Privacy Policy |
Please read our Terms
of Service | Signup and
kpendlebury
Vendor Main Sequence Software
Reged: 11/12/08
Loc: Central TX
Sequence Generator - Image Capture Suite 2.1.14
#5535414 - 11/23/12 12:39 PM
Sequence Generator is a powerful image capture suite that supports equipment profiling for easy sequence generation, powerful event sequencing, auto focus, automatic precision target centering, click-to-center, automatic meridian flipping (using PHD) and hundreds of other features.
To find out more visit our site at www.mainsequencesoftware.com
Notes - Auto flipping is still not yet compatible with Takahashi mounts (working on this with Chuck F). Getting close now...
Changes - Images solved with Pinpoint now have stars with proper names (modern names) labeled - Added feature that allows for selecting an "override" filter for use during auto focus (should not be used unless you have tested that your filters are parfocal) - Solve and sync and auto meridian flips now respect the plate solve override filter - Increased range for AF step size - Added option for QSIs to disable hi-speed readout during frame and focus and plate solving - Last focus time and temp are no longer reset if the camera is disconnected - Reduced the auto focus max star count to 300 (from 1000). This should be more than sufficient to calculate a mean HFR - Changed the way auto focus detects star collisions (gets better data) - A warning is now generated if you attempt to start a sequence with an active target and no active events - An error is now generated if you attempt to start a sequence with the telescope in the park position (assuming the sequence requires a telescope)
Fixes - Hot keys (keyboard shortcuts) are no longer active outside of SGPro - Fixed a bug where AF frames with too much data took a long time to calculate HFR - Fixed a bug that would cause SG to crash when swapping events with over 100 frames - Fixed a bug that would fail to reset events above six - Fixed a bug that would attempt to center on a sequence that was past its end time - Auto flipping now honors the scope settling delay - Fixed a bug where new sequences prompted for save - ASCOM cameras properly checks if driver supports retrieving cooler power before requesting it now - If you paused guiding during auto focus, it will now stay paused until you are done (even if you try again) - Fixed a bug where guiding would sometimes not pause on auto focus (assuming you have is checked)
As always, you can find it here: http://www.mainsequencesoftware.com/downloads.php
3 registered and 13 anonymous users are browsing this forum.
Moderator: BRisley, bilgebay
