KCN
Reged: 04/12/06
Loc: Calgary, AB, Canada
Travel mount for FLT98?
      #5518200 - 11/13/12 03:59 PM
Friends,
I have a William Optics FLT98 refractor (the Al tube version) that I purchased with traveling in mind. Now, all I need is decent mount that could hold the OTA and be transported in checked-in luggage. The tube weighs about 10 lbs or 5 kg and it's 5-600 mm long.
Any ideas from fellow travelers who have experience flying with this kind of setup?
Many thanks!
ichdien
Reged: 11/27/08
Re: Travel mount for FLT98? new [Re: KCN]
      #5518441 - 11/13/12 06:16 PM
If you're looking for an alt-az, you might have luck with a Tak Teegul. Not too large and can be packed in a suitcase. I use mine with a 105mm, lb. refractor, mounted on a Gitzo carbon fiber tripod that can also be packed in a suitcase and checked in.
M13 Observer
Reged: 12/09/06
Re: Travel mount for FLT98? new [Re: ichdien]
      #5518518 - 11/13/12 06:57 PM
I second the Tak TeeGul SPIII with Gitzo CF tripod. I use mine with a Tak Sky90 or AP Stowaway. Scope, 1.25" diagonal, and 1.25" Nikon NAV eyepieces stay with me, tripod, mount and 2 small CW go in luggage.
M44
Reged: 03/24/07
Loc: SoCal.
Re: Travel mount for FLT98? new [Re: M13 Observer]
      #5518534 - 11/13/12 07:08 PM
I third the Tak Teegu (Lapides modified). I have one for travel with Gitzo 5531. It handles my 110 f/5.6, 10 lbs effortlessly.
Smooth slow-motion knobs are great and feels solid with minimum shake in the views.
ottovonrotton
Reged: 01/01/09
Loc: Where is Port Perry?
      #5518574 - 11/13/12 07:39 PM
Hello, don't know if this helps, I travel to Cuba at least once a year, I take a Vixen Vmc 110 (4.26lbs) plus tackle box of eyepieces etc. in my carry on and pack a light weight photo tripod with simple pan head and handle, works great late at night as grab and stagger. (free drinks!)
Midnight Dan
Reged: 01/23/08
Re: Travel mount for FLT98? new [Re: ottovonrotton]
      #5518724 - 11/13/12 09:22 PM
A DSV-1 would handle that nicely: http://www.desertskyastro.com/DSV-1.html
plus it's reasonably small and lightweight.
The problem with putting any of these rigs in a suitcase is the tripod. Getting something that is reasonably small, yet stable, is a real challenge. A standard surveyor's tripod that is used with something like the DSV-1 is 38" long when folded up. That takes a pretty big suitcase.
There are a couple of shorty surveryor's tripods out there that might do the trick if you don't mind sitting on the ground, or if you have a sturdy raised surface to put it on. Here's one example (24" folded up):
http://www.stakemill.com/index.php?main_page=product_info&products_id=4059
-Dan
chboss
Reged: 03/24/08
Loc: Tokyo Japan
Re: Travel mount for FLT98? new [Re: Midnight Dan]
      #5518763 - 11/13/12 09:48 PM
For a real light but stable Alt-Az mount you could also consider the AYO line:
AYO-Traveler:
http://www.aokswiss.ch/d/mont/ayo/ayotraveler/uebersicht_ayotraveler.html
AYO Mark II:
http://www.aokswiss.ch/d/mont/ayo/ayo1/ayo1.html
I use the AYO of the first generation with my FS-102 with 816mm focal length, it would even carry more weight. All models have the thread to be mounted on a normal Photo Tripod.
best regards
Chris
KCN
Reged: 04/12/06
Re: Travel mount for FLT98? new [Re: chboss]
      #5519837 - 11/14/12 05:22 PM
Thanks a lot everyone,
I really like all options, the Tak having the benefit of tracking, but at a much higher price tag.
The DSV and the AYO have a lot of appeal too, especially because they are so affordable. Of course, they have tracking options, which brings them close to the price range of the Teegul. So, now I have to decide tracking or non-tracking.
Also, is there any tracking equatorial that would be fit for travel?
Clear skies,
Midnight Dan
Reged: 01/23/08
      #5519902 - 11/14/12 06:20 PM
For the FLT98, the iOptron SmartEQ ($399) should work. It has a payload of 11 pounds which would be pushing it a wee bit with that scope, but for visual-only it should be ok. The SmartEQ Pro is $100 more, but has metal worm gears and a polar scope.
http://ioptron.com/index.cfm?select=productdetails&phid=6650b0b6-9767-494...
-Dan
M13 Observer
Reged: 12/09/06
      #5520228 - 11/14/12 10:00 PM
Clear skies,
Uuuuhhh, the Tak SPIII with Gitzo tripod?
KCN
Reged: 04/12/06
      #5521094 - 11/15/12 12:06 PM
Of course Let me rephrase that: Is there any tracking equatorial that would be fit for travel, without expensive Japanese letters on it?
33 registered and 31 anonymous users are browsing this forum.
