astrovale
Reged: 02/19/06
Loc: Rimini, Italy
11582 h-alpha high resolution: - noise + contrast
#5466350 - 10/12/12 05:05 AM Attachment (19 downloads)
After reading Wes' comment to my latest high resolution image, I decided that I should be less lazy and reprocess the original image instead of just cropping a bad mosaic. Indeed, the reason why I did not post or bother processing the mosaic was that one of the pane was a ... pain
So I found out that processing the original image revealed a potential that I had overlooked in the first processing that was limited by the dead weight of the bad image!
So, to make a long story almost short, this processing isn't affected by the noisy area in the upper right corner (as correctly pointed out by the eagle-eyed Wes) and is less flat as I added a little more micro-contrast (blessed PS curves!).
Hope you like it more than the previous: I do
Luca The posted image is only 70% size and 50% quality. Full size and quality here: http://www.amun-ra.org/NOAA_HA/11582/NOAA11582_10032012_Ha019_1.jpg
Matt Wastell
Reged: 07/05/09
Loc: Paddington, Brisbane, Australi...
Re: 11582 h-alpha high resolution: - noise + contrast
[Re: astrovale]
#5466360 - 10/12/12 05:26 AM
A stunning re-visit!
raylal
Reged: 04/19/10
Loc: Cornwall, Ont., Canada
[Re: Matt Wastell]
#5466483 - 10/12/12 08:24 AM
WOW sharp and crisp. Great job.
Ray
wes
Reged: 11/13/03
Loc: Oklahoma
[Re: astrovale]
#5466954 - 10/12/12 03:33 PM
Luca,
An already fantastic image is even better now, I like your improvements. As I'm sure you well know I was not criticizing your image but just simply pointing out something you may have missed I always appreciate it when people do the same for me.
Wes
rigel123
Reged: 06/29/09
Loc: SW Ohio
[Re: astrovale]
#5467083 - 10/12/12 04:52 PM
That is gorgeous!!
astrovale
Reged: 02/19/06
Loc: Rimini, Italy
[Re: wes]
#5467125 - 10/12/12 05:22 PM
Dear Wes, no reason to point that out! I know the spirit that moved you and I appreciated your suggestion (frankly that noise had escaped my scrutiny) and I will always appreciate comments that help me improve in all the things I do. That is the way I am.
So, sincerely, thanks for pointing that out
Luca
5 registered and 23 anonymous users are browsing this forum.
Moderator: Bowmoreman, KWB
