kbastro
Reged: 04/20/08
Loc: Running from Clouds
Best grease possible for a mount
      #5497039 - 10/30/12 10:51 PM
any recommendations on a good grease for the re-do of greasing a mount?
I am looking for something that can handle +30C/86F to -10C/14F?
what is better lithium (white) or teflon based like duralube?
Kev b
Midnight Dan
Reged: 01/23/08
Re: Best grease possible for a mount new [Re: kbastro]
      #5497049 - 10/30/12 10:57 PM
Superlube.
-Dan
m2k
Reged: 12/10/06
Loc: Massachusetts, USA
Re: Best grease possible for a mount new [Re: Midnight Dan]
      #5497050 - 10/30/12 10:59 PM
Superlube.
Yep...
FaronD
Reged: 03/25/10
Loc: Richmond Hill, Ontario
      #5497067 - 10/30/12 11:20 PM
Another Superlube
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Best grease possible for a mount new [Re: FaronD]
      #5497114 - 10/31/12 12:13 AM
I used superlube on the sliding (plane) bearings on my AP600 and it was too sticky.
AP and Bisque both recommend lubri-plate 105. since I couldn't find that i used white lithium grease. which is not recommended, but it certainly performs better than superlube for me.
the ball bearings on my CGEM though i use superlube.
Phillip Easton
Reged: 12/24/10
Loc: DFW
Re: Best grease possible for a mount new [Re: orlyandico]
      #5497417 - 10/31/12 08:32 AM
I used SuperLube on my iEQ45 and didn't see any problems. I reduced my PE so assuming it at least didn't hinder things Rated temperature range from -40F to +450F.
Wow, looked up lubri-plate on Amazon. Not cheap, worth the price?
http://www.amazon.com/Lubriplate-C105-03492-293-L0034-092...
Edited by Phillip Easton (10/31/12 08:33 AM)
Astronewb
Reged: 09/19/11
Loc: Connecticut
Re: Best grease possible for a mount new [Re: Phillip Easton]
      #5497426 - 10/31/12 08:42 AM
Er..Phil...that's the price for 12 tubes. So, about 5-6 bucks a tube?
Paul
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Best grease possible for a mount new [Re: Astronewb]
      #5497430 - 10/31/12 08:47 AM
all of the China mounts I've seen use ball bearings on both of the axes.
while my AP600 and my old Vixen GP both used plane bearings, which don't have balls or rollers. I guess a less charitable word for these would be "bushings" or "sleeve bearings."
i suspect these sleeve-type bearings aren't too amenable to thicker lubricants, hence my lack of success with superlube.
johne
Reged: 11/10/06
Loc: Prescott, AZ.
      #5497433 - 10/31/12 08:50 AM
I use Lubriplate No.105 for my Paramount ME.
Phillip Easton
Reged: 12/24/10
Loc: DFW
      #5497514 - 10/31/12 09:59 AM
Paul
LOL Thanks Paul, guess I shouldn't be so quick to reply.
Cheers!
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #5497566 - 10/31/12 10:47 AM
SuperLube.
TxStars
Reged: 10/01/05
Loc: Lost In Space
      #5497614 - 10/31/12 11:23 AM
For ball bearings "Superlube"
For Bushings (metal to metal surfaces sliding against each other)"Lubriplate No.105"
Bart
Reged: 05/28/06
Loc: Somewhere near Charlottesville...
      #5497635 - 10/31/12 11:42 AM
Superlube.
-Dan
Midnight Dan
Reged: 01/23/08
Re: Best grease possible for a mount new [Re: TxStars]
      #5497789 - 10/31/12 01:35 PM
What about for gear surfaces? Lubriplate 105 is marketed as an "engine assembly" lubricant, and they sell other lubricants that are targeted at gears. Would one of them be better?
-Dan
kbastro
Reged: 04/20/08
      #5498288 - 10/31/12 07:08 PM
it seems that superlube is a good choice,,,, the part I was talking about re-lubing is the worm and gear assembly,,, not the whole mount!!
Kevin b
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
      #5498336 - 10/31/12 07:36 PM
I use SuperLube for HyperTuning and have no problems with it at all, hot or cold, wet or dry. But it must be used sparingly. A very thin coat is all that is needed. Like most grease, too much is not a good thing, especially for slow moving parts like these. It's not an automobile, so you don't grease it like one.
Locally, Superlube is often available at Harbor Frieght and sometimes at Ace Hardware. Otherwise it is easily available on line. A 3 oz. tube is enough for many mounts. You can actually get by with a 1/2 oz. tube just fine.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Best grease possible for a mount new [Re: EFT]
      #5498380 - 10/31/12 08:07 PM
Oh and superlube is food safe. Smells pleasant too. I expect that means you can chomp on it without dying.
TxStars
Reged: 10/01/05
Loc: Lost In Space
      #5498478 - 10/31/12 09:16 PM
-Dan
The Lubriplate No.105 works good for gears that are low speed (under 100 rpm) low heat (under 200deg).
Binojunky
Reged: 12/25/10
      #5498508 - 10/31/12 09:42 PM
Probably going to get flamed for this but their is more rubbish talked about mount grease than just about any other thing,I worked as an industrial mechanic for years and also on cars, aircraft etc, any good quality light grease will be fine, the secret is to use it sparingly not slap it about willy nilly and stuff the whole tube into the mount then wonder why its running all over the place in hotter weather.One place I worked for had a large number of pick and place assembly robots running at high speed, using a steel worm and bronze worm wheel, they got checked maybe once a year and a dab of grease on the worm was enough to keep them in good shape and running sweet, again use sparingly, grease everywhere just attracts dirt and dust,DA.
johntrob
Reged: 03/14/11
Loc: Georgia, USA
Re: Best grease possible for a mount new [Re: Binojunky]
      #5498569 - 10/31/12 10:14 PM
Different opionions and experiences is what makes this forum so good. Tech info for Astronomy based on real world experience.
24 registered and 40 anonymous users are browsing this forum.
