Ratchet
Reged: 08/07/11
Loc: Tallahassee, FL
FYI - Point Grey Chameleon source
#5490762 - 10/26/12 07:36 PM
I couldn't find anything already posted on this ebay source, so here goes:
http://www.ebay.com/itm/Chameleon-1-3-MP-Mono-USB-2-0-OEM-Camera-CMLN-13S2M-CS-from-Point-Grey-Research-/281003808282?pt=LH_DefaultDomain_0&hash=item416d21d61a
I got a very reasonable accepted offer on one of these. I'll update when it arrives and is tested out.
ratchet
ValeryD
Vendor (Aries)
Reged: 11/26/05
Loc: Kherson, Ukraine.
Re: FYI - Point Grey Chameleon source
[Re: Ratchet]
#5491252 - 10/27/12 07:26 AM
ratchet
All is OK, include price, but in todays standards it's frame per second speed is very limited.
Great Attractor
journeyman
Reged: 10/23/12
Loc: Poland
[Re: ValeryD]
#5491314 - 10/27/12 08:22 AM
It is limited, but (for high-resolution solar imaging) not necessarily limiting. 1 minute at 18 fps gives a little over 1000 frames, which in my case gives satisfying results: thread.
PiotrM
Reged: 01/03/10
Loc: Poland
[Re: Great Attractor]
#5491410 - 10/27/12 09:58 AM
Chameleon is a very good camera. However the prices are falling down and paying bit more you can get PGR Blackfly (soon) or Ximea xiQ on faster interfaces - if you need that extra speed.
ValeryD
Vendor (Aries)
Reged: 11/26/05
#5491763 - 10/27/12 02:08 PM
The speed is always in deficit. I now imaging the sun with high resolution with exactly the same chip (but with GigE via USB 3.0). 1000 frames are not enough to choose enough good frames out of this 1000. With good seeing I need at least 5000 frames for 500-700 frames suitable for processing. However if I need really noise free images I need avarage at least 1200 frames and this need to record about 10000 frames to choose from. And the problem is that the sun's surface details are fast moving and if I recording 10000 frames at 33 frames per second, the time of record will 5 min! And most filaments around spots are smeared.
So, the faster, the better! USB 2.0 is a yesterday in high resolution imaging.
PiotrM
Reged: 01/03/10
Loc: Poland
[Re: ValeryD]
#5491772 - 10/27/12 02:16 PM
That's a lot of frames. I think you should like the CMOSIS sensors when they show up on USB3. 2048 x 2048 at 90FPS or 2048 x 1088 at 180FPS
tim53
Reged: 12/17/04
Loc: Highland Park, CA
[Re: PiotrM]
#5491803 - 10/27/12 02:50 PM
I would think that the Chameleon, with its exview ccd, would be best suited to faint planets like Saturn through Neptune, where the sensitivity is most needed to keep the exposures down, but you're not likely to have the apterture to pull in enough light to enable shooting at high frame rates (for Uranus and Neptune, at least).
-Tim.
PiotrM
Reged: 01/03/10
Loc: Poland
[Re: tim53]
#5491824 - 10/27/12 03:11 PM
I would think that the Chameleon, with its exview ccd, would be best suited to faint planets like Saturn ..
ICX618 is bit better than ICX445.
ValeryD
Vendor (Aries)
Reged: 11/26/05
[Re: PiotrM]
#5492051 - 10/27/12 06:33 PM
Depends of the price and if they will be free of Newton rings when used for H-a and Ca-K imaging.
Can you, Piotr, provide the link to such a cameras description or annoucements?
Thanks.
PiotrM
Reged: 01/03/10
Loc: Poland
[Re: ValeryD]
#5492178 - 10/27/12 07:54 PM
http://www.ximea.com/usb3-vision-camera http://www.baslerweb.com/products/ace.html (GigE tab)
They are still unavailable as USB3/GigE, only CameraLink, but that's unusable for us. The CMV4000 cams will be around 1500-1800 EUR.
At the moment e2v CMOS sensors are free from sensor-induced Newton rings. Micron sensors do induce quite often, but that's older design. CMOSIS uses some new technologies so maybe it will be free of Newton rins.
