Paul G. Abel
Reged: 01/28/10
Loc: UK
Uranus 20" DK.
      #5451738 - 10/02/12 11:29 AM
Greetings all,
Attached is an observation made of Uranus made with Dr. Hugh Sasse using the University of Leicester's 20" DK planewave telescope, last night. Conditions were only average at best with seeing around AIII-IV and some drifting cloud. A bright waning Moon also hampered observations a little. The planet was examined both in IL and with a red W#25A filter, the results were as follows:
(i) Drawing 1 (IL) [2214UT- 2226UT]
The planet was examined at x356 and x540 and there appeared to be a brighter EZ. Just 'below' this was what appeared to be a darker greyish band. A brighter spot was suspected on the limb (indicated). Interestingly there appeared to be a slight change in colour compared to when we last observed the planet with a stronger cyan component being present.
(ii) Drawing 2 (W#25A)
Examined the planet in a deep red W#25A filter. Due to the presence of high cloud we had to reduce power to x288, but the disk size was just large enough to be able to make some observations. In particular, the brighter EZ seemed to still be present, along with the darker band which MAY have been easier to see in this filter (impossible to be certain). The brighter spot also seemed to be present. We made plans to observe the planet with a blue W#80A filter but alas clouds came up and we were forced to stop observations on this rather inconclusive note.
Best wishes,
-Paul.
Reged: 10/05/09
Re: Uranus 20" DK. new [Re: Paul G. Abel]
      #5452162 - 10/02/12 03:36 PM
Paul,
Nice drawings of Unanus .
Reged: 02/08/11
Loc: Montreal, Quebec, Canada
Re: Uranus 20" DK. new [Re: niteskystargazer]
      #5452541 - 10/02/12 07:43 PM
Paul
Beautiful. Are you serious, you can see such clouds on Uranus ?
azure1961p
Reged: 01/17/09
Loc: USA
Re: Uranus 20" DK. new [Re: Andrev]
      #5452766 - 10/02/12 10:18 PM
Nice work Paul, as always one of my favorite observer/artists.
Pete
Edited by azure1961p (10/02/12 10:18 PM)
Reged: 06/13/06
Loc: Illinois
Re: Uranus 20" DK. new [Re: azure1961p]
      #5452881 - 10/02/12 11:30 PM
Paul, Very fine filtered sketches of the planet Uranus.
Frank
Jef De Wit
Reged: 03/06/09
Loc: Hove, Belgium
Re: Uranus 20" DK. new [Re: frank5817]
      #5453050 - 10/03/12 04:03 AM
Paul G. Abel
Reged: 01/28/10
Loc: UK
Re: Uranus 20" DK. new [Re: Jef De Wit]
      #5453112 - 10/03/12 06:41 AM
Thanks :-D @Andrev, indeed yes! I have been able to make out the brighter EZ with my 8" reflector on a good night when I can use a power of x400 or so (there are records of people seeing this with a 6"). The University of Leicester's 20" 'scope used here brought out the cloud band rather well. It appeared in three different eyepieces and a W#25A filter which suggests to me it is a real thing. More people should be looking at this world!
Reged: 02/08/11
      #5454034 - 10/03/12 07:24 PM
Paul.
So let me tell you, you are lucky. I never seen any band on Uranus with my C14 because the few times I observed it, I never got a decent seeing for this planet to increase to a such power.
Last night I observed Jupiter easily at 434X for a real clear view and the moon at 782X !!! I should have had a look at Uranus but I don't.
whirlpoolm51
Reged: 01/05/12
Loc: pittsburgh,pa
      #5454407 - 10/04/12 12:14 AM
how can you see cloud bands on uranus and hubble cant!!!!! hahaha i thought uranus and neptune were featureless balls off gas and ice except for the occasional aurua
Paul G. Abel
Reged: 01/28/10
Loc: UK
Re: Uranus 20" DK. new [Re: whirlpoolm51]
      #5454587 - 10/04/12 05:26 AM
If you care to examine the ALPO website http://alpo-j.asahikawa-med.ac.jp/Latest/Uranus.htm you will see others have seen similar things. Similarly, if you care to read A. F. O'D Alexander's book The planet Uranus:
a history of observation, theory, and discovery, you will find similar observations in the historical records.
stanislas-jean
Reged: 10/22/08
      #5456017 - 10/05/12 01:35 AM
Good job Paul with the scope in use and assessed also with Mr Hugh.
About the the brightening you noted both in AL and red color I will try to check this at the same longitude you reported. If this is a bright spot it will have a certain duration and not drifting a lot.
Hope the weather will be with us, rainy now since a week and next week forecasted.
Good hope.
Stanislas-Jean
rolandlinda3
Reged: 01/24/06
Loc: Crozet VA 22932
Re: Uranus 20" DK. new [Re: stanislas-jean]
      #5457156 - 10/05/12 10:02 PM
I am sure impressed.
stanislas-jean
Reged: 10/22/08
      #5468268 - 10/13/12 12:41 PM Attachment (39 downloads)
At last a hole into the clouds for making this report about Uranus.
I engaged a new 250mm scope for getting a compromise with the seeing and the resolution ability.
It has a proven strehl ratio of 0.966 global on the tube, the central obstruction needs to be deducted for getting a true equivalent perfect diameter of 168-170mm approaching the cassegrain 305mm performance. Therefore the contrast levels are almost similar.
Last evening was average and in spite of this, during calm times (7/10 images) I could drawn the attached report for your perusal. It should interresting to compare with some other documents issued on the site (the oval brigthening near the limb in the south temperate belt).
The weather being stormy here it is difficults to perform better.
Good hope
Stanislas-Jean
mikesemmler
Reged: 06/01/09
      #5468394 - 10/13/12 02:14 PM
Paul - great scetch, congratulations for your fine observation
Michael
azure1961p
Reged: 01/17/09
Loc: USA
Re: Uranus 20" DK. new [Re: mikesemmler]
      #5469126 - 10/13/12 11:53 PM
Im having a bit of a time comparing Pauls work to Stans as Im not clear on what end is north or south in Pauls. The renderings seem reversed with the arc of the EZ curving one way in Pauls work and the opposite in Stans. Moreover the image Stan refers to [in a different post ] of Uranus iaged with a 16" sct shows a winjupos image with South being at the edge of the equatorial zone with no correlate to a pole at all. The ambiguety here muddles the waters a bit.
Pete
chrisrnuttall
Professor Emeritus
Reged: 12/29/10
Loc: York, England
      #5469300 - 10/14/12 04:36 AM
Paul used a Dall Kirkham, and Stanislas used a Maksutov Cassegrain, and both sketches were made at a similar local time (albeit on different days)so the image orientation should really be the same, perhaps one of them has a diagonal mirror and one does not?
Also the Central meridians are 100 degrees apart between the two sketches, so actually the bright spot is on one limb in Paul's and the opposite limb in Stanislas' (just to confuse you more Pete!).
It's quite interesting that (if the mirror inversion between the two drawings is indeed due to telescope design or something like that) the two sketches agree very well indeed.
Edited by chrisrnuttall (10/14/12 04:38 AM)
stanislas-jean
Reged: 10/22/08
      #5469362 - 10/14/12 07:14 AM
You see Pete, any view performed even by well known imager is controversial.
Pole or not is a result of a method and local conditions. This overall aspect is never until now duly assessed except by experience, of what.
This is not an argument.
The presentation of the sketch are clear if you follow, not on CN but on the japanese alpo the results given.
Uranus south given and rotation. Here the morning limb.
The brightening is not named as a spot but a brigthening.
Have you saw the limb darkening, because this may interfere with the brightening for getting a spot looking appearance.
You see, visual observers are prudent, imagers hardly thinking, and without assessments, also comparative assessments.
Now the brigthening is interresting to note and needs more data for a firm evaluation for saying this is the same.
In first, assessment with time to see if this is rotating with the planet, i got no enough time for.
In second, assessment day to day for collecting the same features.
In third, to assess what was changed around, the dark collar bordering the pole has gone.
etc...
When you see an imager getting a similar approach, ring me.
For the moment they stay on banding structure collected on a favorable period, because constrast had raised. And the banding idea stays on pure circles shape, nothing else can exist, and they don't know exactly behind desks.
Stanislas-Jean
azure1961p
Reged: 01/17/09
Loc: USA
      #5469572 - 10/14/12 10:55 AM
Stan,
Thats not fair to imagers or the technology behind the cams and processing software used these days. This isnt the days of tri-x or ektachrome anymore and the CCD is in another realm. I dont think your assesments of visual versus ccd is accurate.
pete
stanislas-jean
Reged: 10/22/08
      #5469758 - 10/14/12 12:56 PM
For the moment technology is not involved but just the method in use or the approach against problems that is un-acurate.
Stanislas-Jean
Achernar
Reged: 02/25/06
Loc: Mobile, Alabama, USA
      #5472337 - 10/15/12 09:42 PM
You had very good seeing to be able to see what you saw on Uranus, which always appears to me at a pale turquouise dot even through my 15-inch Dob. I can go well above 500X, but the blasted seeing here never quite lets me get a sharp view on all but very few nights. Impressive work, a testament to the quality of the telescope and the dillegence of your observations and sketching.
Taras
stanislas-jean
Reged: 10/22/08
Re: Uranus 20" DK. new [Re: Achernar]
      #5472676 - 10/16/12 02:09 AM
Thanks Taras.
Unfortunately this is not a matter of aperture mainly.
The question of scope is mainly lead by the D-d factor combined by the PTV level (or RMS for others). This implies an equivalent perfect diameter that own more or less the properties of this perfect diameter in terms of FTM curve.
For the featuring size on this planet this enough representative.
This way is interresting for comparison between diameters or scope in use. Otherwise we are discussing of the sexe of the trade names long time and useless. In other this means a potential that is degraded by the seeing level.
For instance my C8 equals the mewlon 180 that i owned and solded, now the 250 cassegrain equals almost the Meade 12 which is not bad.
Now when equivalent perfect diameters are defined the comparison between sizes is surprisingly not so crucial because the contrast is lead by this formula well verified with the FTM curve evaluations: c=c' * w/(w+5/6*D)
D the perfect dia, w width of the feature (elongated), c' the contrast actual on the planet.
If you get 1 or 2% on the planet, at the exit of the scope you will have less. Normal because a scope is a low pass filter. Sothat between 10 and 15" the gain is not null, not 1.5x but say 15% more in term of contrast.
Presently for capturing we need contrast.
Also it is necessary to know the scope characteristics (d, PTV actual) for getting the efficiency. Diffraction limited
commercial means only PTV3.3 (just for seeing the airy disk and the 1st diffraction ring well blurred in fact). In that case the strehl ratio is substantially less than 80% sothat the 15" may be less performing than the 10".
Just the idea because the intrinsic scope data are not identified. The 250 in use here equals 168mm perfect.
Hope this may be clear for you and an help.
Stanislas-Jean
Paul G. Abel
Reged: 01/28/10
Loc: UK
      #5472751 - 10/16/12 05:15 AM
Greetings all,
Many thanks for all the comments, I feel I should addressed some of the points raised here. First of all the telescope used to make the observations;
This was a a 20" Dall Kirkham. No star diagonal was used so North (as indicated by WINJUPOS) is at the bottom of the picture. To confuse matters, NASA have a different defintion of north than the IAU, the NASA definition puts north at the actua pole, the IAU definition (used here) puts north where the northern magnetic pole is located.
No star diagonals were used in this drawings, the image is drawn as it came out of the eyepiece. The markings on Uranus are always vague and ill-defined, even with a telescope as large as this, considerable care has to be taken since the disk is so small and one can easily be decieved. Nevertheless, I am reasonably sure the bright spot and brighter EZ were present.
Now the comparison with Stanislas-jean. Given the curvature of the EZ, some sort of star-diagonal must have been used. It looks as though this drawig was made some 12 days later, and is at a different CM longitude, so unless this is a long lived spot which has drifted in longitude (which I think unlikely), it must be a different feature.
Finally, the comparison between imaging and visual. This argument is probably one of the most pointless arguments in astronomy. Each method has its pros and cons, and in the end both processes require the input human brain (with all its subjectetivity). While it is true some imagers are content just to take pretty pictures, this is also true of some visual observers, I have seen a few drawings which are simply artistic interpretations, not scientific ones.
What we have to do is catagorise between observers, and artists. The observers should represent the scientific area of amateur astronomy. That is not to say the artistic way is any less valid, if that's what gives people pleasure out of astronomy then so be it.
I think most of what Stanislas said has been lost in translation, but I agree: your survey of imagers is wrong, I know quite a few British imagers and they are first class dilgent observers. Don't make sweeping statements which are blatently not true.
Best wishes,
-Paul.
Paul G. Abel
Reged: 01/28/10
Loc: UK
      #5472754 - 10/16/12 05:20 AM
stanislas-jean: I don't think that has anything to do with it! It's quite simple, the disk size of Uranus is small and requires a reasonable amount of magnification. If the seeing is poor, high magnification cannot be used.
Taras, you also have to look for some time, you can't just take a quick look, I spend about 15 minutes examining the disk of Uranus at various powers to try and build up a picture of what's there. Of course it maybe that you are sensitive to different colours (this is why people who are sensitive to red have difficulty seeing the markings of Venus).
Best wishes,
-Paul.
stanislas-jean
Reged: 10/22/08
      #5472773 - 10/16/12 05:52 AM
Paul, your assessment about the visual results are OK.
This is not the same feature. The sketch I performed here in past are performed with a diagonal mirror.
But what I note is brightenings are on this temperate belt.
Last evening I checked again the Uranus at CM 280°, 260° last report here, and the brightening is still here.
Now regarding magnifications for use on this planet the higher the better indeed but considering the seeing level on the moment. 30min arc represent the full moon size with the nake eye, it's a pretty size for collecting features with 500x on good nights, with 20min of arc (still enough) it can be catched still something, under this is problématic with regards to contrast levels. This means here 333x which is enough with a 200mm of good facture.
At final in spite of these conditions the features are not strong and illness indeed but here, as you reported also.
I donot spend more than few minuts for drawing what is reported, I spend time after in order to confirm or try to confirm what was at the first look. This verification stage take some long minuts.
Stanislas-Jean
stanislas-jean
Reged: 10/22/08
      #5474462 - 10/17/12 03:34 AM Attachment (26 downloads)
The sketch of 15th evening showing the same brigthening for CM280° (initially for CM260° last 12th).
Stanislas-Jean
azure1961p
Reged: 01/17/09
Loc: USA
      #5476044 - 10/17/12 10:55 PM
Paul,
Im particularly interested in how you reason or interpret the color filters having visibility, or lack on its moon[s].
It would seem blue should transmit the most light because of the spectrum pass in low light for the retina, and the red shoulve yielded nothing instead.
Im tempted to want to think the moon was reddish and so the filter passed it well, but this isnt the case. Perhaps the red helped the seeing steady by passing the sharper less affected light wavelengths. Blue is known dispersal more so in seeing less than optimum.
Pete
stanislas-jean
Reged: 10/22/08
      #5476276 - 10/18/12 02:34 AM
What was in use
WF without filter
W12 deep yellow filter
Refer to the previous post with the clouds absorption bands showed on the spectrum graph for the selection of the filter.
There is no matter of blue filter here, except for showing nothing visually with the use of such filter (mainly the W82) that cut red light but keep the green light. The use of the blue filter is interresting to be more confortable for the uranus report. IF nothing is reported with it is in a certain way a demontration. If something is this has to be controversial. But when showing the italian observer reports of the alpo site the blue filter brought the collection of the dark collar bordering the polar cap. Interresting, no? An artefact, probably not, in spite of the "authorised" views contracditory.
But the contrasts are fluctuing by periods it seems.
Stanislas-Jean
0 registered and 5 anonymous users are browsing this forum.
Moderator:  cildarith, JayinUT, WOBentley
