astrocreep2000
journeyman
Reged: 09/12/12
Loc: AZ
at65edq and 2" diagonals new
      #5475464 - 10/17/12 05:01 PM
Hello to all,
This is my first post so new to forums. I am looking to purchase the AT65EDQ but its description says it may not work with most 2" diagonals. Does anyone have any experience with these and if so what diagonals will work? I am looking to purchase the AT2D diagonal with it and was advised to post here by astronomics as no one was on hand with hands on experience with this question. I want to use for visual and imaging. Additionally would anyone recommend the AT72ED or the AT65EDQ over the other for my needs? I like the case with the 72. I will have the field flattener so the built in one on the 65 although convenient is not a deal breaker. So much to consider. Thank you so much everyone.
Sincerely,
Cam
iceblaze
Reged: 10/15/11
Loc: 33.9° N, 118.4° W Lawndale, ...
Re: at65edq and 2" diagonals new [Re: astrocreep2000]
      #5476371 - 10/18/12 05:07 AM
Hello Cam,
As far as I understand you need to use a SCT diagonal with the AT66. I owned a AT72ED, and it was a nice scope, but I am not an imager so I can't help there. For visual, I would choose the AT72ED or even an 80ED f/7.5 (I think you can get a reducer to bring the f ratio to 6.3 for the ED80)
Here's a decent review of the AT65:
http://www.cloudynights.com/item.php?item_id=2056
Welcome to Cloudy Nights!
-James
SteveG
Reged: 09/27/06
Loc: Seattle, WA
Re: at65edq and 2" diagonals new [Re: iceblaze]
      #5476915 - 10/18/12 12:58 PM
He's talking about this scope - completely different:
https://www.astronomics.com/astro-tech-at65edq-65mm-astrograph-telescope_p18437.aspx
Here's what the site says:
Most 2 star diagonals will not reach infinity focus with the AT65EDQ with either 1.25" or 2" eyepieces, so a 1.25 diagonal is recommended for visual use.
astrocreep2000
journeyman
Reged: 09/12/12
Loc: AZ
Re: at65edq and 2" diagonals new [Re: SteveG]
      #5477950 - 10/18/12 11:07 PM
Thanks for the reply guys. I know that the description recommends 1.25" but also says "most 2 inch will not reach infinity focus." Paul at Astronomics asked Mike and they said no one there had first hand experience with the scope and to ask the forums here hoping someone could confirm the AstroTec 2" 99% diaelectric diagonal will work with the AT65EDQ. I may just go with it but it seems the AT72ED might be better for using visually since I like to do both. I am able to use a 2" diagonal with the AT6RC for visual to great effect. Andromeda, Orion all came into great focus here in Phoenix, AZ. No filters or anything, it's the best little scope I've owned. So I just want to be sure before I buy as I don't want to use a 1.25" if I don't have to. I like my 2" views. I will search the forums for someone that own the AT65EDQ and hopefully PM them for some details. Thank you again gentlemen.
Cam
mak7
Reged: 09/29/07
Loc: light polluted Phoenix AZ
      #5480859 - 10/20/12 07:18 PM
Hi Cam,
I am in Phoenix like you. I own the AT65EDQ and really like the little guy. Little but heavy with all that glass.
I use it for guiding mostly and just starting to image with it.
I have not tried it with a 2" diagonal and just bought a 1.25" with it after reading the specs. I believe there is not enough backfocus for a 2" diagonal, hence the recommendation for using a 1.25 diagonal.
I will see if I can try it with my 2" the next couple days.
Brad
astrocreep2000
journeyman
Reged: 09/12/12
Loc: AZ
Re: at65edq and 2" diagonals new [Re: mak7]
      #5481474 - 10/21/12 06:15 AM
Hi Brad,
Awesome to meet you. Wish we could turn off even just half of all these high pressure sodium street lights and take advantage of our mostly clear skies. The difference in visibility would be astronomical. Thanks for letting me know your thoughts on the scope. I am on the fence still between the AT65 and 72 but want to order Monday to hopefully have by Friday for some overnight camping away from all the lights. If you find out by Monday I will be extremely appreciative of your first hand testing results. It seems the AT72 gets very good praise but I'm really set on those clamshell rings the 65 has for piggybacking my camera when not connecting directly to the At65 of my AT6RC. Not to mention the better glass and built in flattener. Have a great weekend. I look forward to your evaluation details. Thank you.
Cam
mak7
Reged: 09/29/07
      #5482770 - 10/21/12 10:18 PM
Cam,
As you know, the clouds are out. Only checked on the moon.
Here are my findings with a 2" W/O Quartz diagonal.
40mm Pentax XW almost came to focus, not enough in focus
31T5 no way
26T5 on loan, did not check
20T5 Great, easy focus but not much infocus left
17T4 Great as above
14 ES 100* Great, lots of room
11 ES 82* No focus
10 XW Pentax No Focus
8.5 XF Pentax No
7 XW Pentax No
5 XW Pentax No
3.5 XW Pentax Did not bother
So there you have it, a 1.25" diagonal is recommended for a reason. The lightpath on a 2" diagonal is too long to bring most EP's to focus.
I will still vouch for the AT65EDQ as a wonderful little scope. Nice optics and a good flat field for imaging. I also remember the nice view in a 24 Pan when I first recieved the scope and the 1.25" diagonal. That EP is not on the list as I sold it from non use.
Hope this helps your decision process, whatever that might be.
Brad
astrocreep2000
journeyman
Reged: 09/12/12
Loc: AZ
      #5482997 - 10/22/12 02:07 AM
Oh wow. You went above and beyond for me and I am thankful for this very much. :-) I think I will go with the At65 over the At72 and just get the AT 1.25 quartz diagonal. I think the APO optics, field flattener and rings make it worth the price difference. If you have the time could you let me know what adapters and spacing distance you have for imaging with it to bring the imager to focus and connect to your imager?. I will be using a Canon DSLR. I have a t-ring and suppose I will need a prime focus adapter or maybe the Stellarvue standard camera adapter but knowing someone who has actually done it is nice. Thank you again for the time you took to resolve this for me. If you have any questions for me I am happy to help although with your expertise I may have more for you before you have one for me. ;-)
Cam
mak7
Reged: 09/29/07
      #5483535 - 10/22/12 12:10 PM Attachment (19 downloads)
No problem at all Cam,
Just a couple pointers:
My supplied rings held the scope, but were loose enough that the ring could just slightly pivot. I added some strips of 1/8" hobby foam between the ring and scope body, cut from an 8 x 11 sheet I found at Michials Hobby. That put enough tension on the rings to stabilize them from any movement.
Keep in mind that the supplied rings only have center holes, sure wish they were wide enough to have bolt holes on the outer edges. They work OK as is.
I use Losmandy dovetail plate adapters to mount the scope onto another scope. http://www.losmandy.com/hi-rez-images/DVA-1.jpg I also shim between the scope and adapter to raise the scope enough to get at the focus lock knob. I just use heavy ? nylon ? spacer bushings with longer screws. Picture down below, sorry for the focus, quick and dirty just to show you.
When I guide with it, I use a 2" extension with a 1.25" centering ring attached to hold my SSAG and set the focuser at 2.6 to 2.7.
DSLR imaging with a 2" barrel to camera adapter focuses around 5.25 on the focuser hash marks.
My QHY8 OSC comes to focus with a 2" extender, 2" nosepiece threaded to the T threads at about 2.4 on the hash marks.
My scope is from the second run, so I am not sure what they are shipping now, therefore YMMV.
Clear skies,
Brad
Tamiji Homma
Reged: 02/24/07
Loc: California, USA
      #5483976 - 10/22/12 04:41 PM
Hi Cam,
I tried two 2" diagonals known to have short light path on AT65EDQ.
I can come to focus to infinity with all of my 2" eyepieces (including Nagler 31T5) with 2" Zeiss Prism Diagonal.
With Astro Physics MaxBright, N31T5 is border line, just running out of inward focus. N22T4 is about 1mm left to go. I would say 2" eyepiece with Televue Eyepiece spec F column positive number works with Astro Physics MaxBright 2" diagonal.
This is with 2" Zeiss Prism Diagonal, about 6mm to go when it focus to near infinity (a few miles away)
2" Zeiss Prism Diagonal may be hard to find but Astro Physics MaxBright Diagonal shouldn't be difficult to get. If you have particular eyepiece in mind and if I have it, I can test it out for you if you like.
Closeup:
PS: You would need to use longer dovetail to get the combo balanced when you use 2lb+ eyepiece.
Tammy
astrocreep2000
journeyman
Reged: 09/12/12
Loc: AZ
Re: at65edq and 2" diagonals new [Re: Tamiji Homma]
      #5485817 - 10/23/12 06:25 PM
Thank you to everyone for your responses. You have no idea how much I appreciate the feedback. This is the best forum and group of people I've ever met on the internets. Things would be so much easier if you could try these out at the corner store but that is not the case so the feedback is awesome for my considerations. I believe I will go with the AT72ED after all due to using for visual mostly as I will not only save money but the AT filed flatterner can be used on it and the AT6RC I already have as well I will not need to invest in new eyepieces. I may one day do so but for now as a beginner with taking APhotos I think this will be the right decision. I just wish the AT72 came in black and white tube option like the AT65. It would match the AT6RC perfect but all black will do. Thank you again to all for really going out of your way to help me. This community is the best, I'm glad I joined.
Regard,
Cam =)
astrocreep2000
journeyman
Reged: 09/12/12
Loc: AZ
Re: at65edq and 2" diagonals [Re: astrocreep2000]
      #5496817 - 10/30/12 08:21 PM Attachment (23 downloads)
Hi All,
So at the last moment I went with the AT65. It is great visually. Saw Orion Neb on Saturday night. Pinpoint stars so nice. Have it aligned with myAT6RC and finder. Using it with an AstroTech 1.25 Quartz Dielectric and a Celestron zoom eyepiece I already had for quick views at diff magnifications. So here's a shot of the gang (sorry for the low res I had to seriously downsize it for upload).
Cam
0 registered and 15 anonymous users are browsing this forum.
Moderator:  zjc26138, tecmage, rflinn68
