chemist
Reged: 10/09/10
Loc: Central Texas
Re: What extra eyepieces would a beginner need for 6SE new [Re: Skip]
      #5471586 - 10/15/12 01:30 PM
Just thought I should mention that eye relief and exit pupil are just as important as magnification and field of view. I don't like EP's with less than 10-12mm of eye relief, and 15mm or more is needed if you wear glasses while viewing. For an f/10 scope like the 6SE, EP's in the range of 15-25mm will give better apparent brightness and contrast than those below 10mm.
I agree that a 2X Barlow is a must since it effectively gives you two magnification options for each EP. I also suggest a 32mm (or 40mm) EP for wider angle views of star clusters and asterisms. And for just "huntin' around for stuff", the 24-8mm zoom can't be beat.
Chemist
AlexDJ30
Reged: 09/02/08
Loc: Monterrey, Mexico
      #5477046 - 10/18/12 02:03 PM
Silent I think that the good suggestion is starting with a Zoom eyepice, I think thats the best start if you dont want to spend lots of money and give a wide range of magnifications plus its just one eyepice to carry to use it fast and the SCT scopes are a bite forgiving on the quality of the eyepices (not like fast refractors thats needs good quality eyepices), later on you can buy specialize eyepices, and about a 2X barlow most of my viewing time i dont use it , I have a celestron Zoom eyepice (its OK zoom the only problems at least with mine is some black outs if i move my eyes) and almost all the times i never use the 2X barlow (I have one). I would recomend you that you try to buy a zoom for the easy use and fast (if you can buy a better quality zoom like Baader its better!) and then if you want eyepices then go for them but at least the zoom will perform good on the 6SE.
3 registered and 5 anonymous users are browsing this forum.
Moderator:  KWB, WaterMaster
