dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Denkmeier S1& filter Swicth on CPC Wedge
      #5478462 - 10/19/12 09:42 AM
I posted some of this a little earlier under another blog. I have a 9.25 CPC on Celestron H/D wedge. Am looking at the S1 with filter switch; I see where for A/P it would be a big help from switching from viewing ( I have all 2" E/P) to a CCD or DSLR. To go from F10 to F6 or a 2X without removing things then being able to switch filters as well seems like a good deal. Was wondering on clearance on a CPC W/ wedge or any issues if any users have had. On their web page the S1 with filter switch looks pretty big. Any (recent) input from any users as to quality and use? Thank you
Reged: 07/06/07
Re: Denkmeier S1& filter Swicth on CPC Wedge new [Re: dragonslayer1]
      #5478473 - 10/19/12 09:49 AM
I use a filter switch/power switch all the time. It's actually more useful for visual than imaging, but it shouldn't cause any problems on a wedge. Hell, I use mine on an alt-az mounted NS11 GPS...
Sorny
Reged: 03/15/12
Loc: Southern MN
Re: Denkmeier S1& filter Swicth on CPC Wedge new [Re: rmollise]
      #5479519 - 10/19/12 09:25 PM
I'm using a CPC1100 with a S2 power switch diagonal, and I'm confident I could throw a crayford focuser on the back and still clear the base by a wide margin. I imagine the 9" is quite similar due to the length of the tube on the 9 relative to the 11.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: Denkmeier S1& filter Swicth on CPC Wedge new [Re: Sorny]
      #5480504 - 10/20/12 02:30 PM
Sorny, am curious why you went with S2, The info from their Web site says "choose diag S1 if using single eye[iece only and no binoviewer" ??? Rod, Are you using the S1 or S2? Thank you both for the input
Sorny
Reged: 03/15/12
Loc: Southern MN
      #5481650 - 10/21/12 09:56 AM
I binoview with my scope.
Reged: 07/06/07
      #5483195 - 10/22/12 07:48 AM
S1
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
      #5483467 - 10/22/12 11:33 AM
thank you both for the help, will probably pull the trigger and get one
Never2Busy4You
Reged: 11/20/11
Loc: Slower Lower Delaware U.S.A.
      #5519511 - 11/14/12 01:04 PM
I use a Denk R2 Dual PxS with a separate Denk Filter Switch at the same time on my CPC 8" and it works on or off the Celestron Pro Wedge. I use it on my refractors also, and both ways with Binoviewer and Single EP's, it has become my most used piece of astro gear. If you get it you'll really enjoy it.
Best of Luck,
Jeffrey G.
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: Denkmeier S1& filter Swicth on CPC Wedge new [Re: Never2Busy4You]
      #5521442 - 11/15/12 03:33 PM
Hey Jeffery,
ordered the S1with filter switch, should be here next week. I just mounted a Crayford focuser and am really pleased with it. Eliminates the mirror shift when focusing. hated having to undo EP accessories to change filters or Barlow, especially when trying to do AP. so this S1 and filter switch eliminates another step in hurdles to viewing and AP. Now if can just get good weather and work schedule to coincide all will be well. Next project is possible millicam.
17 registered and 12 anonymous users are browsing this forum.
Calendar Event: 10/19/12
