MHamburg
Reged: 06/21/06
Loc: Brooklyn, NY/Berkshires, MA
CGEM Taper Bearing
      #5497473 - 10/31/12 09:30 AM
I am forced to replace the DEC housing taper bearing on my CGEM. (That's the bearing at the rear of the DEC housing through which the counterweight bar passes.) I am waiting for a response from Ed Thomas who has been very supportive, but thought I might check for sources elsewhere as well. Does anyone know the exact specs of this bearing and any source where it is available? Thanks for all info.
Michael
RTLR 12
Reged: 12/04/08
Re: CGEM Taper Bearing new [Re: MHamburg]
      #5497516 - 10/31/12 10:00 AM
It's a standard bearing available at any auto parts or bearing house. I don't remember the number, but you should not have a problem finding one. The number of the bearing is marked on it.You will need to replace both the bearing and the race as a set.
Stan
nemo129
Reged: 01/03/10
Loc: WMass
      #5497519 - 10/31/12 10:04 AM
Michael,
You could try here. You will need to measure the old bearing to make sure you get the right one. I purchased new main axis bearings from these guys when I did my hypertune on my CGEM.
MHamburg
Reged: 06/21/06
Re: CGEM Taper Bearing new [Re: nemo129]
      #5497808 - 10/31/12 01:48 PM
Hi Stan and Kirk,
Ed sent me to the same website and I ordered the deluxe version (Nachi bearing). Thanks for the help.
Michael
RTLR 12
Reged: 12/04/08
      #5497899 - 10/31/12 02:55 PM
Good deal Michael. I have been dealing with VBX for over 40 years. Good people and products. They are just a few blocks away from my shop in Orange, Ca.
Stan
MHamburg
Reged: 06/21/06
Re: CGEM Taper Bearing new [Re: RTLR 12]
      #5499105 - 11/01/12 09:53 AM
Stan,
By the race, do you mean the circular piece that seems to be attached in the bore of the mount? If so, it looks like it will take some prodding to knock it loose. Thanks again for the info.
Michael
RTLR 12
Reged: 12/04/08
      #5499168 - 11/01/12 10:31 AM
Yes. The race is a press fit. You should always replace brgs in sets. Although made to specific tolerances there is some variance from mfg to mfg. In the application for use on the CGEM the bearing is extreamly over specified and if you find it beyond your abilities, it my not matter if you change the race or not.
Stan
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #5499239 - 11/01/12 11:20 AM
Tapping the race around the edge circumference from the inside with a long dowel or metal rod (inserted from the opposite side of the housing) will usually remove it. Just take your time as it needs to slide out straight.
MHamburg
Reged: 06/21/06
Re: CGEM Taper Bearing new [Re: EFT]
      #5499610 - 11/01/12 04:47 PM
Thanks, Stan and Ed!
Michael
24 registered and 32 anonymous users are browsing this forum.
