Cotts
Just Wondering
Reged: 10/10/05
Loc: Toronto, Ontario
Turning Drive Off Briefly - Mach1GTO new
      #5466580 - 10/12/12 09:53 AM
Is there a way to temporarily stop the drive of my GTO without losing my alignment and/or turning the whole thing off? I'm beginning a program of Double Star measurement and the REDUC software needs an E-W star trail in the image in order to set a baseline for PA measurements.
Dave
korborh
Reged: 01/29/11
Re: Turning Drive Off Briefly - Mach1GTO new [Re: Cotts]
      #5466617 - 10/12/12 10:21 AM
Just turn the Sidereal tracking off using button 8 on the keypad. You will not lose alignment
Cotts
Just Wondering
Reged: 10/10/05
Re: Turning Drive Off Briefly - Mach1GTO new [Re: korborh]
      #5467399 - 10/12/12 09:02 PM
Thanks, 'k'. I suppose the 8 button toglles the drive off and on.....
Dave
M13 Observer
Reged: 12/09/06
      #5467470 - 10/12/12 10:06 PM
Dave
Not quite. From the Main (top) menu, the 8 button toggles through sidereal, solar, lunar tracking rates and stop. Grab up a copy of the v4.12 keypad manual, sit down, and have a read. There is also a serial based command to get to this item directly. Yes the keypad is up to v4.17 but it is just a few bug fixes which are noted in the 4.17 addendum but the base 4.12 manual has not changed. As is normally the case, a bit of poking around on the extraordinarily well laid out Astro-Physics website will lead you to these items.
Cotts
Just Wondering
Reged: 10/10/05
Re: Turning Drive Off Briefly - Mach1GTO new [Re: M13 Observer]
      #5468016 - 10/13/12 10:34 AM
Dave
Thanks for the clarification. A bit of poking around here onCN leads me to these items with excellent efficiency....
Dave
M13 Observer
Reged: 12/09/06
Re: Turning Drive Off Briefly - Mach1GTO [Re: Cotts]
      #5468333 - 10/13/12 01:30 PM
Dave
Dave
Not me. In general, I find the signal to noise ratio on this site to be p poor, the quality of even the decent responses to be mediocre (even mine as I don't recall the actual sequence of the button presses nor do I recall the serial command), and the length of time required to get such info to be incredibly slow. In comparison, by going to the AP website, getting the on-line pdf of the manual and by searching it for "stop" I would have the exact info directly from the source and I would likely have learned several other interesting tidbits in the process. I would also have a pdf copy of the manual on my computer, iPad, and iPhone as well. The total elapsed time would have been comparable to what it took you to type your original question here.
10 registered and 30 anonymous users are browsing this forum.
