Atl
Reged: 04/13/12
Aftermarket Push-To systems
      #5532299 - 11/21/12 01:40 PM
Are there any commercially produced push-to systems to put on home made dobs out there that anyone knows about?
Dave Ittner
Reged: 05/29/12
Loc: SF Bay Area, California
Re: Aftermarket Push-To systems new [Re: Atl]
      #5532391 - 11/21/12 02:31 PM
Not that I am aware of but have you researched putting setting circles on your dob and then adding an inexpensive digital angle gauge?
http://www.harborfreight.com/digital-angle-gauge-95998.html
Google setting circles for a dob. Someone in our club did this for his 8" dob. I have pictures if you are interested.
City Kid
Reged: 05/06/09
Loc: Northern Indiana
      #5532393 - 11/21/12 02:31 PM
Sky Commander from Sky Engineering is one.
Traveler
Reged: 08/19/07
Loc: The Netherlands
Re: Aftermarket Push-To systems new [Re: City Kid]
      #5532401 - 11/21/12 02:34 PM
Wildcard's Argo Navis is another (controller). They also making digital setting circles.
Gastrol
Reged: 11/04/11
Loc: los angeles
Re: Aftermarket Push-To systems new [Re: Traveler]
      #5532426 - 11/21/12 02:52 PM
If your ground board is round you can easily add an azimuth setting circle. You use your smart device to locate objects.
dan_h
Reged: 12/10/07
      #5532494 - 11/21/12 03:29 PM
I recently picked up a used but very useable NGC MAX down in the swap shop on CN. Lots of documentation on the net.
dan
beatlejuice
Reged: 04/05/11
Loc: Hamilton, ON,Canada
      #5532644 - 11/21/12 04:57 PM
Check out the Halo in the vendors forum
Eric
Atl
Reged: 04/13/12
Re: Aftermarket Push-To systems new [Re: beatlejuice]
      #5533128 - 11/21/12 11:23 PM
Anyone use these?
http://www.astronomy-shoppe.com/ScopeScout.htm
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
      #5533144 - 11/21/12 11:40 PM Attachment (18 downloads)
A possible alternative is a laser Point-To system. Briefly… take an el cheapo GoTo system and add a laser pointer to it. Use the el cheapo GoTo system to point the laser at your target, and then follow the beam out to the end with your scope. I was originally going to use a spare ETX system for mine, but I ended up putting together a system from spare parts; a #884 tripod, DS-2000 mount, 2045S scope, and an Orion laser pointer. I put this together to help me point my homebuilt 16.5” f/6.5 Newtonian, but the beauty of it is that it works with any scope. I’ve recently been using it with my LightBridge 16 and it works like a charm.
Edited by jgraham (11/21/12 11:58 PM)
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
Re: Aftermarket Push-To systems new [Re: Dave Ittner]
      #5533154 - 11/21/12 11:48 PM
There is a thread that is a Sticky at the top of this forum with many showing how they put "degree/setting" circles on their dobs.
Degree Circles
The HALO actually was born partially due to this thread.
Dave Ittner
Reged: 05/29/12
Re: Aftermarket Push-To systems new [Re: csa/montana]
      #5533257 - 11/22/12 01:26 AM
Thanks Carol. I completely spaced out and missed posting a link to that sticky post.
tezster
Reged: 07/14/09
Loc: Missisauga, Canada
      #5533545 - 11/22/12 08:50 AM
As a slightly different option, you can take a look at Astro Devices' wireless interfaces; they can be connected directly to encoders.
This then allows you to wirelessly connect to an Android tablet or iDevice running compatible planetarium software (SkySafari, for example) and use that as your "DSC" computer.
Achernar
Reged: 02/25/06
Loc: Mobile, Alabama, USA
      #5533880 - 11/22/12 12:32 PM Attachment (20 downloads)
Sky Engineering offers their Sky Commanders, JMI offers digial setting circles, and there there are those offered by Argo Navis. All can be fitted to Dobs and I know the Sky Commanders and JMI's can also be mounted on equatorial mounts as well. I use JMI's on my 10-inch and Sky Commanders on my 15-inch. The JMI's are good, the Sky Commanders are better. I do not have any experience with the Argo Narvises, but they are much more expensive the the other two choices. You will be fine with the Sky Commanders.
Taras
audioaficionado
Reged: 05/24/12
Loc: Medford, Orygun, USA
Re: Aftermarket Push-To systems new [Re: Achernar]
      #5543055 - 11/27/12 11:14 PM
The aforementioned HALO Setting Circle-Leveling Base looks interesting, but I don't have much confidence in composite that thin with the full weight of a dob plus accessories sitting on it.
Mike B
Starstruck
Reged: 04/06/05
Loc: shake, rattle, & roll, CA
Re: Aftermarket Push-To systems new [Re: jgraham]
      #5543175 - 11/28/12 01:07 AM
My observing group has used John's "laser Point-To system"... or a version of it; we used my Dob, having both SkyCommander *AND* a green-laser! I'd cue the object on the SkyCom, find it in the scope's view, then "light-it-up" with the GLP... and all my buddies would aim their scopes down my GLP's beam.
We called it "cheating". Was eminently more fun than playing fair.
An "el cheapo" GoTo scope from WalGetCo, having funhouse optics & plastic eyepieces, but a functional computer-locator, would make a marvelous platform for mounting a GLP... & spend hours cheating one's way thru the heavens!
John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
      #5543419 - 11/28/12 08:47 AM
I like the Manortronic 'AstroFix' 2 axis locator for Dobs, around £87/$139
http://www.manortronics-force-gauges.com/Astro
rick-SeMI
Reged: 01/08/11
Loc: Michigan - USA
      #5543431 - 11/28/12 08:56 AM
Look ma no wires
http://www.astrodevices.com/products/BETI/BETI.html
SkyCommanders encoders and arms may work with this system.
In Fact you may be able to use their cable also since the BETI uses an 8-pin RJ-45 too.
And a cheaper route would be to use the CUI AMT-102 capacitive encoders.
I got a PAIR of them from Digi-Key for around $48 when I built my Dave Ek, Bluetooth capable DSC's, for the DobStuff 16" depicted here.
http://www.cloudynights.com/ubbthreads/showflat.php?Cat=&Board=atm&Nu...
Edited by rick-SeMI (11/28/12 09:28 AM)
tezster
Reged: 07/14/09
Re: Aftermarket Push-To systems new [Re: rick-SeMI]
      #5543853 - 11/28/12 12:57 PM
Look ma no wires
I can confirm this does work - it's the exact setup I use
Project Galileo
Reged: 11/14/07
Loc: Jefferson County, Colorado
Re: Aftermarket Push-To systems new [Re: tezster]
      #5543966 - 11/28/12 02:17 PM
If you have a droid with GPS try Skeye. It is available at the google play store for free or there is an upgraded pro version for $9. It works quite well. The free version is loaded but the pro version is well worth the $9. I use with with my telescope mounted as a push to devise and as a mobile planetarium much like google sky map. It is really an amazing app. Check it out.
orion61
Vendor(Clear Edge Optical)
Reged: 10/20/07
Loc: NW Iowa BURRRR
      #5544222 - 11/28/12 05:01 PM
JMI (Jims Mobile Inc) makes a great system
The JMI Max, I still have a MiniMax no longer available but going strong. works great!
Also makes the Micro Max. they can be used for virtually any type of mount.
just choose from the menu EQ, az Alt, Dob.
I have owned 2 and they are very accurate, mine centers in the field every time at 2000mm FL! better than my LX200!
3 registered and 9 anonymous users are browsing this forum.
Moderator:  Jarad, tecmage
