rdn
journeyman
Reged: 09/21/12
Loc: New Jersey
Use a "Celestron Logic Drive" on a Super Polaris
      #5490832 - 10/26/12 08:27 PM
I have a Super Polaris mount. I would like to add a motor drive for tracking. My budget is small, and I hope it might be possible to use a "Celestron Logic Drive", or the similar "Celestron R/A Single Axis Motor Drive for the AstroMaster Telescope" which I can buy on Ebay for about $35. Thanks for any comments, or thoughts based on your experience.
Brian Risley
Reged: 09/04/06
Loc: SW Florida
Re: Use a "Celestron Logic Drive" on a Super Polaris new [Re: rdn]
      #5491343 - 10/27/12 08:45 AM
Haven't tried one on an SP, but they do work most EQ-2/EQ-3 mounts. Biggest issue is finding a way to mount it. They have variable speed control and direction reversal, so finding the correct speed/direction is just a matter of experimentation. The other issue is some sort of clutch setup, as the release knob on these units can be in a hard to reach place and without a clutch, you can't use manual slow mo, only release the main lock and then manually position it.
Brian
*skyguy*
Reged: 12/31/08
Loc: Western New York
      #5491686 - 10/27/12 01:00 PM
Welcome to the CloudyNights Forums
The Celestron Logic Drive works well on my Vixen Polaris mount. The "Celestron R/A Single Axis Motor Drive for the AstroMaster Telescope" might fit, but the tracking rate won't be a perfect match since the gear ratios between the two mounts is different.
rdn
journeyman
Reged: 09/21/12
Loc: New Jersey
Re: Use a "Celestron Logic Drive" on a Super Polaris new [Re: *skyguy*]
      #5540473 - 11/26/12 03:03 PM
Thank you both. It sounds like I should proceed with it. I could have used a drive last night looking at the nearly full moon with a 6mm eyepiece, and then at Jupiter. Beautiful views, but galloping targets!
Starhawk
Space Ranger
Reged: 09/16/08
Loc: Tucson, Arizona
      #5542301 - 11/27/12 03:03 PM
A lot of these mounts have 130:1 gear ratios instead of the Vixen 144:1 ratio. I put a CG-4 motor set on my Vixen Polaris by gearing it with a 20:22 ratio to take the 130:1 motors to the 144:1 speed.
-Rich
*skyguy*
Reged: 12/31/08
Re: Use a "Celestron Logic Drive" on a Super Polaris new [Re: Starhawk]
      #5542477 - 11/27/12 04:59 PM
-Rich
Rich,
That's a great solution to the gearing differences between the two mounts. I've heard that you can change the crystal in the handcontroller to get close to the vixen drive rate ... but not precisely. Can you post some additional information and pictures on how you accomplished the drive rate changes? Thanks ...
Geo.
Reged: 10/01/08
Loc: Upstate NY
      #5543023 - 11/27/12 10:53 PM Attachment (27 downloads)
Think you find that the Polaris RA worm whell has 130 teeth. The SP is 144.
Somewhere on CN there is a thread on using the logic drive on a CG-5, which also has a 144 tooth wheel. So the correct speed can be obtained. Maybe you'll want to go to a geared coupling so the drive can be mounted as the SP's drive was there's lots of room there. Drawing below may help.
The logic drive has a really simple control circuit. I cloned one and found it gave a wide range of speed adjustment. My build covers about a square inch after eliminating the power and reversing switches.
By mixing and matching with various DC motors and gear reductions you can probably match any need. The opamp will handle up to 40v, but the switching transistor would have to be upgraded to handle much more current. I have some 3 amp MOSFETs around. I'll have to play with it some more. Blue smoke to follow...
Starhawk
Space Ranger
Reged: 09/16/08
Re: Use a "Celestron Logic Drive" on a Super Polaris new [Re: Geo.]
      #5544471 - 11/28/12 08:08 PM
No, Polaris is 144:1. The Super Polaris is, also, but I don't have one.
-Rich
Starhawk
Space Ranger
Reged: 09/16/08
      #5544695 - 11/28/12 10:22 PM Attachment (34 downloads)
Here is my Polaris with vixen dovetail clamp, heavy duty altitude adjustment, and 2-axis motor drive.
Starhawk
Space Ranger
Reged: 09/16/08
      #5544700 - 11/28/12 10:25 PM Attachment (29 downloads)
Gear drive pix
-Rich
Starhawk
Space Ranger
Reged: 09/16/08
      #5544704 - 11/28/12 10:26 PM Attachment (30 downloads)
Details.
Starhawk
Space Ranger
Reged: 09/16/08
      #5544708 - 11/28/12 10:28 PM Attachment (28 downloads)
More gear detail.
-Rich
21 registered and 45 anonymous users are browsing this forum.
