gillmj24
Reged: 12/06/05
Loc: PA
new space heater idea
      #5515509 - 11/12/12 04:56 AM
I'm more concerned with humidity than temperature. My mount was dripping wet inside my dome this foggy morning. Has anyone used one of these spot heaters? I think if I pointed up to my black lined dome that would re-radiate heat downward and more evenly, I hope enough to prevent things from getting soaked this winter.
http://www.heater-home.com/product/ms-09.aspx
roscoe
curmudgeon
Reged: 02/04/09
Loc: NW Mass, inches from VT
Re: new space heater idea new [Re: gillmj24]
      #5515578 - 11/12/12 07:49 AM
Yeah, they'll work. That design has been around for many many years, they're reliable. It is a radiant heater, in that it is somewhat like a flashlight, instead of light, it projects a beam of heat toward an object. It will warm that object, and somewhat the air in general, but not warm a space as well as the little cube heaters that have fans in them to circulate air past heated elements. Another option for warming a space is electric heaters that look like old steam radiators, they heat the air convectively without fans, so will heat a space silently and breeze-less-ly. They all cost about a dime an hour to operate.....
Russ
gillmj24
Reged: 12/06/05
Loc: PA
Re: new space heater idea new [Re: roscoe]
      #5515616 - 11/12/12 08:40 AM
What is better to keep your mount from dripping? I'm even starting to get some rust in my expensive stainless steel counterweights
roscoe
curmudgeon
Reged: 02/04/09
      #5515665 - 11/12/12 09:37 AM
How about a cover over the mount with a smaller heater - perhaps even a light bulb in some sort of fixture to prevent it touching the cover - under the cover, so to keep the scope and mount warmer/above the dew point?
R
gillmj24
Reged: 12/06/05
Loc: PA
      #5515750 - 11/12/12 10:44 AM
I brought everything irreplaceable inside before sandy and just yesterday got around to outright stuff back. I left some CW out and they were dripping as was the ATS portable pier. The pier is painted and wont rust but I left the CWs out in the humidity for two weeks. I might need a bigger cover I might just use an old blanket for now. I will try a small <800W heater first that is less likely to start a fire since it will already have a thermostat.
Happy Birthday csa/montanaModerator
Den Mama
Reged: 05/14/05
Loc: montana
      #5515792 - 11/12/12 11:10 AM
How about this, for under a cover?
Link
Along with a TeleGizmos cover.
jaddbd
Reged: 05/18/05
Loc: Woodbine, MD
Re: new space heater idea new [Re: csa/montana]
      #5516005 - 11/12/12 01:24 PM Attachment (27 downloads)
I have a couple of those dry rods and they work well. I actually put 1 inside my parked ota (the baffles hold it in place) after a night with a tee-shirt cover of imaging and there is never any dew on the mirror in the morning even when the outside of the scope is covered in dew. Putting a rod (I use 2 under cover) under your mount cover works well night after night of non-use (in a shed), but after a night of exposure to the ellements, they won't "dry" your equipment.
John D
maryland
gillmj24
Reged: 12/06/05
Loc: PA
      #5516032 - 11/12/12 01:38 PM
Thanks I will try it.
JustinO
Reged: 10/08/12
      #5516037 - 11/12/12 01:43 PM
Go to this web site, put your zip code in.
When it refreshes for your zip, click on the "hourly weather graph" which is down and to the right.
http://forecast.weather.gov/MapClick.php?lat=39.0558235&lon=-95.689018499...
It has a "dewpoint" graph. As long as your mount is warmer than the dewpoint, you should be okay. If you have a source of moisture in your observatory, you might have a higher local dewpoint -- if you have bare masonry or concrete, you should seal it.
I put a low wattage light bulb in equipment I'm worried about. It's just enough to keep the temperature of the equipment above the dewpoint.
gillmj24
Reged: 12/06/05
Loc: PA
Re: new space heater idea new [Re: JustinO]
      #5516184 - 11/12/12 03:13 PM
My floor is open since I am on a raised wood deck next to my house. Far from ideal but it was that or no Obs at all.
Tel
Reged: 03/31/06
Loc: Wallingford England
      #5517410 - 11/13/12 08:19 AM Attachment (20 downloads)
Under predominantly damp, UK weather conditions, I can keep humidty levels to a minimum and thus my 'scopes and kit dry in my ca.8.5 cubic metre, (ca. 290 cubic feet), dome by making use of a £26 (ca. $40) 1000 Watt fan heater timed to switch itself on for quarter of an hour every hour from between 7:00pm and 8:00am.
My only slight problem is that although the concrete base of the dome is covered by both a damp course menbrane plus an interlocking polyurethane mat flooring, some condensate still builds above the membrane, presumable as a result of damp air contacting the cold concrete area as a whole.
Until now I have had the heater situated about two feet off the ground but aim to set it at floor level to see whether this effects a cure.
Best regards,
Tel
MRNUTTY
Reged: 11/22/11
Loc: Mendon, MA
      #5518602 - 11/13/12 07:58 PM
Russ
This is what I use when I need a space heater. They're light, portable, and don't give off any smell. This is what I was going to move out to the observatory.
gillmj24
Reged: 12/06/05
Loc: PA
Re: new space heater idea new [Re: MRNUTTY]
      #5522365 - 11/16/12 07:40 AM
My dri-rod arrived last night and I also bought a vornado personal heater for 30 dollars and a mechanical appliance timer that I set to cycle the power every half hour. Unlike most heaters whose low and high are 750 and 1500 Watts, the personal heater (at bed bath and beyond not the big home improvement Mega stores...) is 375 and 750. It does not have a thermostat. My thermometer this morning says 40F inside the dome (it's 35 outside) and humidity according to my weather station is at 70% instead of going up to 90% like it did a few mornings ago. It was reporting 75% humidity last night before putting the heater in.
The dri rod says it gets to 125F. The instructions weren't right either I had to reverse the wires to get it working. I didnt use it last night since it took a while to get it working. Not sure why they cant just wire the olug and test it for you but ok. I wouldn't put it in my scope at that temperature so I'll try to put it inside or under the cover somehow.
I was using the low setting and my stuff is dry. So far so good. Might need the 750W setting if it gets really cold, but when it's 20 here it usually isn't as humid as when it's just above freezing like it is now.
Edited by gillmj24 (11/16/12 07:52 AM)
Geo.
Reged: 10/01/08
Loc: Upstate NY
      #5540012 - 11/26/12 10:00 AM Attachment (9 downloads)
Don't discount how much heat an incandesant light bulb can put out. We had a few Farmall tractors that had magneto ignitions. The bakelight would absorb moisture and short the spark. Dad would secure a 100 watt bulb next to the mag and that would keep it dry, even at winter temperatures.
wolfman_4_ever
Reged: 07/15/11
Loc: El Segundo, Ca, So. Cal
Re: new space heater idea new [Re: Geo.]
      #5544298 - 11/28/12 05:48 PM
Your in an observatory... enclosed space.. you have humiditiy.. use a dehumidifier..
light bulbs and dri rods.. jebus...
and where do people get the idea that heat will get rid of moisture in the air that is trapped inside? Is it suppose to evaporate? Evaporate to the top of your OTA and dome..
All you are doing is preventing dew by increasing the temperature. not remedying the situation by removing the water in the air..
KISS.. Keep it simple ......
gillmj24
Reged: 12/06/05
Loc: PA
Re: new space heater idea new [Re: wolfman_4_ever]
      #5545089 - 11/29/12 08:30 AM
Last time I kept my basement dehumidifier on during the winter (60F in the basement?) The coils froze up. Its 30F in the dome now and humidity 70%. Not 90% and no dew. Warmer air prevents dew by lowering relative humidity if not absolute water content.
Jebus indeed....
jaddbd
Reged: 05/18/05
Loc: Woodbine, MD
      #5545637 - 11/29/12 02:26 PM
Your right... Dry Rods and light bulbs will not effect the humidity level - however, they can be used to keep the tempurature (of optics anyway) above the dew point to keep dew from forming - and it does work. Trying to de-humidify a non-insulated/unsealed roll-off (mine is 15x11) would be a losing and costly battle, at least in my case.
John D
wolfman_4_ever
Reged: 07/15/11
Re: new space heater idea new [Re: jaddbd]
      #5546145 - 11/29/12 07:54 PM
and in about 2-3 years when you pull your motor covers and wonder why all the gears/pins are rusted, you'll be screaming "Jebus, Mary and Joseph!"
So you open your dome for a night of "exploring" and bring all that nice water vapor that is trapped inside the nooks and cranies right down to the dew point.. wash, rinse and repeat for a few years..
I guess you are keeping those dry rods and light bulbs on all night long during a session? Oh that's right.. you have few hour cool down session so drip drip drip.. lol..
This is not lucky charms.. The water vapor does not "magically" disappear..
In fact dew will probably form faster since you just keep it trapped indoors..
But whatever.. you young whipper snappers will do what you want to do..
Thank You, Come Again!
wolfman_4_ever
Reged: 07/15/11
      #5546148 - 11/29/12 07:56 PM
John D
So you'll spend $60 on a dry rod and light bulbs but nothing to seal and insulate your roll off... interesting..
Do you heat your roll off by burning money in a firepit?
Wmacky
Reged: 11/24/07
Loc: Florida
      #5546169 - 11/29/12 08:13 PM
1 registered and 9 anonymous users are browsing this forum.
Moderator:  csa/montana, Chris Erickson
