Pages: 1 | 2 | 3 | (show all)
Eddgie
Reged: 02/01/06
Re: Adapter to connect Denkmeier to Baader diagonal??? new [Re: johnnyha]
      #5457230 - 10/05/12 11:26 PM
Well, there is the added benefit of using the Baader GPCs as well!
In this configuration, it would likely be that I could just use the Baader GPC inserted into the diagonal the same way that it is used with the Maxbright!
This means that I could buy just the Televue bino body for $875 new, or there is one listed now on CN for sale that includes the Televue refractor adapter for $800.
But I prefer the Baader GPCs, and I don't see why they would not work.
What a great idea. Less than the Denks and with about the same aperture, but with the shortest possible light path.
Thanks again!
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
Re: Adapter to connect Denkmeier to Baader diagonal??? new [Re: Eddgie]
      #5457246 - 10/05/12 11:43 PM
It should work the same as the Maxbrights. Man, sometimes there are some GREAT deals on TV Binovues, I've seen them go for $500 and less. I'm tempted myself.
Eddgie
Reged: 02/01/06
      #5457256 - 10/05/12 11:51 PM
I am looking at the ads for the Televue.
Am I missing something, or does the Televue not use individual diopter type focusing? The manual on the TV web site is perhaps old, and maybe the later versions have diopter focusing, but the manual says that matching focus is accomplished by sliding the eyepeices in and out.
I really prefer the ability to focus the eyepeices individually.
johnnyha
Reged: 11/12/06
      #5457346 - 10/06/12 01:30 AM
Aha! There's the rub. I think you are right Eddgie and I would definitely not want a bino without individual diopter adjustment. I think the Denk II definitely has the edge here, I LOVE their diopters. I always felt like I could dial it in to the nth degree. Mark V, meh, requires some degree of iteration back and forth because you have to loosen the collar that holds the eyepieces to adjust the diopter, but then the focus changes again slightly when you actually tighten the collar back. Once you are set you're okay, but the eye does funny things when you view for awhile and its nice to be able to adjust them "on the fly". The Denk II is very simple and robust and the diopters simply thread in and out providing real time fine focus with beautiful precision. You don't have to loosen the eyepieces and tighten them back again like the MkV. So the Denk II are MUCH better in this regard especially when sharing views.
Eddgie
Reged: 02/01/06
      #5457832 - 10/06/12 11:54 AM
I was under the impression that the Mark V has microfocusing for each eyepeice.
I think the previous Ziess version did not.
I am still powerfully attracted to the Mark Vs except for the price. I really like the Baader system and the fact that the light path is kept very short.
But the cost is high enough that I would be willing to live with a Denk II and an adapter if I can find one that is very low profile.
I also considered a Denk II with a 1.25" nose and just using a Clicklock/T2 on top of the Baader prism. This may not be all that much longer light path than some adapters may require. I am pretty sure that Denk has a 1.25" nose available. Again, would not be as short as the Mark V, but at least I would be able to exploit the very short light path of the Baader T2 Prism.
DaveJ
Reged: 01/07/05
Loc: NE Ohio
      #5457889 - 10/06/12 12:33 PM
The Baader Mark V do, indeed, have microfocusers on each eyepiece. What Johnny mentioned has to do with the system Baader uses which requires that the eyepieces be released from the Clicklock (1/4 turn, at most) and then the microfocusers lift the eyepieces away from the clicklock. This is not easy to explain, but I love the system now that I'm used to it. Having come from the Denk II, which is slightly more intuitive to focus, it was confusing at first...now it's second nature. I find the view with the Mark V significantly better. Identical color and light throughput through each eye with the Mark V was noticed immediately. It's a stunning view. As a matter of fact, for the past 2 hours I've been watching migrating birds feed at our bird feeders using my wife's 80mm Apo and the Mark Vs. The 1.25 GPC in the front of the 2" nosepiece focuses on the feeders 12 feet away and I can immediately focus to infinity with the same exact setup. I really love it. I'm not making this any easier for you, am I, Ed.
Eddgie
Reged: 02/01/06
Re: Adapter to connect Denkmeier to Baader diagonal??? new [Re: DaveJ]
      #5457926 - 10/06/12 01:02 PM
Thanks for explaining. I think I understand what you are saying.
My preference would be for the Mark V. My feeling is that it is evolutionally perfected technology and there is no meaningful improvement to be found past this point in a 1.25" ocular binoviewer.
I really like the Baader system.
But... It is a lot of money. There is no way to suger-coat that. The $800 price differential to the Denk II makes me willing to accept an adapter based solution to mate it with the Baader diagonal.
I also believe that Denkmeier used to make a 1.25" nose for their BVs, and I would consider using the Denk 1.25" nose on the front of the Bino and putting a 1.25" click-lock on the Baader diagonal. This would be perhaps 10mm to 12mm longer than the adapter route, but my calcualtions suggest a total back focus in this configuration of close to 200mm.
I really want to keep the total light path to 180mm or less, and this may be difficult with the Denks. I do believe that the Mark V/T2 is unbeatable in terms of light path length in a 27mm aperture BV.
johnnyha
Reged: 11/12/06
      #5457951 - 10/06/12 01:19 PM
As Dave says, the Mk V does have microfocusers for each eyepiece but you cannot adjust them without loosening the eyepieces and the focus does change when you tighten them back up, so it is indeed an iterative process. The MkV diopters also require both hands to adjust. [EDIT: sorry that's not true actually, it can be done with one hand]. Once they are set for your eyes you should be okay but you cannot adjust them as you view. The Denks otoh you can adjust them while you are viewing without loosening the eyepieces or as I put it earlier "on the fly" and "in real time".
Edited by johnnyha (10/07/12 09:03 PM)
Tamiji Homma
Reged: 02/24/07
Loc: California, USA
      #5457953 - 10/06/12 01:20 PM
Left is 1.25" nosepiece, right is 2" nosepiece for Denk binoviewer.
Tammy
johnnyha
Reged: 11/12/06
Re: Adapter to connect Denkmeier to Baader diagonal??? new [Re: Tamiji Homma]
      #5457955 - 10/06/12 01:22 PM
Denk used to include the 1.25" nosepiece as well as the 2", I'm sure you could find one with a "wanted" ad, there must be hundreds of unused ones floating around out there.
Edited by johnnyha (10/06/12 01:35 PM)
Eddgie
Reged: 02/01/06
      #5457973 - 10/06/12 01:45 PM
I do have the Maxbrights and love them, but really want to use 24mm ES 68s to binoview with.
I owned a Denk (Standard) supersystem, and was loosing aperture with itin my C14.
I replaced it with a Baader Maxbright and this configuration sold me on the importance of keeping the light path short in an SCT. With Maxbright/T2, the system is working at 100% aperture.
The Denk Supersystem was loosing about 2 to 3 inches of aperture with the low power arm in place, so that also taugth me that a power switch really doesn't work with an SCT unless one is OK with the aperture loss (I am not).
So, now I am back at the point where I want to use 24mm wide field eyepeics. Even 22mm Pans vignetted slightly in the Baader Maxbrights, thought the 20mm ES 68s work fine. Still, in the C14, this works out to almost 200x, which is a bit more than I can use for much of my viewing.
I know I can stay below 200mm with the Mark V, and possibly with the Denk II with a short adapter, and with 24mm eyepeices, get the magnifications down to 165x, which seems a bit more useful for general observing.
I do appreciate all of the advice though...
johnnyha
Reged: 11/12/06
      #5458031 - 10/06/12 02:29 PM
Yes sorry Ed I went back and read your original post and deleted my suggestion for the Maxbrights realizing you probably already had them.
Eddgie
Reged: 02/01/06
      #5458108 - 10/06/12 03:39 PM
Oh, no problem. It was an excellent suggestion.. I have highly recommended the Maxbrights to several individuals. I find them to be super-excellent. Just would like a bit less magnification.
johnnyha
Reged: 11/12/06
      #5458190 - 10/06/12 05:03 PM
I hear you. I don't do a lot of low-power binoviewing but last night I had the 24mm Pans in my MkVs testing out some focusing positions. I recently installed an FT3545 focuser on my FS152 with a low profile adapter and sure enough I can reach focus at 1X with my 24mm Pans with about 1/2" to spare - but only because I am using the MkVs with their shorter overall lightpath. With the new focuser and the MkVs I can also reach focus at 2.6X with 1/2" to spare on the other end racking it almost all the way out. Absolutely perfect! This was impossible with the stock focuser which had a 2.75" drawtube as opposed to the Feathertouch 4.5" drawtube.
Back to the Denk IIs - I assume you were planning on using them without the Powerswitch? Because the Powerswitch not only adds length to the setup, it also requires the OCS, it does not work without it.
Tamiji Homma
Reged: 02/24/07
      #5479139 - 10/19/12 05:00 PM
Wow.. You must be an easy sell.. LOL.
Hi Ed,
I received T2 female<->Denk Dovetail adapter.
Directly on top of Baader Prism Star Diagonal. Adapter length is 15mm:
Denk II binoviewer is removed, from Denk Dovetail connector side:
Just adapter from T2 thread side:
Connect Baader Quick Change System instead of directly screwing into thread of Baader Prism Star Diagonal:
I could ask Precise Parts a little shorter adapter to cut down light path. I think it could be 5-6mm shorter , perhaps. But it is harder to grip adapter if it is too short... I guess this is good compromise.
Tammy
johnnyha
Reged: 11/12/06
      #5479161 - 10/19/12 05:20 PM
Sweet!
Eddgie
Reged: 02/01/06
      #5479218 - 10/19/12 05:58 PM
Very nice. Compact and a clean solution.
But I have decided to go with the Mark V. It was a difficult decision.
It was very good of you to post the pictures though. I think for a lot of people that want a big aperture bino, the Denk Standard with this adapter will be a good alternative to the Maxbright. You could use the Denk standard head, the adapter, and the standard Baader T2 prism and for a little more money than the Maxbright, have a 27mm aperture vs the 23 of the Maxbright.
Again, very nice adpater, and I am sure that the forum members will appreciate knowing that they have another option.
Baader T2 Prism/Denk Standard would be a great mid-priced system.
jtaylor996
Reged: 09/02/08
Loc: North Texas
      #5501699 - 11/02/12 10:29 PM
What did that precise parts adapter cost?
Tamiji Homma
Reged: 02/24/07
Re: Adapter to connect Denkmeier to Baader diagonal??? new [Re: jtaylor996]
      #5502372 - 11/03/12 12:52 PM
Are you asking price of DenkII binoviewer to T2 female thread adapter?
If so, it was $113.
Tammy
jtaylor996
Reged: 09/02/08
Loc: North Texas
      #5502530 - 11/03/12 03:02 PM
That's the one. Thanks!
1 registered and 5 anonymous users are browsing this forum.
Moderator:  TG, Geo557
