Freddy WILLEMS
Reged: 11/13/05
Loc: Hawaii, Honolulu
JUPITER - November 02, 2012 - Variable seeing
      #5506219 - 11/06/12 12:42 AM Attachment (58 downloads)
Again a bit better seeing today,
Some outbreak visible and two bright beacons following the GRS.
The dark spot above the GRS seems to have an inner core with a darker ring around.
Freddy
Freddy WILLEMS
Reged: 11/13/05
Re: JUPITER - November 02, 2012 - Variable seeing new [Re: Freddy WILLEMS]
      #5506220 - 11/06/12 12:42 AM Attachment (26 downloads)
Set 2
Freddy WILLEMS
Reged: 11/13/05
      #5506221 - 11/06/12 12:43 AM Attachment (22 downloads)
Set 3
Freddy WILLEMS
Reged: 11/13/05
      #5506222 - 11/06/12 12:44 AM Attachment (15 downloads)
Set 4
Freddy WILLEMS
Reged: 11/13/05
      #5506224 - 11/06/12 12:44 AM Attachment (11 downloads)
Set 5
Freddy WILLEMS
Reged: 11/13/05
      #5506225 - 11/06/12 12:44 AM Attachment (14 downloads)
IR Sets
Freddy WILLEMS
Reged: 11/13/05
      #5506227 - 11/06/12 12:45 AM Attachment (19 downloads)
Set 6
Freddy WILLEMS
Reged: 11/13/05
      #5506228 - 11/06/12 12:45 AM Attachment (14 downloads)
Set 7
Freddy WILLEMS
Reged: 11/13/05
      #5506230 - 11/06/12 12:46 AM Attachment (14 downloads)
Set 8 Green images
cheapersleeper
Reged: 01/22/10
Loc: Sachse TX
      #5506284 - 11/06/12 02:20 AM
They sure do look varaiable. Seems that seeing was changing by a lot. Thanks for posting.
Brad
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
      #5506338 - 11/06/12 05:08 AM
Superb compilation Freddy! Those closeup cutouts are great. When you had good seeing is was really good. Some of the best IR and color channels I've seen. Well done!
Glenn
Rankinstudio
Reged: 04/05/08
Loc: Southern UT
Re: JUPITER - November 02, 2012 - Variable seeing new [Re: DesertRat]
      #5506498 - 11/06/12 08:57 AM
Nice set of images!
alacane
Reged: 01/14/10
Loc: Madison, AL / Huntsville, AL
Re: JUPITER - November 02, 2012 - Variable seeing new [Re: Rankinstudio]
      #5506841 - 11/06/12 12:47 PM
Wow! nice...I just moved up to a DMK21AU618. I'll have to get a IR 742 for my wheel.
mikotoy
Reged: 06/20/12
Re: JUPITER - November 02, 2012 - Variable seeing new [Re: alacane]
      #5507264 - 11/06/12 05:23 PM
I am incredibly envious and thank you for the inspiration to keep at it.
Amazing images and like alacane, I'm going to pick of an IR 742 for my wheel as well.
Freddy WILLEMS
Reged: 11/13/05
Re: JUPITER - November 02, 2012 - Variable seeing new [Re: mikotoy]
      #5507329 - 11/06/12 06:09 PM
It's becoming more and more a full time job, processing it all, good and bad, every single capture hold a lot of valuable information for the researchers. So that's why I keep up imaging...
mikotoy
Reged: 06/20/12
      #5507455 - 11/06/12 07:41 PM
I have a seemingly stupid question captain obvious question (total newbie here). When you image in RRGB are you performing two passes with the R wavelength with the intent of increasing the amount of detail visible in the final image?
I'm also presuming the same with the IR sequence. It is not placed in front of the visible wavelengths to aid in stabilization of the image, but in fact as a part of the sequence for detail acquisition.
Freddy WILLEMS
Reged: 11/13/05
      #5507533 - 11/06/12 08:58 PM
No... mot that complicated, you just use winjupos and ad the extra R or IR (Image) to the RGB group, you can combine 4 channels in winjupos ! Just plain easy combining... no extra ..
I just like to play with different filter combinations and combining in Winjupos..
alacane
Reged: 01/14/10
      #5508153 - 11/07/12 10:25 AM
Thanks Freddy, I just assumed ....I'll have to try Winjupos to see the difference between that and PS.
How long are you imaging each channel? Do you use the derotate feature in winjupos?
Edited by alacane (11/07/12 12:48 PM)
Freddy WILLEMS
Reged: 11/13/05
      #5508350 - 11/07/12 01:16 PM
Around 90s - 120s / channel and Yes derotated in WinJupos
Love that program !
mikotoy
Reged: 06/20/12
      #5508641 - 11/07/12 04:12 PM
I unfortunately have not had much luck with WinJupos, but I do attribute that to my inexperience with it and seeing conditions in my area.
It is very easy to use and its capabilities are quite powerful.
One question though: Do you perform any processing prior to combination of derotated wavelengths in WinJupos?
4 registered and 16 anonymous users are browsing this forum.
Moderator:  Boot, bilgebay
