FaronD
Reged: 03/25/10
Loc: Richmond Hill, Ontario
New Mach 1 Mount new
      #5497171 - 10/31/12 12:49 AM Attachment (117 downloads)
Well new to me anyway, it certainly looks new. I've decided to purchase a new imaging mount. It was a toss up between the Mach 1 and a new G11 with G2. Obviously I chose the Mach 1. It looks like Sandi as an affinity for my mount, sorry everyone; If I were to purchase the G11, I was going to add Cassidy weights and an Ovision worm plus a few other extras. Basically, I was trying to build a Mach 1. Add these items up and it starts to approach the Mach 1 price. I sent a few messages to Losmandy, I wasn't too impressed with the response, or lack of. I even called a few times but didn't get anyone?? Just go ahead and email or call Astro-Physics, they have amazing customer service, and so they should.
The Mach 1 and Eagle is a gorgeous combo. The build quality is simply superb. I did have an hour or so to test it on Fri before the clouds rolled in. I'm very impressed with the stability of the Eagle Pier, it's rock solid. It took me a while to familiarize myself with the HC, it's certainly different than my EQ6. I have to practice drift aligning, I don't have a clue about it. I told myself if I'm going to spend this much money on a mount, I will only drift align for imaging. Besides, AP has a few short cuts to speed up the process however, I will need a finder with crosshairs to take advantage of this.
I do have my first question if an owner would care to answer? When going through the polar alignment procedure, how do I change the movement speed without having to back out of the process? I know number 6 is the button but, once you choose a star and start the process, I can't change the speed. I need to really slow it down to center the star properly in the reticle and vice versa if I'm too far off. Any tips here?
I'm really happy with my purchase and can't wait to check it out with my cam on it.
Here's a picture.
Faron
blueman
Vendor Blue Sky Accessories
Reged: 07/20/07
Loc: California
Re: New Mach 1 Mount new [Re: FaronD]
      #5497185 - 10/31/12 01:03 AM
Beautiful!
Blueman
D. Perry
Reged: 09/28/07
Loc: Southern California, USA
Re: New Mach 1 Mount new [Re: blueman]
      #5497226 - 10/31/12 02:16 AM
Looks great. Congratulations! You made the right choice. I *believe* you can change speeds by using the left and right arrow keys.
Best,
Starhawk
Reged: 09/16/08
Loc: Tucson, Arizona
Re: New Mach 1 Mount new [Re: D. Perry]
      #5497551 - 10/31/12 10:31 AM
Read all of the manuals. It doesn't work like other mounts. You'll see when you get it going.
-Rich
RAKing
Reged: 12/28/07
Loc: West of the D.C. Nebula
      #5497905 - 10/31/12 03:00 PM
Congrats on the new Mach1. There is no finer mount available in its class and I'm sure you will enjoy the heck out of it after you work your way through the manual.
I only do visual now, so I conveniently forgot all that stuff about drift alignment a few years ago. I can do a simple polar align through the mount and be happy all night.
I also suggest you not be so hard on Losmandy. They are a much smaller operation and astro mounts are a sideline to their 'real' business. I have always been able to get through, unless they are on lunch break, and they have always been very helpful to me.
But as you noticed, no one compares to A-P when it comes to customer service.
Ron
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: New Mach 1 Mount new [Re: RAKing]
      #5497937 - 10/31/12 03:17 PM
"I sent a few messages to Losmandy, I wasn't too impressed with the response, or lack of. I even called a few times but didn't get anyone??"
I also sent Losmandy some questions about the G11 last week and never got a response. Wonder what is happening there.
rockethead26
Reged: 10/21/09
Loc: Indiana, USA
Re: New Mach 1 Mount new [Re: Lane]
      #5498055 - 10/31/12 04:33 PM
Beautiful mount, Faron. Maybe some more pics besides just the head-on shot
pfile
Reged: 06/14/09
Re: New Mach 1 Mount new [Re: rockethead26]
      #5498239 - 10/31/12 06:43 PM
i always had better luck calling losmandy than with email. however, scott did answer at least one of my emails.
FaronD
Reged: 03/25/10
      #5499906 - 11/01/12 08:53 PM
Hi Jim, I will take a few shots of the head and post it for you.
Guys, I have two nine pound weights and a single six pound. I'm slightly scope heavy with my beefy TOA130 and accessories. I've read that the Mach 1 has the same motors as the larger mounts which means they are very strong. I'm sure a slight off balance won't be an issue for the motors. Will this have a detrimental effect on tracking? Again, this is an imaging mount.
Faron
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #5500014 - 11/01/12 09:55 PM
If you're imaging, work to get a good balance.
andysea
Reged: 09/03/10
Loc: Seattle, WA
      #5500238 - 11/02/12 12:25 AM
Faron
Good question! I would post on the AP GTO group. I'm sure a lot of AP users will chime in...According to AP perfect balance isn't required. I would however try to get as close as possible.
andysea
Reged: 09/03/10
Loc: Seattle, WA
      #5500319 - 11/02/12 01:27 AM
Hi Again Faron.
I think that for the TOA we will need three 9lb weights. Incidentally I have discovered that the 11lb Meade LX80 weights work just fine on the Mach1. They are obviously cheaper but also much lower quality. I don't know if that's relevant but SS in not magnetic so it won't interfere with the built in compass of the Mach1. The meade weights do.
They also have what appears to be a SS Rod that pushes against the counterweight shaft so I replaced is with a bronze one that is non marring.
RAKing
Reged: 12/28/07
      #5500686 - 11/02/12 10:44 AM
My TOA-130 needed three nine pound weights, shifted up 1.5 inches from the bottom.
The Mach1 is not too sensitive off-balance, but your setup will also depend on your camera and guiding setups and you are already a couple pounds off.
I would definitely grab another nine pound weight.
Ron
FaronD
Reged: 03/25/10
      #5501656 - 11/02/12 10:07 PM
Thanks guys, I will order another weight. Andy, I can't put a Meade weight on there...
andysea
Reged: 09/03/10
Loc: Seattle, WA
      #5501772 - 11/02/12 11:13 PM
Lol yeah most people wouldn't! I'm just practical:) Sometimes to increase the counterweights on my NJP I use 5lb gym plates!! Works like a charm
RAKing
Reged: 12/28/07
Re: New Mach 1 Mount [Re: andysea]
      #5502061 - 11/03/12 08:32 AM
I agree. I also sandwiched Losmandy weights on my thin Mach1 shaft while I was waiting for the "proper" gear to arrive. It's okay to improvise.
Ron
5 registered and 20 anonymous users are browsing this forum.
