tboss70
Reged: 11/25/05
Loc: Missouri
Losmandy G11: weights to balance C14 new
      #5516727 - 11/12/12 08:54 PM
How many weights does it take to balance a C14 OTA on a G11?
And which ones?
whduke
Reged: 04/22/08
Loc: Clayton NC
Re: Losmandy G11: weights to balance C14 new [Re: tboss70]
      #5516731 - 11/12/12 08:57 PM
On my CGE it takes 62.5 Lbs to balance it.. If you are hunting for a quick solution just buy some weights from Walmart and they work just as good.
Gord
Reged: 01/06/04
Loc: Toronto, ON, Canada
Re: Losmandy G11: weights to balance C14 new [Re: whduke]
      #5516849 - 11/12/12 09:52 PM
I have one 21(?) pound down near the bottom of the shaft, and 2 x 11 lbs sitting on an extension at the end of the shaft. That's enough for the C14 Edge.
Clear skies,
tboss70
Reged: 11/25/05
Loc: Missouri
Re: Losmandy G11: weights to balance C14 new [Re: Gord]
      #5517758 - 11/13/12 11:44 AM
Thank you. I have one 21lb and one 7lb. Looks like I may need at least another 21lb weight if not more.
Does anyone make similar weight cheaper than the Losmandy?
$100 for a 21lb weight is a little high.
Startraffic
Reged: 02/12/06
Re: Losmandy G11: weights to balance C14 [Re: tboss70]
      #5518378 - 11/13/12 05:35 PM
Tboss,
Weider does. You can get them at just about any sporting goods store. Sandwich a 10# between the 21# & 7# & you'll be good to go.
Clear Dark Skies
Startraffic
39.138274 -77.168898
Alt 518ft ASL
Danno2006
Reged: 01/25/06
Loc: Ontario, Canada
Re: Losmandy G11: weights to balance C14 new [Re: Startraffic]
      #5520283 - 11/14/12 10:43 PM Attachment (25 downloads)
This setup takes 3 x 21 lbs. Before I added the top scope, I could use a Meade LXD55 weight on the end in place of the safety stop and 2 x 21lb weights part-way up the shaft.
Edited by Danno2006 (11/14/12 10:45 PM)
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: Losmandy G11: weights to balance C14 new [Re: Danno2006]
      #5520738 - 11/15/12 08:32 AM
Beautiful!
Danno2006
Reged: 01/25/06
Re: Losmandy G11: weights to balance C14 new [Re: Raginar]
      #5525168 - 11/17/12 09:44 PM
Thank you!
20 registered and 28 anonymous users are browsing this forum.
Moderator:  Cotts, Starman27
