pretty good as well. Clear skies to you.
Scanning4Comets
Markus
Reged: 12/26/04
      #5432775 - 09/21/12 01:59 PM
Markus,
All of my filters are 2" size, as you can see in my sig. Was that sale for a 2" Lumicon O-III? I doubt it, plus I am ok with what I have right now. I just looked here in Canada and the 2" Lumicon O-III sells for $240.00 + tax + shipping, LOL. This is exactly WHY I am keeping what I have right now.
David Knisely
Reged: 04/19/04
Re: OIII Filter Choice new [Re: Traveler]
      #5432786 - 09/21/12 02:01 PM
The Astronomik filter is a little on the broad side in terms of bandwidth, so I would probably pass on it. If you want the contrast, you have to have a filter that just lets through the two OIII lines and almost nothing else. Lumicon's OIII would be my first choice with the Thousand Oaks OIII a close 2nd. Clear skies to you.
Starman1
Reged: 06/24/03
Loc: Los Angeles
      #5432824 - 09/21/12 02:12 PM
Don,
It should be noted that these are not test reports, merely the superimposition of many manufacturers' bandwidth diagrams.
Great illustrations, though.
mitaccio
Reged: 03/17/09
Loc: Oahu, Hawaii
      #5432889 - 09/21/12 02:57 PM
I bought my OPT OIII 1.25" a year ago for about $40, best investment I have made.
Cabrillas
Reged: 07/19/09
Loc: Madrid. Spain.
Re: OIII Filter Choice new [Re: mitaccio]
      #5433188 - 09/21/12 05:45 PM
Another vote for the Astronomik. I've compared it against others, and it is the best in my refractor. A friend has a C9.5. We checked the Astronomik against the Baader in both scopes. We agreed the astronomik was the clear winner.
But of course beware that the performance of such restrictive filters are very affected by aperture and quality of the sky. Regards.
turtle86
Pooh-Bah Everywhere Else
Reged: 10/09/06
Re: OIII Filter Choice new [Re: Cabrillas]
      #5433268 - 09/21/12 06:57 PM
Yet another vote for the Astronomick. I have the narrow band, OIII and H-beta filters all on a filter slide. All work great for me. The OIII might be a little broader than the Lumicon, etc., but the Veil really pops out when I use it in my scope, showing exquisite filamentary detail. Another standout is Thor's Helmet. Just a great filter for planetary nebulae (and the Veil).
Two things I really like about the Astronomick. One, they have very durable coatings, which are essentially scratch-proof and impervious to dew. Two, the view is very aesthetically pleasing, with nice pinpoint stars. In contrast, a couple of the other OIII filters I've seen (the older version of the Lumicon specifically comes to mind) yielded rather funky-looking bloated stars...
John Huntley
Reged: 07/16/06
Loc: South West England
Re: OIII Filter Choice new [Re: turtle86]
      #5433341 - 09/21/12 07:42 PM
And yet another Astronomik O-III advocate here. I like it for the same reasons that Rob describes well above.
Prior to the Astronomik I'd tried the Telescope Services 0-III (which is the same as the Skywatcher one) and the Baader and Celestron O-III's which are, again, the same as each other.
I find the Astronomik O-III works very effectively in all my scopes from 4 to 10 inches in aperture.
Edited by John Huntley (09/21/12 07:43 PM)
rocketsteve
Reged: 04/17/11
Loc: Southeast Louisiana
      #5433360 - 09/21/12 07:52 PM
And I'd like to register another vote for the Astronomik O-III filter. Rob's experiences are very similar to my own. His experiences with the Veil and Thor's Helmet are right on the money. Overall, I'm completely satisfied with my filter purchase.
      #5433568 - 09/21/12 10:36 PM
The Celestron and Baader versions are identical - except in price. Celestron-branded O-IIIs run about 30% less than the Baader versions of the same filters.
I use it successfully in scopes from 2.7" to 16". It works just fine. I also have an Orion-branded O-III. Despite "on paper" differences, at the eyepiece there's not much difference between it and the Celestron.
drollere
Reged: 02/02/10
Loc: sebastopol, california
Re: OIII Filter Choice new [Re: jrbarnett]
      #5433602 - 09/21/12 10:57 PM
i agree with david, the thousand oaks is a very good OIII filter, but note i use it for visual only.
Starman1
Reged: 06/24/03
Loc: Los Angeles
      #5433727 - 09/22/12 12:37 AM
The point to be made here is that a slightly narrower bandwidth would enhance the contrast more, but at the expense of the stars. So which do you use the nebula filter for--nebulae, or views of stars? I'm not being sarcastic because there really is a difference in preference involved.
The TeleVue O-III is a broader one and also of superlative quality. It really does depend on preference.
David Knisely
Reged: 04/19/04
Re: OIII Filter Choice [Re: Cabrillas]
      #5433758 - 09/22/12 01:24 AM
The problem with the Astronomik OIII isn't that it doesn't work (it works fairly well). It is just that its bandwidth is nearly as broad as some of the narrow-band filters that let in both the OIII emission lines as well as the H-Beta line. The Astronomik has a full width at Half Maximum (FWHM) of a whopping 204 angstroms (the Lumicon OIII is around 115 angstroms for example). The DGM Optics NPB filter has a FWHM figure of nearly 230 angstroms and I suspect that the views with it would equal that of the Astronomik OIII, not to mention that the DGM NPB would be useful on more nebular objects than a standard OIII might be useful on. If you want a halfway decent "true" OIII filter, I might suggest the DGM Optics OIII filter, as it is close to the bandwidth of the Lumicon OIII. Clear skies to you.
23 registered and 30 anonymous users are browsing this forum.
