CharlesW
Reged: 11/02/12
Loc: Chula Vista & Indio, CA
Jupiter is a blown-out, white, disk
      #5532032 - 11/21/12 11:27 AM
Good morning folks, last night I spent some time trying to image Jupiter for the first time and all I could get is what looked like an extremely over-exposed, white disk. Here's the equipment:
Celestron 8" CPC
Canon 50d
Not using a Barlow
Backyard EOS
Registax
I was using the planetary mode in EOS to write video, about 400 frames. I tried iso settings from 200 to 1600. Even just looking at it in EOS it was just a white ball with none of the detail I could see using an eyepiece. Focus was good. No amount of histogram stretching was helping.
Do I need a filter to knock the brightness down? I can't imagine that dropping iso to 100 is going to help much. Or, is there something else I'm doing wrong?
Tapio
Reged: 09/24/06
Loc: Tampere, Finland
Re: Jupiter is a blown-out, white, disk new [Re: CharlesW]
      #5532082 - 11/21/12 11:47 AM
It's best to use lowest ISO (100?) with planets.
Don't know if you can adjust exposure with 50D/video but if you can then you should do that.
Magick Lantern can do this but this is another matter and maybe you should try something else first.
http://magiclantern.wikia.com/wiki/Magic_Lantern_Firmware_Wiki
ToxMan
Reged: 01/23/11
Loc: Tucson, Arizona, USA
      #5532099 - 11/21/12 11:55 AM
Use a barlow, don't stretch histogram. Generally, I don't use a DSLR to get video. But, on my Olympus, I can adjust my shutter speed for video mode and keep image from being "over-exposed." And, my camera only has 2 frame rates for video mode. Jerry Lodriguss and some others have tutorials for imaging with a DSLR, whether it is planets or deep sky.
skywatch
Reged: 02/06/08
Loc: Ottawa 45.3085N 76.175W
Re: Jupiter is a blown-out, white, disk new [Re: ToxMan]
      #5532112 - 11/21/12 12:01 PM
You probably need to set the liveview exposure to manual (simulated exposure) rather than automatic. Not sure where that is on the 50d.
-Rolf
RedLionNJ
Reged: 12/29/09
Loc: Red Lion, NJ, USA
Re: Jupiter is a blown-out, white, disk new [Re: skywatch]
      #5532288 - 11/21/12 01:36 PM
I see no mention of exposure length. What are you using? I typically use somewhere between 1/10 and 1/50 of a second, depending on the transparency and optical train.
Grant
25 registered and 31 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
