What if m=ec^2?
#1
Posted 19 November 2012 - 06:14 PM
/Ira
#2
Posted 19 November 2012 - 09:11 PM
#3
Posted 19 November 2012 - 09:24 PM
/Ira
#4
Posted 20 November 2012 - 05:38 AM
"The hurrier I go, the behinder I get." — Lewis Carroll
#5
Posted 20 November 2012 - 10:09 AM
#6
Posted 20 November 2012 - 02:52 PM
Rearranging to e=m/c^2
Pesse (I think that would lead to a massive change in the Universe.) Mist
#7
Posted 20 November 2012 - 03:12 PM
Jarad
#8
Posted 20 November 2012 - 04:27 PM
Cleveland.
Oh....noes! OK, it could be worse; it could look like Camden, NJ.
#9
Posted 20 November 2012 - 04:33 PM
Well, then stars would run out of fuel much faster, because mass would suddenly carry a lot less "bang for the buck", so to speak. C^4 less bang, to be exact....
Jarad
If so, the vast majority of primordial disks of gas and dust that have formed stars under e = mc^2 would not have enough energy to ignite the fusion process under m=ec^2 in the first place, and most of the mass which is now stars would instead be tied up in more massive versions of not-enough-for-prime time balls of gas like Jupiter.
#10
Posted 20 November 2012 - 05:01 PM
Thanks for the particulars which are beyond my skills! How could such a universe even originate and proceed from a "Big Bang"?
#12
Posted 20 November 2012 - 11:23 PM
Jarad
It probably goes beyond that. I'm not sure that matter as we know it would even be able to exist under those conditions. Doesn't that relationship pervade all the forces of matter?
#13
Posted 21 November 2012 - 07:36 AM
if it began as e, then we would have a whole lot more m around.
stars would form sooner and get bigger, and would not fusion take place at the same star mass just produce less e
but if we started with m then we would have same stars producing less e , therefore getting much denser before going supernova or perhaps no supernovas because gravity would be able to counter act the reduced e and resulting in "slightly above average Novas"
or mediocrenovas
#14
Posted 21 November 2012 - 08:22 AM
In our universe the equation for gravity is F = G*M1*M2/R^2. For this test, you will be calculating orbits in a universe where gravity is F = G*M1*M2*R.
I remember looking around and seeing the sweat popping out on everyone else's foreheads, too, as we realized we were going to have to re-derive all of the formulas we had memorized.
Jarad
#15
Posted 21 November 2012 - 02:09 PM
In a world where e=m/c^2, energy would have the units of mass * time^2 / distance^2. I guess kinetic energy would be 1/2 m/v^2 - i.e. the smaller the speed, the larger the kinetic energy. I can't even begin to imagine what that universe looks like.
#16
Posted 21 November 2012 - 03:01 PM
Keep in mind that a physics formula doesn't deal with numbers, they deal with physical quantities with units. e=mc^2 works because energy has the unit of mass * distance^2 / time^2. A Joule equals kg*m^2/s^2.
Pesse (Just tap it in. Just tap it in. Give it a little tappy. Tap Tap Taparoo.) Mist
#17
Posted 21 November 2012 - 03:18 PM
Does that mean that NASCAR in that universe would be a contest to see who can go the slowest around the track?
Jarad
#18
Posted 21 November 2012 - 03:25 PM
E=M/C^2 means it takes very LITTLE energy to fuse two atoms..bascially coming within smell distance of each other ought to do it.
No need for stars to run fusion reactions. Atoms will combine willy-nilly just bumping into each other where kinetic energy would overcome the strong nuclear force.
So after the Big Bang the quark soup would rapidly coalesce into hydrogen atoms which would then keep fusing until the process resulted in the most stable atomic arrangement possible.
Pesse (Basically the Universe would be one big block of lead.) Mist
#19
Posted 21 November 2012 - 03:58 PM
#20
Posted 21 November 2012 - 05:20 PM
Well, in fact the equilibrium inside stars (attractive gravity and central high pressure~temperature) means that energy has some "weight"
My point was, all other things being equal, that fusion wouldn't require stars. In fact tiny grains would fuse..and fuse..and fuse again until you had lead.
You wouldn't need stars for this and all that lead would collapse down under its own weight since there would be no 'energy' pushing back.
A star is in equilibrium when the energy released during the fusion process exactly pushes back against the gravitational collapse.
When a star uses up all available fusion fuel then, depending on the mass of the star, it'll collapse down to a black hole or trigger a last hurrah known as a supernova which is the Universes way of puking out all the heavy elements.
Pesse (Sort of like a used up college student after an all weekend beer-bender) Mist
#21
Posted 21 November 2012 - 11:11 PM
#23
Posted 22 November 2012 - 07:55 AM
The good news is it would take less gas to go fast than to go slow.
Jarad
If they put restrictor plates on the universe, I'm leaving. But you know how scientists are, all they want to see is bunching and crashing at horizons...
-drl
#24
Posted 26 November 2012 - 01:45 PM
Jarad
-drl
Pesse (Well, without restrictor plates everyone would just sit there.) Mist
#25
Posted 26 November 2012 - 01:54 PM
