MHamburg
Reged: 06/21/06
Loc: Brooklyn, NY/Berkshires, MA
CGEM RA Axis Backlash new
      #5516312 - 11/12/12 04:40 PM
Hello All,
While I am waiting for an answer from Ed Thomas, I thought this forum's brain trust could also help. I recently finished a hypertune of my CGEM (which went reasonably well and taught me a lot about the mount) and believe I have increased the backlash! The RA axis wiggles (whether fully loaded or not) about 3/32". When slewing under power the motors sound fine and are responsive. Since I did the hypertune to improve the mount's imaging capabilities, I welcome all suggestions that would reduce this slop. I would love to avoid having to disassemble the mount again. Thanks in advance for the help.
Michael
MHamburg
Reged: 06/21/06
Re: CGEM RA Axis Backlash new [Re: MHamburg]
      #5516358 - 11/12/12 05:24 PM
Just got explicit instructions from Ed Thomas how to adjust this backlash. He has been the most supportive and deserves our patronage whenever possible.
Michael
orlyandico
Reged: 08/10/09
Loc: Singapore
      #5517358 - 11/13/12 07:11 AM
don't take out all the backlash, you would stall the motor.
i notice that the closer the worm is set to the ring gear, the noisier the RA motor will be.
you cannot eliminate all the backlash so don't even try; backlash in RA is not a big deal, just make sure to be slightly east heavy.
MHamburg
Reged: 06/21/06
Re: CGEM RA Axis Backlash new [Re: orlyandico]
      #5517553 - 11/13/12 09:31 AM
Thanks for the advice, Orlando. I'll let you know how it all works out.
Michael
orlyandico
Reged: 08/10/09
Loc: Singapore
      #5517565 - 11/13/12 09:40 AM
in spite of the large-ish backlash and huge periodic error (40") on my CGEM, i can still guide effectively..
https://dl.dropbox.com/u/63497702/20121022-cgem-m57.PNG
notice the RMS error for the RA which is 0.18 - with my finder-guider and Meade DSI, that's about 1.4" to 1.8" - not fantastic, but that's what you get for the money.
Another of Ed's words of wisdom - don't kill yourself trying for perfection, you won't get it. Not with the CGEM anyway. Personally getting 2" accurate guiding is a bit annoying but it is what it is.
It all depends on the magnitude of your CGEM's 8/3 (the famous 2.6667X harmonic). If it's large - like mine - then guiding is always a challenge. If it's small, then lucky you. My CGEM has an Aeroquest worm, but since the 8/3 is so large (larger than the fundamental) it still screws things up.
MHamburg
Reged: 06/21/06
Re: CGEM RA Axis Backlash [Re: orlyandico]
      #5518310 - 11/13/12 04:59 PM
I would be very happy with a graph like that.
Michael
19 registered and 33 anonymous users are browsing this forum.
