Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | (show all)
HowardK
Reged: 10/20/10
Re: AZ EQ6 in the US? new [Re: opticsguy]
      #5624309 - 01/15/13 12:29 PM
Also, Orion advertises a 44 pound weight capacity but the finer print shows this as equally loaded with two scopes in alt/az mode. Not one scope, a little misleading in my opinion.
I do not believe that is correct.
I thought it was 44lbs main scope in alt az and 2 counterweights equaling 22lbs or a secondary scope of similar weight to balance.
David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
Re: AZ EQ6 in the US? new [Re: Lee Jay]
      #5627135 - 01/16/13 10:18 PM
Well, I saw Jack's mount in person this evening. Looks like a well thought out piece of hardware. And it retains that marvelous Atlas hum. You can barely here it operate. I think this one is going to be a winner. If there was one thing I'd change, it would be the saddle. It's set up for a Losmandy D style dovetail, but it's fairly small. I would make it longer, like the Losmandy G11's saddle.
It looks like we may get a field test report from Jack. After this consarned (thanks, Rod ) stretch of cloudy/rainy weather, it looks like we may be in for about a week's worth of clear skies.
David
Jack Huerkamp
Vendor - Waning Moon
Reged: 10/13/05
Loc: Louisiana
      #5627599 - 01/17/13 08:30 AM
They advertise a 20Kg load for visual and a17Kg load for imaging while in EQ mode and there is a gentleman in Austria using an 18Kg 10" f/5 Newtonian in EQ mode with great success. It would be interesting to see if the mount could handle a 12" f/4. The moment arm would be similar although the weight would be slightly higher.
Jack Huerkamp
Jack Huerkamp
Reged: 10/13/05
Loc: Louisiana
Re: AZ EQ6 in the US? new [Re: David Pavlich]
      #5627607 - 01/17/13 08:33 AM
Davis,
Hopefully I will be able to get the mount out this weekend. I have a contractor coming in to help with the observatory and other tasks around the house, but if time permits, I will do so.
Jack
HowardK
Reged: 10/20/10
Re: AZ EQ6 in the US? new [Re: Jack Huerkamp]
      #5628556 - 01/17/13 05:51 PM
Jack
Just received my az eq6
Looks great...very well engineered, great sounding motors, very cool
Looks much more capable than my MT Pro
Let us know how you go
Howard
HowardK
Reged: 10/20/10
Re: AZ EQ6 in the US? new [Re: HowardK]
      #5629437 - 01/18/13 07:42 AM
Hi
I have been using sky safari with sky fi perfectly with my CGE PRO mount.
I now have a SKY WATCHER AZ EQ6 and using the same cable from sky fi to the synscan hand controller as i use with the CGE PRO i cannot connect to the mount.
Do i need a specific cable for the SKY WATCHER....or should the Celestron one work?
Thanking you
Howard
Spain
Jack Huerkamp
Reged: 10/13/05
Loc: Louisiana
      #5629476 - 01/18/13 08:35 AM
Howard,
You need the Atlas/SynScan cable for the SkyFi unit. The Celestron cable is not the same.
Also, the mount comes with a cable used for updating the firmware. I did not try it to see if it will work with the SKyFi.
Jack Huerkamp
HowardK
Reged: 10/20/10
      #5630479 - 01/18/13 07:38 PM
Jack
i have it working now by using the serial cable from sky fi and the serial adapter that came with the az eq6 for firmware updates...but this is clumsy...
do you know of one cable that connects sky fi with synscan..?
carbon12 makes one for the cge pro but not it appears yet for synscan
Howard
Jack Huerkamp
Reged: 10/13/05
Loc: Louisiana
      #5632392 - 01/19/13 10:54 PM
Howard,
Here is a picture of the SkyFi Cable connected to the hand controller on my AZ-EQ6:
Jack
HowardK
Reged: 10/20/10
      #5634445 - 01/21/13 07:54 AM
thanks Jack
carbon12 are looking in to supplying 1 cable to tidy this up
14 registered and 40 anonymous users are browsing this forum.
