Telescope Specific Forums >> NexStar GPS / CPC Telescopes
James Cunningham
Reged: 08/07/10
Loc: Maryland
Strange problem with electronics new
      #5533496 - 11/22/12 07:59 AM
This has happened a few times. My scope gets it power from a 13.8 regulated power supply. A few times, when I turn on the scope, the power light comes on but the handset does not. Then I will turn off the power and replug the handset and everything works fine. Any ideas what would cause this? Thanks. I do not believe its the handset because when it is like this, I can't connect to Nexremote either.
Reged: 07/06/07
Re: Strange problem with electronics [Re: James Cunningham]
      #5534191 - 11/22/12 04:40 PM
Which scope? Which firmware build for the HC?
Footbag
Reged: 04/13/09
Loc: Scranton, PA
Re: Strange problem with electronics new [Re: rmollise]
      #5535297 - 11/23/12 11:30 AM
Could one of the pins in the handset not be seating correctly?
Reged: 07/06/07
Re: Strange problem with electronics new [Re: Footbag]
      #5535679 - 11/23/12 02:53 PM
Some revs of the firmware have this very problem. If your HC has an older version, update it.
James Cunningham
Reged: 08/07/10
Loc: Maryland
      #5536836 - 11/24/12 09:01 AM
Its a Celestron 11 inch SCT. The HC firmware is 4.21.
1 registered and 4 anonymous users are browsing this forum.
Moderator:  BRisley
