James Cunningham
Reged: 08/07/10
Loc: Maryland
Convert Lxd55 tripod for use with CG-5 mount?
      #5453183 - 10/03/12 08:15 AM
Has anyone converted their Lxd55 tripod to use with the CG-5 mount? If so, what was involved. Thanks.
Cow Jazz
Reged: 11/24/03
Loc: Toronto, Ontario
Re: Convert Lxd55 tripod for use with CG-5 mount? new [Re: James Cunningham]
      #5453381 - 10/03/12 11:03 AM
Hi Jim.
I responded on the LXD55 group, but I think I got your use backwards. I did it the other way around, with my LXD55 mount on a CG-5 tripod. It works really well, and the difference is huge.
James Cunningham
Reged: 08/07/10
Loc: Maryland
Re: Convert Lxd55 tripod for use with CG-5 mount? new [Re: Cow Jazz]
      #5453565 - 10/03/12 01:45 PM
I tried that but the base of the Lxd55 does not fit into the CD-5 mount. The dec stop is too long and the raised part of the bottom of the mount also does not fit. Can you tell me how you did it. Thanks.
Reged: 06/16/04
      #5454668 - 10/04/12 08:15 AM
James:
Which CG-5 mount do you have? The ASGT? Do you have the standard Tripod for it? If I remember correctly, the LXD-55 tripod was an aluminum tripod and as John implied, it's definitely a weak point and would have a hard time with your 6 inch refractor.
jgraham
Reged: 12/02/04
Loc: Miami Valley Astronomical Soci...
Re: Convert Lxd55 tripod for use with CG-5 mount? new [Re: Jon Isaacs]
      #5454695 - 10/04/12 08:48 AM
Yeah, the original LXD55 tripod was way too fragile for the weight of the LXD55 head and a telescope of any significant size.
James Cunningham
Reged: 08/07/10
Loc: Maryland
      #5454767 - 10/04/12 09:32 AM
I have the ASGT.
Starhawk
Space Ranger
Reged: 09/16/08
Loc: Tucson, Arizona
      #5454790 - 10/04/12 09:47 AM
It can be done, but you're going to wish you hadn't moved onto the flimsy LXD55 tripod.
What are you trying to accomplish?
-Rich
James Cunningham
Reged: 08/07/10
Loc: Maryland
Re: Convert Lxd55 tripod for use with CG-5 mount? new [Re: Starhawk]
      #5454840 - 10/04/12 10:20 AM
I have both the CG-5 and the Lxd55. I have a 6 inch refractor on the CG-5 and a 120mm refractor on the Lxd55. I wanted to try the Lxd55 mount on the CG-5 tripod.
Cow Jazz
Reged: 11/24/03
      #5462383 - 10/09/12 03:46 PM Attachment (8 downloads)
Here's a pic of the tripod with the added hex bolt at the north leg position. This replaces the large "stud" on the LXD tripod. The stabilizer shaft just screws into the bottom of the LXD mount.
James Cunningham
Reged: 08/07/10
Loc: Maryland
      #5462399 - 10/09/12 03:55 PM
Thanks. Now I understand.
23 registered and 73 anonymous users are browsing this forum.
