dvb
different Syndrome.
Reged: 06/18/05
Loc: Vancouver, Canada
A few iEQ45 mods
#5472054 - 10/15/12 06:26 PM Attachment (124 downloads)
I've been quite pleased with the iEQ45 mount - I wasn't sure if it would manage my 10" f/4.5 Newt, but it does, for visual use, in its "stripped down version" with the Ken Dauzat rings, which weights about 33 lb., with a Parcorr, Nagler 31T5, and TelRad. The heavier Parallax rings, at 39 lb., are manageable, but I didn't really enjoy it.
I have replaced the stock saddles with a the ADM Vixen/Losmandy type.
You'll note I am using the iEQ45 extension bar - with that, 2 weights will do more that 4 weights on the stock bar alone.
Edited by dvb (10/16/12 12:17 PM)
dvb
different Syndrome.
Reged: 06/18/05
Re: A few iEQ45 mods
[Re: dvb]
#5472059 - 10/15/12 06:29 PM Attachment (73 downloads)
A surprising annoyance of the iEQ45 is the tripod spreader, which is made of plastic, with "vanes" underneath - these cut into the hand while carrying the mount, and remove some of the benefit of its light weight.
dvb
different Syndrome.
Reged: 06/18/05
[Re: dvb]
#5472064 - 10/15/12 06:33 PM Attachment (77 downloads)
I happened to have a spare spreader from a Skywatcher mount. On its own, it is too wide to properly mate with the spindle of the iEQ45. One option would be to replace the spindle with something longer, but my dealer, Nick at Vancouver Telescope Centre, was kind enought to shorten the wings of the extra SW spreader so it is compatable with the stock iEQ45 spindle. Here is the shorter SW spreader (black) lying on a stock SW spreader (white).
dvb
different Syndrome.
Reged: 06/18/05
[Re: dvb]
#5472072 - 10/15/12 06:36 PM Attachment (88 downloads)
A final annoyance is the azimuth adjustment bolts - they are cold-forged, square-ended, which makes adjustment kind of "jiddery"; not very smooth:
dvb
different Syndrome.
Reged: 06/18/05
[Re: dvb]
#5472076 - 10/15/12 06:38 PM Attachment (67 downloads)
Nick at Vancouver Telescope was kind enough to round the end of the screw on his grinder:
dvb
different Syndrome.
Reged: 06/18/05
[Re: dvb]
#5472088 - 10/15/12 06:46 PM
I know there some other mods out there. For example, here is a link to a spreader made from wood:
http://tinyurl.com/ckkbwtp
A really nice job!
I'd be interested in other posts or links to mods folks might have to share.
MRNUTTY
Reged: 11/22/11
Loc: Mendon, MA
[Re: dvb]
#5472183 - 10/15/12 07:42 PM
Good stuff!
Phillip Easton
Reged: 12/24/10
Loc: DFW
[Re: MRNUTTY]
#5472508 - 10/15/12 11:34 PM Attachment (54 downloads)
Finish off your azimuth mod by sanding the paint off of the contact surfaces between the mount and the tripod. Use painter's tape to mask off the surfaces you don't want to sand. I also put the mount in a bag to keep it clean. Put a thin film of super lube on the surfaces to help protect them and reduce friction. Makes it much easier to adjust.
I also put super lube on alt bolt and wheel.
Got the idea here:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/4198974/page/0/view/collapsed/sb/5/o/all/fpart/28/vc/1
Edited by Phillip Easton (10/15/12 11:39 PM)
Phillip Easton
Reged: 12/24/10
Loc: DFW
[Re: Phillip Easton]
#5472519 - 10/15/12 11:40 PM Attachment (58 downloads)
The bottom of the mount.
dvb
different Syndrome.
Reged: 06/18/05
#5472525 - 10/15/12 11:45 PM
Thanks for the suggestion, Phillip!
dvb
different Syndrome.
Reged: 06/18/05
[Re: dvb]
#5472529 - 10/15/12 11:47 PM
Here's a link to an excellent wood accessory shelf that fits over the stock spreader, made by Midnight Dan:
http://tinyurl.com/cq62zg5
Edited by dvb (10/15/12 11:49 PM)
Phillip Easton
Reged: 12/24/10
Loc: DFW
[Re: dvb]
#5476519 - 10/18/12 08:24 AM
Okay, I finally got around to doing a polar alignment after doing azi and alt mods/tweaks and wow what a difference. After struggling with trying to do fine adjustments it was a huge difference! No more jerky motion everything was smooth as butter.
Summarize:
1 - Round off the azi adjustment bolts
2 - Sand off the paint and lube mount/tripod contact surfaces
3 - Lube the pivot bolts (at the back) for alt adjustment and the inside of the adjustment wheel.
4 - Use a longer bolt to put in the alt adjustment wheel. I found a long screw with an actual plastic knob on the end at Ace Hardware.
If you have an iEQ45 and do nothing else do these.
Cheers!
Phillip
Edited by Phillip Easton (10/18/12 08:26 AM)
dvb
different Syndrome.
Reged: 06/18/05
#5476807 - 10/18/12 11:56 AM
Astronewb
Reged: 09/19/11
Loc: Connecticut
#5477647 - 10/18/12 08:02 PM
Summarize:
1 - Round off the azi adjustment bolts 2 - Sand off the paint and lube mount/tripod contact surfaces 3 - Lube the pivot bolts (at the back) for alt adjustment and the inside of the adjustment wheel. 4 - Use a longer bolt to put in the alt adjustment wheel. I found a long screw with an actual plastic knob on the end at Ace Hardware.
Cheers! Phillip
Ditto the above...! Also, you can try some of these mods:
http://www.flickr.com/photos/astronewb2011/sets/72157629679446064/
http://www.flickr.com/photos/astronewb2011/sets/72157631021687076/
Thanks for the informative thread.
Paul
Midnight Dan
Reged: 01/23/08
[Re: Astronewb]
#5477764 - 10/18/12 09:20 PM
Excellent advice, Phillip! I've put those mods on my todo list! Thanks!
-Dan
Phillip Easton
Reged: 12/24/10
Loc: DFW
[Re: Midnight Dan]
#5478580 - 10/19/12 10:55 AM
-Dan
Dan,
No problem, I am glad I went back through that long thread I referenced and tried out some of the ideas. I could not believe what a difference it made in doing the polar alignment. My goto's were better that night as well. Going to be going to our club's dark site tonight so actually looking forward to setting it up again.
Cheers! Phillip
dvb
different Syndrome.
Reged: 06/18/05
[Re: Astronewb]
#5480231 - 10/20/12 11:40 AM
Paul
Those are very impressive mods, Paul - I enjoyed the Flickr slideshows.
Phillip Easton
Reged: 12/24/10
Loc: DFW
[Re: dvb]
#5496292 - 10/30/12 02:37 PM
Gents,
I updated my site with additional images for the mods/tweaks I have done in case anyone is interested.
http://www.the3dwizard.net/index.php/astronomy/ieq45
Cheers!
Midnight Dan
Reged: 01/23/08
#5496349 - 10/30/12 03:06 PM
Just completed Phil's list of mods and they make a very nice difference in smoothness of altitude and azimuth adjustments!
The only thing I did a little different was to completely separate the base from the mount head. That way I didn't have to put the mount head in a plastic bag to keep it clean while sanding the paint off of the base surface. Plus it opened up all the screws, threaded holes and adjusters for easy lubing.
-Dan
Wembley2000
Reged: 01/07/12
Loc: NW Ohio
[Re: Midnight Dan]
#5496405 - 10/30/12 03:52 PM
I sent Aeroquest Machining my ieq45 worm and Jim made me a new one. When the skies clear, I will let you all know how it goes with pempro graphs.
Wem
Phillip Easton
Reged: 12/24/10
Loc: DFW
[Re: Wembley2000]
#5496435 - 10/30/12 04:12 PM
Dan,
Wish I had thought of removing the base, LOL
Wem,
Certainly want to hear how this works out!
Cheers! Phillip
Astronewb
Reged: 09/19/11
Loc: Connecticut
[Re: Wembley2000]
#5496474 - 10/30/12 04:42 PM
Wem
Jim at Aeroquest makes a nice worm. I installed one about a week ago and compared the stock worm to the Aeroquest worm using the TE Recorder software on my TEM. Here are screenshots of the results. Good luck with yours.
Stock worm: [img]http://farm9.staticflickr.com/8469/8139537570_291645... No TDM Stock Worm by Astronewb2011, on Flickr
Aeroquest worm: [img]http://farm9.staticflickr.com/8056/8139506881_f78c30... No TDM Aeroquest Worm by Astronewb2011, on Flickr
Just a simple bolt on reduced the PE from 32 arc-seconds to 19 arc-seconds. A very cost effective modification.
Paul
Wembley2000
Reged: 01/07/12
Loc: NW Ohio
[Re: Astronewb]
#5496515 - 10/30/12 05:04 PM
http://www.flickr.com/photos/astronewb2011/sets/721576296...
http://www.flickr.com/photos/astronewb2011/sets/721576310...
Paul
Paul's tensioners are also a very worthwhile upgrade, really helps to smooth out the frequency spectrum. Lowered my pe by roughly 20%, smoothed out a 20 second error due to the belt to nothing.
Wem
Phillip Easton
Reged: 12/24/10
Loc: DFW
[Re: Astronewb]
#5496525 - 10/30/12 05:11 PM
Paul or Wem,
How much did the worm cost? I have gotten my PE down from 40 (replacement worm from iOptron) to 20 arc-secs by adjusting mesh and using a stiffer spring. Wonder if the Areoquest worm would help to bring it down further of is the low 20's about the best we can hope for without PEC or the TDM?
Cheers!
Wembley2000
Reged: 01/07/12
Loc: NW Ohio
#5496553 - 10/30/12 05:28 PM
Phillip,
The worm was 105 plus shipping. I will let you know if it will help you out when I get a chance to give it a try. If you are already at 20 and I get results close to Paul's, it would not be worth while for you. I need to wait until probably thursday or friday for Sandy to clear out of my neck of the woods.
Wem
orlyandico
Reged: 08/10/09
Loc: Singapore
[Re: Wembley2000]
#5496847 - 10/30/12 08:38 PM
I put an Aeroquest worm on my CGEM. It reduced the fundamental periodic error from 29" to 15"
However - the CGEM has a huge non-integral 2.6667X periodic error due to the gearbox - and on my CGEM the amplitude of this harmonic is 20"
Hence the Aeroquest didn't really reduce the overall PE very much (net-net PE went down by about 3").
chboss
Reged: 03/24/08
Loc: Tokyo Japan
[Re: orlyandico]
#5497227 - 10/31/12 02:17 AM
Nice information regarding optimizing the periodic error. I need to measure mine and see how big the error is. The tip with the stronger springs makes sense to me, I always felt the pre tension on the RA block was too low.
best regards Chris
Astronewb
Reged: 09/19/11
Loc: Connecticut
[Re: chboss]
#5497416 - 10/31/12 08:32 AM
best regards Chris
Just a note, be careful with the spring, too much tension will result in increased motor loading and greatly increased gear noise when slewing. Proper mesh is the key ingredient to lowering PE. As is reducing all play in the housing/worm to minimum, ie; zero play.
Clear skies,
Paul
Astronewb
Reged: 09/19/11
Loc: Connecticut
[Re: Astronewb]
#5499214 - 11/01/12 11:08 AM
I forgot to mention an important mod while reading the thread. Just remembered...you all must have experienced the shift in the FOV if you accidentaly touch the polar scope focuser while doing a polar align?
This shift of FOV occurs when you turn the focuser element also.
Run down to your toolbox, or hardware store and grab a roll of Tefon Pipe Thread tape. Unscrew the focuser from the polar scope...wrap a turn of Teflon pipe tape around the threads and then screw it back in. Voila! The focuser is now significantly tighter in the housing, and will not shift FOV when you touch it.
This works on the SmartEQ polar scope as well, and probably any polar scope with a threaded focuser element.
Paul
dvb
different Syndrome.
Reged: 06/18/05
[Re: Astronewb]
#5500339 - 11/02/12 02:03 AM
Thanks Paul!
Wembley2000
Reged: 01/07/12
Loc: NW Ohio
[Re: dvb]
#5500522 - 11/02/12 08:19 AM
Also anyone looking for a hand controller extension cable, the one for the cgem scopestuff sells will work. I had one left over from my cgem experience and it works fine.
Brian
Wembley2000
Reged: 01/07/12
Loc: NW Ohio
[Re: Wembley2000]
#5506393 - 11/06/12 07:11 AM
Wem
Finally a clear night lastnight. My results with the Aeroquest worm were very similiar to Paul's, 19 p-p error. These results were much better than my original stock worm, 51 p-p, but about the same as my replacement worm iOptron sent me. I can post graphs later today.
I am going to be putting the replacement worm back in the mount tonight as its native PE is a little smoother than the aeroquest worm.
Brian
Phillip Easton
Reged: 12/24/10
Loc: DFW
[Re: Wembley2000]
#5506463 - 11/06/12 08:21 AM
Brian,
Thanks for the update. I went from 60 to 30 with a worm I also got from iOptron. Finally got into the 20's when I changed the spring and took more time to align. Going to put on Paul's tensioner tonight and see how it rolls
Phillip Easton
Reged: 12/24/10
Loc: DFW
[Re: Astronewb]
#5535890 - 11/23/12 05:17 PM
Paul
Paul,
Thanks for the tip. Just did it to mine and it makes a huge difference when trying to focus. Also expect it to stay in focus better now as well.
Cheers! Phillip
