tonyt
Reged: 09/02/09
Loc: Australia
Re: Astro Tech AF 70 eyepieces? new [Re: Scanning4Comets]
      #5143376 - 03/27/12 06:01 AM
I've used 22mm and 17mm in the astro-tech AF and bulky celestron versions. Both eyepieces handled fast scopes well. The AF is aesthetically nicer but the Celestron LX is more comfortable to use with it's adjustable eyeguard.
Tony
SStoffer
Reged: 04/15/11
Loc: Grand Rapids, Michigan
Re: Astro Tech AF 70 eyepieces? new [Re: Phillip Creed]
      #5144009 - 03/27/12 01:53 PM
I have both the 13 mm and 17 Celestron Ultima LX. The 17 is great, one of my best eyepieces. However, the 13 has an annoying field darkening near the center of field surrounded by a lighter field of view near the edges. I like my fields to be more uniform in appearance.
I also have the 32 mm which is used as my finder eyepiece for my LightBridge. The edge of field performance I tried to improve with an Baader MPCC coma corrector and visual ring set. But so far just minimal improvement.
- Stephen
Scanning4Comets
Markus
Reged: 12/26/04
Loc: Ontario, Canada
Re: Astro Tech AF 70 eyepieces? new [Re: SStoffer]
      #5524367 - 11/17/12 01:24 PM
Thanks you guys! I bought the 17mm and really like it!
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
      #5524795 - 11/17/12 05:58 PM
- Stephen
I'm very sensitive to such things and didn't see that in the 13. I believe you might have been holding your eye a little too close to the lens. It's easy to do on the shorter focal lengths.
I presume you mean 22mm on the LB finder.
SStoffer
Reged: 04/15/11
Re: Astro Tech AF 70 eyepieces? new [Re: Starman1]
      #5527289 - 11/19/12 03:15 AM
- Stephen
No, it is the 32mm Celestron Ultima LX on the LB finder.
Also, you may be right on the 13, the last time I used it I didn't see the edge of field brightening. But the times I have seen it it was only with this eyepiece.
Clear Skies, Stephen
Edited by SStoffer (11/19/12 03:18 AM)
Sorny
Reged: 03/15/12
Loc: Southern MN
Re: Astro Tech AF 70 eyepieces? [Re: SStoffer]
      #5533261 - 11/22/12 01:33 AM
I've got the AF70 eyepieces and use them (when not binoviewing) on my slow f/10 CPC1100...
I have the 8, 13, 17, and 22mm from the set, and all are good. The 8mm gets little use due to prevailing seeing conditions, but the 13, 17, and 22 get a lot of use and I've no complaints. For the modest price, they offer great performance.
20 registered and 25 anonymous users are browsing this forum.
Moderator:  ausastronomer, droid, Scott in NC
