Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Opinion on Star Test
      #5523696 - 11/17/12 12:20 AM Attachment (133 downloads)
Please glance over the star test images below and offer your assessment.
The intra and extra focal images appear quite different at a glance, but on closer inspection are not that dissimilar. Of course, the most notable feature is the strong loss of contrast outside of focus. Inside focus patterns are clean and high contrast, outside are not. This made evaluating outside patterns a little difficult.
At 4 waves, the contrast difference is not that apparent despite the flaring of the outer ring. In both de-focus locations, the inner most rings are clean, well defined, and high contrast. However, inside focus, the inner most rings are noticeably dimmer than outside focus. The third ring is bright, clean and well defined. There is also a dim halo of two rings, the inside one is not too faint while the outer one is barely seen. Outside, the general pattern of dimmer to brighter still applies like the inside focus pattern.
However, the innermost rings are definitely brighter than the corresponding rings inside focus. They are well contrasted, too. The third ring is a bit dimmer than the same ring inside focus (probably due to the lesser contrast.) This third ring, in particular, contributes nearly all of the flaring seen at this de-focus. Again, the same ring inside focus is very clean and well defined. The difference of this is striking.
Amateur Telescope optics shows 4 waves balanced (at bottom), but they appear only similar in some aspects, possibly between 0.1 and 0.2 PV. Neh?
http://www.telescope-optics.net/Mak_spherical.htm
About 10 waves, the contrast loss outside of focus is very prominent. In fact, it's difficult to detect the ring structure in moderate seeing, so it did require great seeing to get a good look at them. Inside of focus has the same relative brightness patterns consistent with Suiter's representation of 1/8th wave spherical. Again, they are very clean with full contrast.
Interestingly, in the best moments, outside of focus the relative ring structure and relative brightness are strikingly similar to inside focus. Outside the rings are a bit dimmer than inside, but this is due to the light scattered across the outside focus pattern. In less than perfect seeing, the two rings bordering the shadow tend to blend into one fuzzy, tad brighter ring. But, if one looks deep into that fuzzy glow, there are indeed two rings there. The inner most ring on the shadow boundary is actually a little dimmer than the one just outside it, just like inside focus pattern. Both are very thin and hard to see without good contrast. But, having said that, the basic relative pattern still holds pretty well with Suiter's (first edition) 1/8th wave representation.
Inside of focus, the central shadow is also noticeably darker at both levels of de-focus. It also appears a bit larger inside focus, but that's difficult to evaluate because of the flaring and loss of contrast outside of focus. OUtside it's more difficult to see the defined shadow. I did not do the shadow break out tests, the CO is only ~29% and the test looks very difficult to perform accurately. Nor have I applied Aberrator at this point. Maybe some night I will do so.
Lastly, the in-focus image is shown. Of course, the spurious disc (Aldebaran at 383x) is bright and as perfectly round as I could make it out to be. The first ring is pretty bright. That all appears normal for a spherical, obstructed scope with some spherical aberration present. Outside the first ring, there are two much fainter rings. The first of which is fairly faint and the third, outer most ring is very faint. The latter can only be seen during the best moments of seeing (I hope it even shows in the sketch.)
One interesting artifact(?) exists just outside the first bright ring and between that ring an the next. In generally good seeing, a series of extremely thin, not too dim, arcs seem to dance between the major diffraction rings. In very steady seeing, those dancing arcs settle into two very, very thin rings of moderate brightness (the outer ring a tad brighter than the inner.) I am not sure that to make of those rings. Again, they appear to be consistent with Suiter's representation of 1/8th wave in-focus representation.
Anyway, my guess is, despite the loss of contrast, the correction seems pretty good. Surely they are not perfect, and I doubt they are 1/8th corrected. I cannot quantify it except to say it's consistent with Suiter's 1/8th wave, and much less so with 1/4 wave SA. I might wager the correction is near 1/6th P-V, with lower order and higher order contributing (and I suspect balanced to some degree.) Despite the contrast loss outside of focus, Jupiter come to focus rather snappy and shows a great bit of detail.
I am still trying to evaluate the HSA component, but that is very difficult to do. According to Suiter, I really gotta get down to 1 to 3 waves de-focus to see, "mouthpiece of the born pulled back through the caustic."
Anyway, what say you?
Edited by Asbytec (11/17/12 12:35 AM)
thomas68
Reged: 01/25/11
Loc: North west Indiana
Re: Opinion on Star Test new [Re: Asbytec]
      #5523968 - 11/17/12 08:59 AM
Asbytec, your collimation looks great! I bet it looks even better under those dark skies you have.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: Opinion on Star Test new [Re: thomas68]
      #5523981 - 11/17/12 09:15 AM
Tom, thank you. Yes, it's amazing, really. Very fortunate, tropical dry season is the best seeing I have personally seen. When you can get down to 1 wave de-focus and the Poisson spot sits still dead center, it's nice to get collimation spot on. Dark. Not bad, pretty dark. Especially when the power goes out.
Edited by Asbytec (11/17/12 09:21 AM)
thomas68
Reged: 01/25/11
      #5524008 - 11/17/12 09:29 AM
Asbytec, once in a while I wish the power would go out! Only on the clearest night of the year.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5524122 - 11/17/12 10:44 AM
Yea, one cannot cast stones at that idea.
orion61
Reged: 10/20/07
Loc: Birthplace James T Kirk
      #5525011 - 11/17/12 08:09 PM
what brand/type OTA is that, I've found for whatever reason Maks fair better on the focused image with SA.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: Opinion on Star Test new [Re: orion61]
      #5525040 - 11/17/12 08:31 PM Attachment (37 downloads)
Orion, that's exactly what I am trying to figure out. They do focus well, but why? The images are from a modified Orion 150 Mak, f/13, ~28% CO.
I am sure there is some HSA, but I am having difficulty with determining how much or whether it's balanced. I suspect it is. According to Suiter, you can best see this at very close to focus. Apparently, there is a brighter central region with light falling off toward the edge of the pattern in the presence of SA. The condition gets worse with less correction. It's just so very hard to see any of that.
The 1 wave patterns are sketched below. I really do not know what to make of them other than to praise God for such favorable seeing (and perfect collimation. )
Last night observing Capella, outside focus a little brighter than Aldebaran, the two inner rings bordering the shadow appeared to be about equal brightness. So, maybe there is some revision to the description above, but not much.
Pinbout
Reged: 02/22/10
Loc: nj
      #5525100 - 11/17/12 09:07 PM Attachment (47 downloads)
here's what I get for a 150f10 1/6~ under balanced
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: Opinion on Star Test new [Re: Pinbout]
      #5525131 - 11/17/12 09:24 PM
Thank you, Danny. Inside looks darn close, very darn close. Outside, the inner ring might be just a tad brighter than observed, but that's definitely ball park. The higher order is more visible in that image, with a more distinct dimming toward the edge as I understand the effect. Still, it might be accuracy in observing that might account for that difference.
Playing with Aberrator last year, I found it was pretty sensitive to CO. Change the CO by a couple percentage points, and the ring structure and relative brightness changed a bit. A CO of 30% is probably close enough. Gotta re-install Aberrator and give it a look see.
Thanks for posting, Danny.
Eddgie
Reged: 02/01/06
      #5525146 - 11/17/12 09:34 PM Attachment (36 downloads)
I had difficulty modeling this.
The second diffraction ring visible in the in-focus image required .15 wave of spherical abberation to achieve. This is the primary cause for light to be pushed outside of the Airy Disk and first diffraction ring, and no HSA simulation I tried would generate an easily visible second diffraction ring, so I am going to guess that the contribution to this is some LSA.
This is consistent with what Suiter suggests for the design(that some LSA could be used to negate the rolled edge appearance that would otherwise result from the HSA component.
I think the model for 4 waves is about right, but at 10 waves, the model did not work out. It showed what looked like a turned edge. Was the secondary baffle in place? If not, I would think that the HSA could cause this appearance (of a turned edge) which again is what Suiter suggests.
Anyway, I included my settings. I had to flip the in/out focus patterns to match your provided drawing.
I think you should obstruct to 40% and try to model the lower order SA so you can get a read on it.
I think much of what you are seeing is the effects of some HSA, but there appears to me to be some LSA too.
Anyway, why don't you load my figures into Abberator and give it a try. You will see that if you correct the LSA, the outer ring will go out, even with .4 waves of HSA.
I modeled the HSA a bit stronger than necessary.. I think the .3 setting looked perhaps a bit closer so I would plugh that into abberator.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: Opinion on Star Test new [Re: Eddgie]
      #5525255 - 11/17/12 10:56 PM
Eddgie, I had a lot of trouble modeling it, too. Beginning with some initial assumptions, then hit and miss tweaking the patterns to get them close. Then, as you say, scroll through focus to check consistency.
It was a real chore, best I could do is get all de focus ranges close. The closest I could do (previously) was LSA at -.15 and adding about +0.1 to .2 HSA (about 1/5th wave that might be expected in a balanced system.) The result was close across 10 and 4 waves (and in focus) giving RMS of about 0.038, including a trace coma and astig added (but not observed.) So, the test proved pretty good at one point earlier this year.
Initially, your presentations brought an "oooh, he got it!" reaction. At 4 waves, though, the inner most ring brightness is reversed. If you reverse them back, it's closer. LOL I tell ya, it's tough to get it right. It's one reason I am hesitant to play with Aberrator, again. I am trying to observe it directly and infer some level of correction visually.
I do get that "turned edge" look, but outside of focus (with the secondary's baffle removed.) That was the one scary thing testing without the baffle, the star test was no longer "beautiful." When the star tests were beautiful, shadow break out occurred at about 1: ~1.5 to 2, (or a little less than 2.) I was shocked it turned out that well, but with the CO closer to 52mm (37%) of 140mm eff aperture, well that might be expected. With the excessive contrast loss outside focus, and the CO less than 33%, the break out test is much more difficult. So, I rely on the previous tests remaining somewhat accurate if not a little over estimation.
Thank you for chiming in, Eddgie. Always appreciate your views. Still mulling it over.
Eddgie
Reged: 02/01/06
      #5525291 - 11/17/12 11:35 PM
Well, this is the one thing Suiter mentions in his book and this is perhaps the best example one could have.
Suiter is quick to mention that single abberations rarely appear alone, and that when you mix the effects of the abberations, it can be difficult to interpret the results of the star test.
We assume higher order Spherical Abberation (you and I do of course because you are one of the few people I know to have read his book) in this scope because we know that it is a consequence of a "Fast" aluminized spot all spherical MCT.
And we may conclude that the secondary baffle acted to mask the effects of HSA, and that when you removed it, it let those abberatios show through.
I believe that there is a bit of LSA, because I can't find a model using pure HSA that will give a result similar to what you observer.
But if there is HSA and LSA, finding the exact match may prove to be impossible simply because there are so many possible combinations of LSA and HSA.
And sadly, there is one more complication. A Turned Edge can cause some of the things you are obseving. Even a tiny turned edge could account for some of what you see, even if it was not enough to have a meaningfull effect on the image.
If you have a Rinchi grating, you may want to test for this.
The Ronchi when used single-pass is just not very good for detecting Spherical Abberation unless it is very bad. But it is very good at showing a TE.
So, perhaps the LSA component is milder than we have modeled and maybe there is a mixed in TE.
Again, just brainstorming, but I tried a half dozen models and could not get the 10 wave pattern to work.
With a tiny TE though, I could imagine that you might see your 10 wave pattern.
Sadly, Abberator 3.0 doesn't model turned edges..
Ah, but Abberator 2.0 does.. LOL...
But see if you can order a plastic Ronchi strip and check for TE. If you had a tiny bit, it would explain a lot.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5525315 - 11/17/12 11:55 PM
Edggie, no doubt there is some LSA and even residual HSA. I am trying to determine how much and whether the system is balances for 5th order.
Absolutely, that is the core of the entire exercise, to determine if the baffle was cutting off some marginal rays and improving the star test. And whether removing the baffle has been detrimental to the wavefront figure afterward. I tend to think not, Jupiter still "snaps" pretty well.
My Ronchi is not that sensitive at 50ln per inch, but at f29 I could detect no trace of a turned edge. Just some very weak under correction, pretty consistent with Ronchi for windows. The test is not conclusive, but I think the crisp inside patterns indicate no turned edge.
Studying HSA (including Suiter's book) seems to suggest it needs to be pretty severe to degrade performance (~0.4 waves at 0.075 RMS.) According to Vlad's site, the mere process of making a usable Mak requires reducing higher order SA to some degree. Balancing has minimal impact on the wavefront and can still be quite good RMS, wise.
But, I am trying to actually see this. Really, Jupiter is just as good if not better, but the star test is kind of ugly outside of focus (only.) This is much like Roland's description of asymetrical testing resulting from higher order SA. So, all this seems to point to well corrected and balanced SA.
Another test, very subjective, last night observing Capella in focus, so much of the light was centered near the Spurious disc and first ring. There was a little scatter outside the first ring, usually when seeing blurred the image. When it did, the fainter second and third rings would simply vanish. When they were visible, they were very faint. So, I conclude EER(1) is pretty good.
Using Suiter's EER(1) chart, and some optimistic estimations of 1/8th LSA (only) and a 37% CO, EER(1) was near 72%. Without the baffle, EER(1) improves to about 0.80. So, even though the actual Strehl (calculated from Aberrator generated RMS) is near 0.95, the EER(1) approaches "diffraction limited" performance, "good" according to Suiter and taking into account Strehl and CO effects.
But, I still cannot say conclusively the system is balanced for HSA, it just looks to be from all accounts and to the best of my knowledge. And if so, then removing the baffle had minimal impact, in fact might have improved performance.
Thanks, Eddgie...brain dead. More later...
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5525603 - 11/18/12 07:02 AM Attachment (21 downloads)
Well, here are some star test patterns from Amateur Telescope Optics. Been focusing on the ones in the link above and forgot to look at these.
http://www.telescope-optics.net/diffraction_pattern_and_aberrations.htm
The 4 wave de-focus sketches above do resemble the balanced form (and nothing like the primary aberration alone.) That's good, very good.
Its very hard to tell which level of residual HSA remains, however. The patterns look very difficult to differentiate visually at the eyepiece. In 0.2 PV form, both outer rings are close to equal brightness on both sides of focus.
In the 0.4 PV form, the difference between that outer ring inside and out is a little greater. However, the inner most ring is noticeably dimmer inside focus. It's barely visible.
Both outside patterns look pretty similar, too similar to differentiate visually.
So, it looks like it boils down to evaluating how bright that inner ring is and evaluating how closely the outer rings are in terms of brightness on both sides of focus. Really hard to say, but it's pleasing to know they resemble the balanced form.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5525986 - 11/18/12 12:04 PM
Well, kind of sort of did the shadow break out, without the 33% obstruction. I know it's not the standard test, but was just a curious look see. What harm could it do?
I de-focused until I was sure it was broke out, then went way outside focus and moved back toward focus until it looked like it disappeared. So, I approached the break out from both directions. Did that several times.
It seems the shadow breaks out between 6 and 8 waves inside, and about 12 to 15 waves outside. And some of that error was subjective, was the shadow well defined or how large should it be. Surely with a larger CO, it would have held up closer to focus, but this look was just a wag.
Also, as I thought, 4 wave patterns were really difficult to discern. The outer ring was pretty close in brightness on both sides, but that was hard to estimate because outside of focus the ring spread light into some flaring. That tiny inner ring inside was, neh, fairly bright. So, truthfully, HSA probably lies somewhere between 0.2 and 0.4, probably closer to 0.2. Say, wagging it, 1/4 P-V HSA.
Eddgie
Reged: 02/01/06
      #5526338 - 11/18/12 03:28 PM
Well, this is going to be the problem with even the 33% obstruction... It greatly reduces the influence of HSA, but does not eliminate it, and your result could in fact have been affected by HSA.
By my model suggested a bit of LSA, and this is consistent with your 33% obstruction test. The ratio was maybe 2:1, and that is consistent with about 1/6th wave of SA, which is almost exactly what I put in my model that I posted earlier. I tried to get the second ring to show using more HSA, but that caused the 10 wave test to not match your 10 wave drawing even a little.
Don't you have access to a camera" Even if you can do it afocal, you may be able to use the Roddier test????
I have not used the Roddier test, but I keep telling myself I need to learn how.
But honestly, when the abberations mix, it is not easy to know if your result is being influenced a bit. Maybe the LSA is a bit better than this.. Maybe 1/7th, and the HSA is influencing the test some (which I would think might happen if it is more than a very tiny amount).
As you are seeing, the star test is indeed sensitive to HSA at small defocus amounts, and that is why Suiter says to run the obstruction when testing LSA.
Pinbout
Reged: 02/22/10
Loc: nj
      #5526506 - 11/18/12 05:21 PM
how about laying a piece of black tape across half of your diagonal and using it as a knife edge test on a bright star. you go thru focus to see if the ke spins. you look to see is its a good null at focus where it nulls. if there are abberations you'll start to see donut images like testing a parabola @ center of curvature.
its an easy test and does require a lot of effort.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5526965 - 11/18/12 10:13 PM
Eddgie, yea, thought about trying the Roddier test. I have a old PC cam shoved into an eyepiece barrel and a lap top. Problem is, the scope is not driven.
You're correct, LSA still exists and HSA is residual. It's certainly not perfect. And it's very hard to model in Aberrator, I spent weeks pushing and pulling the simulation just to get it close. You have always said the star test is sensitive, it certainly is.
I guess the main point of this exercise was to evaluate balanced SA, or not. I am convinced by anecdotal and observational evidence it is, indeed, balanced. This, then, beggars the question why the baffle was vignetting when it need not. When the marginal rays lag the reference sphere at best focus in balanced scope, they focus a bit closer to best focus than with LSA alone and need not be cut out of the focus. The overall P-V and RMS improves due to the correction, not the baffle. In fact, the baffle would have very little effect at focus, but make the star test look pretty (it was pretty before.)
In lower order alone, the marginal rays precede the best focus reference sphere centered at best focus (0.7 zone) and the center lags it. The difference is a large P-V figure and gives the wavefront a parabolic(?) shape. When it collapses on itself, it delivers the classic under corrected caustic focus.
If you can imagine the balanced wavefront shaped like a Schmidt corrector figure, you can understand the paraxial wavefront is advanced with respect to the 0.7 zone giving the wavefront that central bulge (similar to the convex central figure on a Schmidt corrector.) And when the marginal wavefront is delayed a bit, it lags the 0.7 zone curling the lip back on itself (not unlike the thickening of a corrector's outer zones.) When this curve collapses on itself, all focal points are closer together improving correction with a shorter caustic. And since the curled lip is very small (while much of the central bugle is masked), the effect is better correction and complicated star test.
Interestingly, I believe the Schmidt corrector leaves the best focus rays untouched, corresponding to the concave section of the corrector. This zone behaves just as if there were no corrector at all, then the varying thickness delays the wavefront just enough to correct all other zones on the point of best focus (leaving the focal ratio untouched.) The Mak meniscus shifts all zones further from the primary, including best focus (giving a slightly longer focal ratio.) Lengthening the primary's radius, then, is partly responsible for the marginal timing "delay," and advancing the paraxial zone, producing the balanced higher order wavefront.
The result is, as Suiter explains, someone reached into the horn and pulled the mouthpiece back through. So, the Schmidt seems corrected at the corrector (which is probably why it's called a "corrector" LOL) and the primary's surface radius is left alone, where the Mak uses the primary's radius to "finish" the correction. Looking for the reason even fast food Maks are pretty darn good, I think balanced correction is it. With HSA corrected, and a bit longer focal ratio, there is no question they can reach a bit better than diffraction limited.
Danny, yea, forgot about the knife edge test. Might have to try that. Thanks. (In fact I played with it using the Ronchi grating as a knife edge to no avail, really.) Not sure how the KE would "spin." But, I can imagine cutting the cone at paraxial focus, for example, should give brighter outer zone (on one side?) Hmmm...been a while using knife edge.
Sorry for the length, fellas...just an interesting exercise to share.
Edited by Asbytec (11/18/12 10:58 PM)
Eddgie
Reged: 02/01/06
      #5527073 - 11/18/12 11:32 PM
I will be the first to admit that your saga has been very interesting, and I would very much like to know the answers to your questions just about as much as you would. I enjoy star testing (and belive in it) so that is part of my interest, but like you, I would like to know the answer to the question about the secondary baffles you are posing.
But like you, I could not get Abberator to churn out a model that worked for me. I feel like I got kind of close at 4 waves, but the result did not work at 10 waves.
That is why I think that a Roddier test would be interesting to see.
We may never know the answer to the question about the baffle. Was it a design error, or was it intentially sized to minimize the influence of the HSA on the star test? We just won't know.
Suiter was apparently right in his own model when he said that the aluminized spot design would experience some HSA if made faster than f/15, but even his own f/12 model could still have a Strehl of .95, which in my book is still excellent.
One of the best mystery stories ever on CN, and the big flurry of informatoin on aperture testing that resulted was (I thought) one of the best threads ever posted here. I learned some really excellent things during that.
Keep us up to date if you make progress.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5527161 - 11/19/12 12:34 AM
You know, it has been a fascinating journey made possible by Ed Holland's monster thread.
Someone mentioned Aberrator HSA term was, in fact, the balanced form. So, there may be no need to add any LSA at all. That may be why it gives us a hard time.
On the baffle design, I can attest to it being very tight. By that, I mean absolutely impossible to see around it from the visual back. Maybe the design was just tight, tighter than it need be. Maybe it was designed so as not to scare the star test crowd (like it did me.) Dunno.
Yes, Suiter's account of his own model seems accurate. A pretty good Strehl and acceptable EER(1). If the model is balanced, as Vlad often says it "must" be, then the correction is very good. If it's not balanced, I suspect you will end up with a lot of under correction and performance like those very bad "China Maks" on Rhor's site - instead of the pretty good performance of the Skywatcher (and many SCTs.)
Will do, Eddgie, Danny. Cheers...
19 registered and 25 anonymous users are browsing this forum.
Moderator:  cbwerner, Starman27, kkokkolis
