Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
52 Orionis
#5511580 - 11/09/12 12:56 PM
After stumbling over this site, I decided to give it a try in 9/10 seeing.
http://www.cityastronomy.com/52-orionis.htm
It was a nice clean split at 163x (12mm UO Ortho 1.6x Barlow), and better split and the "figure 8" diffraction rings at 320x (6mm TMB II) were quite pretty. Both splits showed a clear thin dark line.
Nice double, really. Reminds me much like a smaller Porrima - a couple of headlights way off in the distance. Both seemed pretty much white and close to the same magnitude. Looks to be a good test for 4-6" scopes in good seeing. Not sure of the actual separation, but it's getting close to that of a 6" scope. Maybe a sketch tomorrow.
WRAK
Reged: 02/18/12
Re: 52 Orionis
[Re: Asbytec]
#5511882 - 11/09/12 03:41 PM
According to WDS 1" +6/6mag - textbook values for Dawes limit test. I have to wait until mid January to get Orion in to my field of view. Wilfried
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: 52 Orionis
[Re: WRAK]
#5512390 - 11/09/12 10:19 PM
Yes, thank you, Wilfred. That looks about right. Pretty double for those who want to give it a try.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: 52 Orionis
[Re: Asbytec]
#5512720 - 11/10/12 05:56 AM Attachment (39 downloads)
A sketch...not sure of any flowery colors. Maybe baby powder for both.
Reged: 06/16/04
Re: 52 Orionis
[Re: Asbytec]
#5512750 - 11/10/12 07:04 AM
I enjoy 52 Orionis... When Orion is visible, I start with Rigel, go to Zeta, then Nu and finally 52. I have read some comments that 52 Orionis might be a bit wider than than the 1.0 arc-seconds reported by WDS/Sky Tools...
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: 52 Orionis
[Re: Jon Isaacs]
#5512760 - 11/10/12 07:29 AM
Thank you, Jon.
Okay, gonna hit the others you mentioned tonight, too. I am new to double star observing, a lot of exploring ahead.
Edited by Asbytec (11/10/12 12:59 PM)
coopman
Reged: 04/23/06
Loc: South Louisiana
Re: 52 Orionis
[Re: Asbytec]
#5514492 - 11/11/12 01:35 PM
As long as you're in Orion, don't forget to check out Sigma Orionis.
C_Moon
Reged: 10/23/09
Loc: Virginia
Re: 52 Orionis
[Re: coopman]
#5514894 - 11/11/12 06:38 PM
This is one of those I use to gauge seeing. A nice one I got turned on to from this forum a couple years ago. Got my first glimpse of it this season the other night.
Great sketch, by the way!
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: 52 Orionis
[Re: C_Moon]
#5515023 - 11/11/12 08:17 PM
Sigma, will do. Thank you, both.
Pistorbanic
Reged: 11/06/12
Loc: Ohio, USA
Re: 52 Orionis
[Re: Asbytec]
#5521987 - 11/15/12 09:49 PM
So how hard is it to see 52 Orionis? I have an 8" reflector. Any chance I could split these two stars? Anyone know why it's called '52' Orionis'?
azure1961p
Reged: 01/17/09
Loc: USA
Re: 52 Orionis
[Re: Pistorbanic]
#5522141 - 11/15/12 11:53 PM
With fairly good steady seeing a 1" double should split easily provided you ate at 250x or more preferably though there's always someone who uses less magazine. I don't believe I ever seen this Orion double. Its 52 because it follows 51?
At anyrate it should be doable. Poor seeing where stars refuse to come to focus could make this problematic to impossible.
Pete
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: 52 Orionis
[Re: azure1961p]
#5522220 - 11/16/12 02:43 AM
Sure, as Pete says, it should be very doable in an 8" in descent seeing. I dunno how stars got their number. In order of magnitude, maybe.
Astrodj
Reged: 08/24/11
Loc: Missouri
Re: 52 Orionis
[Re: Asbytec]
#5525018 - 11/17/12 08:14 PM
I tried this one last night along with some others and I had the same impression as you, a smaller Porrima. I have never observed this double, thanks for pointing it out.
The seeing was very good for a change, about 4/6 most of the time. My best view was at 300X with a 4mm ortho. Very pretty double! A clean split in the 10" dob with a thin black space separating the two equal components.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: 52 Orionis
[Re: Astrodj]
#5525094 - 11/17/12 09:05 PM
Hey, you're welcome. Nice going.
ziridava
Reged: 08/17/12
Loc: Arad,Romania,Eastern Europe
Re: 52 Orionis
[Re: Asbytec]
#5537284 - 11/24/12 01:57 PM
Hello
52 Ori is the top gem in a list of six double/ multiple stars in Orion ,described by Norman Lockyer in his book ,,Stargazing-Past and Present'' published at Macmillan and Co., London, 1878. I first passed through this sequence with my 125mm F/7 Dobsonian in 2010,right before Christmas:freezing cold,deep snow ,ocasional wind gust, it took me three and half hours to complete the sequence. I was successful at splitting the first five double/multiple stars but failed on 52 Ori. Only at the third sequence attempt I was able to split 52 Ori. Knowing what to expect and where to look,last week I passed through the Lockyer sequence with success in about ten minutes with the same telescope.This time,I splitted 52 Ori at 144x/6mm Radian eyepiece.
I found this Lockyer sequence inspirational and very entertaining:quaint old Kitchener,Admiral Smith and Sir John Herschel were claping my shoulders ,encouraging me to continue,to go till the end.Which I did:52 Ori is one of my Winter trophee,but not all the time! And I knew from an authoritative source like Norman Lockyer itsef that my telescope ''is by no means to be despised''!
I have an article about the Lockyer Sequence on my blog:
http://observoergosum.blogspot.ro/2011/01/testul-lui-lockyer.html
Here is a link to download from ,,archive.org'' the whole book ''Stargazing-Past and Present'' by Norman Lockyer:
http://ia700406.us.archive.org/34/items/stargazingpasta01seabgoog/stargazingp...
Mircea .......................................................
Quotes from ‘’STARGAZING: PAST AND PRESENT’’ by J.Norman Lockyer
London. MACMILLAN AND CO. 1878
Book II,CHAP. XII,page 164-166
‘’The convenient altitude at which Orion culminates in these latitudes renders it particularly eligible for observation ; and during the first months of the year our readers who would test their telescopes will do well not to lose the opportunity of trying the progressively difficult tests, both of illuminating and separating power, afforded by its various double and multiple systems, which are collected together in such a circumscribed region of the heavens that no extensive movement of their instruments an important point in extreme cases will be necessary.
Beginning with DELTA, the upper of the three stars which form the belt, the two components will be visible in almost any instrument which may be used for seeing them, being of the second and seventh magnitudes, and well separated.
The companion to BETA though of the same magnitude as that to DELTA , is much more difficult to observe, in consequence of its proximity to its bright primary, a first-magnitude star. Quaint old Kitchener, in his work on telescopes, mentions that the companion to Rigel has been seen with an object-glass of 2 3/4-inch aperture ; it should be seen, at all events, with a 3 -inch.
ZETA the bottom star in the belt, is a capital test both of the dividing and space-penetrating power, as the two bright stars of the second and sixth magnitudes, of which the close double is composed, are exactly 2.5" apart, while there is a companion to one of these components of the twelfth magnitude about 3/4 seconds distant. The small star below, which the late Admiral Smyth, in his charming book," The Celestial Cycle," mentions as a test for his object-glass of 5*9 inches in diameter, is now plainly to be seen in a 3 3/4 inch. The colours of this pair have been variously stated ; Struve dubbing the sixth magnitude which, by the way, was missed altogether by Sir John Herschel "olivaceasubrubicunda."
That either our modern opticians contrive to admit more light by means of a superior polish imparted to the surfaces of the object-glass, or that the stars themselves are becoming brighter, is again evidenced by the point of light preceding one of the brightest stars in the system composing SIGMA . This little twinkler is now always to be seen in a 3 3/4-inch, while the same authority we have before quoted -Admiral Smyth -speaks of it as being of very difficult vision in his instrument of much larger dimensions. In this very beautiful compound system there are no less than seven principal stars ; and there are several other faint ones in the field.
The upper veryfaint companion of LAMBDA is a delicate test for a 3 3/4-inch, which aperture, however, will readily divide the closer double of the principal stars which are about 5" apart.
These objects, with the exception of ZETA, have been given more to test the space-penetrating than the dividing power ; the telescope's action on 52 Orionis will at once decide this latter quality. This star, just visible to the naked eye on a fine night, to the right of a line joining ALPHA and DELTA, is a very close double. The components, of the sixth magnitude, are separated by less than two seconds of arc, and the glass which shows a good wide black division between them, free from all stray light, the spurious disk being perfectly round, and not too large, is by no means to be despised.
7331Peg
Sirius Observer
Reged: 09/01/08
Loc: North coast of Oregon
Re: 52 Orionis
[Re: ziridava]
#5537313 - 11/24/12 02:23 PM
You can't miss with the good Admiral Smyth, Sir John Herschel, and Norman Lockyer looking over your shoulder, Mircea. I've got both 52 and 32 Orionis on my list for the next clear nights.
Thanks for the link to that book. There's a fabulous picture of someone (Mayall?) sitting at the eyepiece end of a huge refractor -- no idea where that was taken, but you can almost hear the creaking of machinery and smell the cold air in the dome. It's page 11 using the page numbers of the .pdf format.
Clear Skies!
John
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: 52 Orionis
[Re: 7331Peg]
#5537446 - 11/24/12 04:00 PM
Thank you for the link, Mircea. Interesting and good on ya.
fred1871
Reged: 03/22/09
Loc: Australia
Re: 52 Orionis
[Re: Asbytec]
#5537883 - 11/24/12 09:31 PM
Good one, Mircea, getting it with moderate magnification - and thanks for the quoted material from Lockyer. 52 Ori is a bit closer these days than it was in the 19th century, as the Struve measure in 1824 is given as 1.7". One of my older reference books gives the separation as 1.5" in 1957. And going with Jon Isaacs' comments above, WDS lists a 2011 measure of 1.1", not 1.0.
Because it's bright, as well as close, air steadiness appears to affect resolving it more than some. I've found I need different magnifications on the same telescope on different nights for this one, depending on the seeing. It's a fine pair when you get a steady view.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: 52 Orionis
[Re: fred1871]
#5537928 - 11/24/12 10:08 PM
John, just noticed your web site listed. Fascinating stuff. Thanks, mind if I browse it? Use it?
7331Peg
Sirius Observer
Reged: 09/01/08
Re: 52 Orionis
[Re: Asbytec]
#5538109 - 11/25/12 12:34 AM
No, please go right ahead. After a couple of years adding to that site, there's a lot of material there for reference.
If you search for something, you're probably better off to use the search window instead of the Select Category window. Wordpress has made a change in the way those constellation selections come up which doesn't work as well as it used to.
John
Moderator: PJ Anway, RLTYS
