Mitchell Duke
Reged: 04/22/08
Loc: Georgia
Secondary centering expert help needed
      #5516416 - 11/12/12 05:59 PM
Ok I just took apart my OTA and matched up the primary, and secondary alignment marks. However when I looked through the OTA back (eyepiece holder) the secondary housing is not centered. I had an astigmatism issue which hopefully was resolved by realigning the marks, or it might have been the noncentered secondary over the baffle. I can see the housing walls on one side and just the edge on the other side. My question is whats the best way to center the secondary on the baffle? By the way this is not a fastar secondary..
Mitchell
Eddgie
Reged: 02/01/06
Re: Secondary centering expert help needed new [Re: Mitchell Duke]
      #5516636 - 11/12/12 08:02 PM
This method may work for you.
Move a bright star to the very exact center of your field.
Collimate as best as possible.
Defocus on a very bright star and note that there will be a little tiny point of light at the center of the secondary shadow.
Defocus just enough so that you see the inner bright ring come out from under the secondary shadow, but again you still should see this tiny dot near the center of the shadow.
Does the dot look perfectly centered in the inner bright ring?
If not, this may indicate that the secondary is not directly over the primary. To center it, just move loosen the screws holding the corrector plate and push it in the direction required to center the point in the secondary shadow.
It does not have to be perfect perfect perfect, but you should be able to improve it using this method.
Plese let me know how this works for you (if it works).
I know it worked for me on two scopes, but one was an EdgeHD and one was a C5 that had some other modifications.
But I think it will work.
Again, would appreciate your feedback to know if this helped.
Mitchell Duke
Reged: 04/22/08
Loc: Georgia
Re: Secondary centering expert help needed new [Re: Eddgie]
      #5516661 - 11/12/12 08:19 PM
Eddgie,
I will let you know the results once we get some good seeing here. I do have one question though, should it be that obvious looking through the eyepiece hole?
Ed Holland
Reged: 06/16/10
Loc: San Jose, CA and Oxford, UK
      #5516669 - 11/12/12 08:26 PM
I don't know if this is relevant, but when I resurrected my C8 last year, I used vernier calipers to check the centering of the secondary (housing) with relation to the flange on the tube. Measurement was from the outer edge of secondary housing to inner edge of OTA flange, fairly easy to perform in a repeatable fashion. I noted readings at 90° intervals around the corrector, then adjusted - in my case changing the shims around the edge of the corrector, rather than moving the secondary within it, but the principle is similar. In a couple of iterations all four measurements agreed to my satisfaction - it will pass Eddgie's test as described above
Visual performance of the instrument is now very good. I also had to secure and adjust the rear cell mounting to ensure proper alignment of the primary mirror assembly, but that is another subject entirely.
Good luck,
Ed
Mitchell Duke
Reged: 04/22/08
Loc: Georgia
Re: Secondary centering expert help needed new [Re: Ed Holland]
      #5516729 - 11/12/12 08:55 PM
I did measure around the secondary to ensure it was perfectly centered, but its still not centered as seen from the back of the OTA (eyepiece hole).
Mitchell
Eddgie
Reged: 02/01/06
      #5516780 - 11/12/12 09:18 PM
Did you remove the baffle from the rear cell? If you did, that would be bad.
Are you sure that the front corrector cell and the mirror cell are both flush to the edge of the tube ends?
You need to eliminate any chance that the baffle is tilted with respect to the optical axis. If this condition occurs, you can have the secondary perfectly centered in the corrector cell, but when you sight though the baffle, it will appear off center.
If you removed the baffle, then you are going to have to check it to ensure that you got it back perfectly centered and perfectly parallel to the optical axis.
If you pulled off the mirror box from the tube, you need to ensure that that it is fully seated back against the end of the mirror tube. No gap at all anywhere around the outside. The mirror cell has to be exactly square to the tube itself.
Mitchell Duke
Reged: 04/22/08
Loc: Georgia
      #5517031 - 11/12/12 11:11 PM
I did remove the mirror from the rear cell a while back, but i never removed the baffel.
2) The secondary was perfectly centered and even measured.
3)I saw that the secondary was off center when i sighted through the baffel.
4) Could this be the true reason for astigmatism?
**Please give me some steps of what you would do to correct this please i need to get some nice Jupiter shots soon.
4)How do you square the tub to the mirror housing?
Mitchell Duke
Reged: 04/22/08
Loc: Georgia
      #5517524 - 11/13/12 09:17 AM
Ok after rechecking the baffel alignment through the OTA back (eyepiece hole) it seems as if the baffel / secondary is off a half inch to the left. I guess this is causing the astigmatism that im seeing in the star test? Question whats the best way to correct the half inch difference? Resecure the baffle to the primary, or resquare the mirror back housing?
Mitchell Duke
Reged: 04/22/08
Loc: Georgia
      #5517534 - 11/13/12 09:23 AM
Another thought could there be enough play in the corrector plate where the secondary sits to adjust by removing and realigning the secondary housing?
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5517618 - 11/13/12 10:19 AM
Duke, man this is one of those hands on projects you gotta look at, feel and touch. If your secondary was centered at one point, it can be centered again. Trick is, how to best do that.
It could be the cause of astigmatism, other's have complained of the same astig and centering issues. But, if your secondary was off at some point, then there might be two problems to deal with.
The first one would be to accurately place the secondary back in the corrector according to spec. It may have some sort of hash mark showing proper rotational orientation (in reference to what I don't know. Another hash mark?) Surely Celestron will give up the info.
Once rotational orientated, then it really needs to be placed radially so that it sits above the primary baffle. You could square the primary mirror and baffle assembly, but that may not be needed. It was just fine before. Unless you wanna knock your scope out of commission for a few days and pull our hair out.
There should be some play in the secondary hole in the corrector to allow for some radial adjustment (maintaining proper orientation of both the corrector and the secondary.) Then maybe some sufficient play in the corrector shims to allow more, if needed. You should be able to work out that 1/2 inch as seen from the visual back and get it back to where it was.
Alright, lot of words but how to do it? Eddgie and Ed Holland offered some methods. There was a guy who used rolled up paper sticking from his primary baffle (just long enough to reach the secondary baffle) and set the corrector that way. His process was a bit more involved than that, but that's the idea. It was on the internet somewhere, sorry I don't have a bookmark. Google, "how the *BLEEP* do I center my *BLEEP* *BLEEP* secondary mirror and corrector for *BLEEP* sakes?"
I used Eddgie's method on my scope with the same problem. Focusing in and outside, my donut was not concentric on both sides. It was skewed one way inside and the opposite way outside. I could tell my focal plane wasn't moving orthogonal to the optical axis - same effect as you might have. Rotating my optical components (with a fixed, spot secondary) 90 degrees eventually got everything spot on. As Edggie says, I made sure all components were as flush with the tube as they could be.
So, first thing to do is to align your secondary's rotation back to spec. I believe there might be some surface correction applied to it, so it has to go in one way. And that one way probably means the corrector is the same. It goes in one way, too. (They add some 5th order aspheric terms and that may mean some hand figuring with optics in some alignment. Someone can correct me if that's not true.)
Once rotation alignment is restored, then radial centering can be done. By then, you should be back to normal without ever touching the primary mirror assembly...unless you have way too much hair and need to pull some of it out.
Good luck, Duke. My hair is growing back. Yours will, too.
Edited by Asbytec (11/13/12 10:25 AM)
Eddgie
Reged: 02/01/06
      #5517631 - 11/13/12 10:30 AM
A half inch off is a lot.
I don't even think there is enough play in the corrector to correct for that much decentering. Ususally there is only about 1/4 inch of total play between the edge of the corrector and the cell.
Dude, I don't know how you could be off so far unless the baffle was tilted with respect to the optical plane.
Did you mark the primary cell to ensure that it was put back in the same orientation on the tube? It sounds like your baffle is not square.
There are other tests you can do.
One is to use a low power eyepeice and defocus a star. Now, move the star to the north, south, east, and west.
What you want to see is that the fresnel pattern remains whole as it approaches the edge of the field of the eyepecie.
If you see the pattern have a circular intrusion at any point on one side and not the other, this indicates that the baffle is tilted with respect to the focal plane.
The Fresnel pattern should remain whole in every direction.
The SCT design is not free from astigmatism, but the dominant abberation is coma. If you your baffle is tilted, or you secondary is not centered, you will see coma as the primary abberation, but there is indeed an astimatic component in the SCT. Same with a Newtonian mirror. Both have astigmatimsm, but the coma is much stronger so it does more damage. But if you pass through focus on star at the edge of the field even using excellent eyepeices, there could be an astigmatic component visible.
I just don't know how you could be so far off with the secondary mirror.
What was the result of the point test? Did you observe the little point I mentioned? Was it centered in the inner ring?
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5517716 - 11/13/12 11:24 AM
Good point, Eddgie. That does seem a lot to be off. Was the primary mirror assembly off?
If it's a half inch, that may be a bit much to account for with corrector centering itself. Maybe the mirror assembly was re-installed 90 degrees out. Re-installing both incorrectly could give that much displacement, ya think?
This seemed to be true in my case, the baffle pointed at the secondary when I rotated the mirror assembly 90 degrees (to match the mounting holes.) Not sure how the CGE is constructed, but if the primary mirror assembly is rotated, then the baffle could tilt away from the installed secondary position. Rotating the mirror assembly might re-point the baffle at the secondary, or get closer than 1/2 inch. From there, some corrector adjustment would finish the alignment.
Chances are, it's not perfectly square as a result of mass production. This is still okay as long as the secondary can be positioned directly above (centered) it and shining directly down it (verified by your Poisson spot method, or checking the secondary shadow is concentric both sides of focus.)
spectre
Reged: 05/09/10
Loc: Abington, PA
Re: Secondary centering expert help needed new [Re: Asbytec]
      #5517748 - 11/13/12 11:40 AM
I may have the same off-center condition on my C-8. What do I loosen in order to adjust the secondary location in the corrector? Collimation screws or do I need to remove the corrector and work at it from the inside?
Ed Holland
Reged: 06/16/10
Re: Secondary centering expert help needed new [Re: spectre]
      #5517875 - 11/13/12 12:51 PM
In the case of my scope, a previous owner had obviously removed the rear cell It was loose on the main tube, leading to a tilted, and tilting primary, which made collimation impossible and images astigmatic.
I had to remove the corrector so that the rear cell fasteners could be accessed, then adjust & re tighten and replace the corrector. At that point I used the (well known) method of sighting the scope from the front to check for a concentric pattern of circles & reflections. This has the potential to be a time consuming and frustrating process... care is needed each time the tube is reassembled if the effect of resetting the rear cell is not to be confounded by some other variation.
However, once I was happy with alignment as gauged by the "circles" test, the telescope required only a minor adjustment of the secondary mirror to attain excellent collimation. The difference between the scope performance before and after realignment of the rear cell was very significant. Pin sharp stars, surface features on Mars etc. were all now within easy reach.
Ed
wolfman_4_ever
Reged: 07/15/11
Loc: El Segundo, Ca, So. Cal
      #5517932 - 11/13/12 01:20 PM
I wish Celestron and Meade would put the little tiny bullseye back in the center of the secondary.. then you would shoot a laser up the baffle (assuming the baffle is centered) and get it dead on.. Or use a Tak Collimating Scope
Eddgie
Reged: 02/01/06
      #5518082 - 11/13/12 02:51 PM
I had a phone call this morning with the OP and suggested this exact same thing... That the rear cell itself may be tilted very slightly.
He is going to center the corrector the secondary hole in the corrector cell, remove the secondary, put a piece of paper over the hole, then put the alignment laser into visual back to see if it strickes the center of the hole. or if it misses.
It may be possible to loosen the screws on the rear cell and tilt the entire rear cell in much the same way that refractor focuser tubes can be sometimes tilted slightly by loosening the screws holding the focuser housing. In this case, the entire rear mirror cell might have to be very slightly tilted.
Waiting to hear the result.
We discussed several other things to do as well to diagonose the problem, but I remain confident that this is an axial alignment problem of some sort...
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
      #5518431 - 11/13/12 06:08 PM
Mitchell, sounds like you have a plan, wish you the best in this alignment.
The secondary should be positioned properly in the corrector if still in the original factory configuration. If that has been altered it needs to be fixed. A secondary decentered from the plate will result in on-axis coma. To 'collimate' a scope in that condition will result in other aberrations. The centering of the secondary in the corrector plate is of paramount importance, even more so than centering the plate over the primary.
If the primary is not tilted then you may find the best placement for the corrector plate is not necessarilly concentric to the scope tube. It could be off as much as 1-2 mm. A decentered plate will introduce astigmatism as well as a mixture of some other components.
Let me know (you have my email) if you need any notes or procedures or additional information concerning the above.
Glenn
Mitchell Duke
Reged: 04/22/08
Loc: Georgia
Re: Secondary centering expert help needed new [Re: DesertRat]
      #5518501 - 11/13/12 06:52 PM
Thanks Glen and Ed for the awesome help!! Im going to try this site out http://www.wilmslowastro.com/tips/c14_optics_alignment.html its a similar idea to what Ed and i discussed. I just have to figure out how the primary wooded centering contraption works, any ideas?
Eddgie
Reged: 02/01/06
      #5519228 - 11/14/12 09:12 AM
Interesting... This is exactly whay I mentioned as my thought when we were on the phone, that the rear cell may need to be tilted to get the baffle aligned to the optical axis the way refractor focuser draw tubes have to be alighed:
If you do have any run out (mine was about 2mm), then loosen the nuts/screws that hold the rear casting to the OTA and use a piece of wood and mallet to gently tap the tube in the direction required. You will probably find the tube is seated hard back against the rear casting, so the initial adjustments are going to be tapping the front casting forwards away from the rear casting.
My guess is that Celestron has a fixture that holds the tube and baffle alignment when the retaining screws are tightened so that the baffle is parallel to the tube wall.
And the 2mm figure is interesting because this is what I mentioned on our phone call... A tiny amount of tilt of the baffle could put you outside of the diffraction limited field of the mirrors.
Looking forward to hearing how it goes. Please keep us updated.
Ed Holland
Reged: 06/16/10
      #5519767 - 11/14/12 04:17 PM
With reference to the method in the link provided by whduke, I think that looks like a sound approach. With the primary being such a fast mirror, it only takes a tiny misalignment to disrupt performance.
Ed
15 registered and 18 anonymous users are browsing this forum.
Moderator:  cbwerner, Starman27, kkokkolis
