Dosster
Reged: 10/27/06
Loc: Cambridge MN
New Mount for my SN8
#5518032 - 11/13/12 02:20 PM
Hello Everyone
I'm considering a new mount for my SN8 to replace the hyper-tuned LXD75 I have. I'm looking at the big 3 with Astrophotography as the goal.
ieq45 with pier (not tripod) Atlas CGEM DX
My SN8 with a Canon 40D and the Orion Magnificent Mini AutoGuider, weighs in at 27.5lbs. I figure with heaters and dew shield, I'll be at 28.
the average capacity of these mounts is 45#. At 75% this gives me a cap of 33.75# and at 66% gives a cap of 30#. I'm right under the suggested max cap for astrophotography.
So far the Atlas has the best reviews hands down. I like the features of the IEQ45 but, heard the tripod is junk. That's why if I go that route I thought the package with the pier would be a better option. The CGEM DX is the tank and possible the most stable of the group out of the box.
I have been reading a ton of reviews and can't decide which one would be the best. I'm looking for thoughts and opinions. Also does anyone have the IEQ45 with the pier?? and have any comments?
Thanks to all in advance Matt
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
Re: New Mount for my SN8
[Re: Dosster]
#5518059 - 11/13/12 02:35 PM Attachment (12 downloads)
I used a stock LXD75 SN6 for many years and I loved it, but I reached a point where I wanted something a little more robust. I ended up getting an Atlas EQ-G and that did the trick. This mount is rock solid with my SN6 or my SC8 sitting on top of it.
My original LXD75 SN6...
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
[Re: jgraham]
#5518060 - 11/13/12 02:35 PM Attachment (13 downloads)
And my Atlas EQ-G SN6...
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
[Re: jgraham]
#5518066 - 11/13/12 02:38 PM
One word of caution... do NOT use the original LXD75 dovetail, it doesn't fit the Atlas quite right, something that I found out the hard way. I ended up moving the LXD75 rings over to the dovetail bar that comes with the Atlas.
Have fun!
Erik30
Reged: 10/16/12
Loc: Cottage Grove, MN
[Re: jgraham]
#5518312 - 11/13/12 05:00 PM
I have the ieq45 and the mount is not "That" bad. hands down better than the CG-5 mount I have. But that is the only other mount I can compare it to.
Erik30
Reged: 10/16/12
[Re: Erik30]
#5518316 - 11/13/12 05:01 PM
And I mean mount as in the tri-pod..
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
[Re: Erik30]
#5518367 - 11/13/12 05:31 PM
I have a SN8 on a Losmandy G-11. Works great. Plenty of stability and no worries about overloading. Its the same mount I use for my 8" DK and with both Gemini II and an Ovision worm on the RA, its one heck of a mount for medium-sized OTAs and the price difference between the G-11 and more premium mounts.
BTW: I cannot understand why the Schmidt-Newtonian is no longer made. It is a nice OTA with wide-field advantages. Perhaps someone with one of the F4 Newtonian astrographs can chime in about using this design with a corrector? Maybe that is just as good?
Ed
Jb32828
Reged: 08/01/10
Loc: Orlando, FL USA
[Re: Ed Wiley]
#5520018 - 11/14/12 07:20 PM
I have the exact same setup as John. Rock solid. Easy to use. EQMOD just rocks.
Startraffic
Reged: 02/12/06
[Re: Dosster]
#5520065 - 11/14/12 08:00 PM
Dosster, Why not take a look at a Losmandy G8 with Gemini-2 & a polar scope? Yes, it is more $$$ but, more load cap, better tracking, easily repaired (should you manage to break it), the new Gemini-2 drive system is easy to update, & the mount will last for decades, not a few years. My $0.0125" worth.
Clear Dark Skies Startraffic 39.138274 -77.168898 Alt 518ft ASL
chboss
Reged: 03/24/08
Loc: Zurich Switzerland
[Re: Startraffic]
#5520115 - 11/14/12 08:42 PM
Matt
I think the iEQ45 will work for your configuration. Fully agree with your view to go with the pier, the tripod is just not up to the necessary standard for AP! I use mine on a larger pier and it is rock solid.
best regards Chris
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
[Re: chboss]
#5520234 - 11/14/12 10:07 PM
+1 EQMOD, I don't even bother with the hand controller anymore. Simply fantabulous.
