droid
rocketman
Reged: 08/29/04
Loc: Conneaut, Ohio
sky view pro trouble new
      #5510356 - 11/08/12 06:11 PM
Some stupid questions if I might. I put a 4 inch f/8 refractor on my Sky View Pro last night, while trying to sight in Jupiter , I used the slo-mo cables, get it in the center let go of the slo-mo cables, an watch it spin back wards and gone.
My first thought was balance, so I rebalanced everything, andthe same thing.
Is there a way to tighten this mount up enough to stay put when you let go of the cables???
Edited by droid (11/10/12 08:12 AM)
beatlejuice
Reged: 04/05/11
Loc: Hamilton, ON,Canada
Re: sky view pro trouble new [Re: droid]
      #5510406 - 11/08/12 07:00 PM
If it is slipping after you tighten both clutches then there is definitely something amiss.
Eric
droid
rocketman
Reged: 08/29/04
Loc: Conneaut, Ohio
      #5512814 - 11/10/12 08:11 AM
wow , no one here has taken apart a sky view pro?
Reged: 07/06/07
      #5512873 - 11/10/12 09:38 AM
Taking this simple mount apart is not the place to start. The place to start is with, as Eric says, CHECKING YOUR CLUTCHES.
EXT64
Reged: 12/15/07
Loc: Virginia Tech, VA, USA
Re: sky view pro trouble new [Re: rmollise]
      #5512957 - 11/10/12 10:47 AM
Which axis is slipping (RA or DEC)?
droid
rocketman
Reged: 08/29/04
Loc: Conneaut, Ohio
Re: sky view pro trouble new [Re: EXT64]
      #5513464 - 11/10/12 05:11 PM
The declination axis, even just rebalanced it dead perfect, tweaked the slow motion cable, and watched it spring back.
EXT64
Reged: 12/15/07
      #5513608 - 11/10/12 07:52 PM
Wow, the declination axis on mine is pretty stiff when loaded up.
Are you the first owner of this mount or did you acquire it used. From the factory I'm not sure I've ever heard people have problems with it being too loose (usually they think they are too sticky).
droid
rocketman
Reged: 08/29/04
Loc: Conneaut, Ohio
      #5513689 - 11/10/12 08:55 PM
I'm the second owner, and it actually springs back, though there is one spot where it will drop.
tweek the cable it moves, when you let it go it springs back.
EXT64
Reged: 12/15/07
Re: sky view pro trouble [Re: droid]
      #5513797 - 11/10/12 10:58 PM
Well, I am pretty baffled. When I got my SVP (used) I did think about doing some work on it; however, it turned out it didn't need it so I didn't. Still I learned a bit about the inner mechanics. This site ( http://www.andysshotglass.com/SVPmods.html ) might be of some help.
16 registered and 28 anonymous users are browsing this forum.
