DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
Jupiter & Io from Arizona - 30Oct 12 - good seeing new
      #5500105 - 11/01/12 10:46 PM Attachment (107 downloads)
Io was transiting Jupiter this night. The best seeing so far this season, I'd give it a solid 7.5/10. The definition was good enough I had to align for the planet and the moon & shadow separately and then merge the two.
This is a north up view resized up to 1.25X.
Captured with a Flea3 using FireCapture 2.1.
Comments or questions welcome. Thanks for looking!
Glenn
Az Frank
Reged: 10/18/08
Loc: Tucson Arizona
Re: Jupiter & Io from Arizona - 30Oct 12 - good seeing new [Re: DesertRat]
      #5500197 - 11/01/12 11:53 PM
No doubt Glenn one of your best! What great detail!Great work on processing all the key details! I guess I missed a potencial great seeing opportunity.
Kecktastic
Reged: 01/16/10
Loc: Broken Hill NSW Australia
      #5500210 - 11/02/12 12:05 AM
Another super image Glenn, a ripper in every respect.
Regards
Trevor
ToxMan
Reged: 01/23/11
Loc: Tucson, Arizona, USA
Re: Jupiter & Io from Arizona - 30Oct 12 - good seeing new [Re: Kecktastic]
      #5500237 - 11/02/12 12:24 AM
The NEB looks a lot like the GRS wake. Lots of activity to look over. Simply gorgeous.
claytonbigwood
Reged: 11/06/08
Loc: Adelaide, South Australia
Re: Jupiter & Io from Arizona - 30Oct 12 - good seeing new [Re: ToxMan]
      #5500392 - 11/02/12 04:44 AM
A stunning shot Glenn
Mike Phillips
Reged: 02/21/06
Loc: Swift Creek, NC - 35.682 N, 78...
Re: Jupiter & Io from Arizona - 30Oct 12 - good seeing new [Re: claytonbigwood]
      #5500613 - 11/02/12 09:47 AM
Wonderfully balanced image Glenn!
Sunspot
Reged: 03/15/05
Loc: Surprise, AZ
      #5500658 - 11/02/12 10:20 AM
Excellent in every way.
Paul
DesertRat
Reged: 06/18/06
Re: Jupiter & Io from Arizona - 30Oct 12 - good seeing new [Re: Sunspot]
      #5502694 - 11/03/12 05:36 PM Attachment (20 downloads)
Thanks guys! Much appreciated. I must hasten to add that at least 95% of the result is due to a higher power!
Here is a later image in IR. Io is really bright at the longer wavelengths posing a problem in processing both planet and moon without Io saturating. I think this is the best compromise.
Thanks for looking!
Glenn
BKBrown
Reged: 08/23/09
Loc: Northern Virginia, USA
      #5502727 - 11/03/12 05:52 PM
Terrific image Glenn, one of the better ones so far this apparition I think. Just loads of great detail there...
Clear Skies,
Brian
lcd1080
Reged: 06/03/10
Loc: Maryland, USA
Re: Jupiter & Io from Arizona - 30Oct 12 - good seeing new [Re: BKBrown]
      #5502751 - 11/03/12 06:09 PM
Glenn, when you said that at least 95% of your result was due to a higher power I quickly glanced up at the image caption to see if you boosted the focal ratio with a higher power barlow; then I thought, "oh he means THAT higher power" I'm sure you're going to want to print this one for framing; it's truly superb.
Pete
Sunspot
Reged: 03/15/05
Loc: Surprise, AZ
      #5502774 - 11/03/12 06:24 PM
Glenn,
Truly amazing and a processing technique I wish I knew how to do.
Paul
DesertRat
Reged: 06/18/06
      #5502796 - 11/03/12 06:43 PM Attachment (26 downloads)
Thanks guys!
Pete, yes that is what I meant, and thanks for making me laugh! Of course the 95% figure is far too conservative!
Paul, I played with wavelets a lot to get this. I unchecked level 1 as shown below. Why it helped to give definition across Io without saturating the heck out of it I don't know. Normally I play with the Sharpen control (in addition to denoise) usually turning them down to something like .060, 080 etc. And when I resize up to 2.5X (Jupiter) or 4X (Mars) I start by setting the initial layer to 2.
For each outing I end up with a slightly different scheme in wavelets. Hence my wavelet directory has many entries - so appending the date, filter and magnification is useful for the next time to give a closer starting point.
Glenn
DesertRat
Reged: 06/18/06
      #5504539 - 11/04/12 08:46 PM Attachment (25 downloads)
Seeing was still pretty good at the time of this RGB image.
This is my first attempt at WinJupos derotation of RGB images. I only used 3 images, but the definition seems to be improved across the face of the planet. After composing in WinJupos, I still found that I had to do a minor color alignment. Is that the experience of any others out there?
Thanks for looking!
Glenn
oldstargazer
Reged: 08/03/11
Loc: Western Oklahoma
      #5504617 - 11/04/12 09:34 PM
That is such a great image! I could be wrong and probably am but it looks like you got two moons on the planet. You can kind of see it on this last image and even better on the first with what looks like its shadow also on the planet. In both shots it is almost directly above the bigger one on the other dark band.
Space Cowboy
Reged: 05/30/10
Loc: Cheshire, UK
Re: Jupiter & Io from Arizona - 30Oct 12 - good seeing new [Re: oldstargazer]
      #5507898 - 11/07/12 04:18 AM
Fantastic resolution Glenn!
Eddgie
Reged: 02/01/06
      #5508083 - 11/07/12 09:25 AM
This last image is one of your very best! You are getting to be a top notch planetary imager. And you don't even live on an island!
martus
Reged: 01/03/11
Loc: Czech Republic
Re: Jupiter & Io from Arizona - 30Oct 12 - good seeing new [Re: Eddgie]
      #5508201 - 11/07/12 11:15 AM
Glenn beautiful images !
regards,
martus
rik ter horst
Reged: 11/01/10
Loc: Ewer, the Netherlands
Re: Jupiter & Io from Arizona - 30Oct 12 - good seeing new [Re: martus]
      #5508627 - 11/07/12 04:04 PM
This last one is just awesome! I love the way you process your images! Not too much, just enough and smooth.... Great!Cheers,
Rik
Daniel Chang
Reged: 07/05/06
Loc: Hong Kong
Re: Jupiter & Io from Arizona - 30Oct 12 - good seeing new [Re: rik ter horst]
      #5508900 - 11/07/12 07:23 PM
Fantastic !
DesertRat
Reged: 06/18/06
Re: Jupiter & Io from Arizona - 30Oct 12 - good seeing [Re: Daniel Chang]
      #5508973 - 11/07/12 08:18 PM
Thanks everyone for your generous comments.
Ralph - only one moon shown here. But Jupiter is a stormy planet and spots break out all the time.
Glenn
5 registered and 11 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
