Peter Natscher
Reged: 03/28/06
Loc: Central California
C8 1.25" Eyepiece Choices
      #5536121 - 11/23/12 07:23 PM
I've noticed that the Celestron C8 uses only a 1.25 dia. eyepiece barrel. Since I'm used to using mostly 2" dia. eyepieces for observing with my larger scopes, what eyepieces might I use with a C8, especially for lowest power observing?
Eddgie
Reged: 02/01/06
Re: C8 1.25" Eyepiece Choices new [Re: Peter Natscher]
      #5536439 - 11/23/12 11:21 PM
With a 2" diagonal, you can use any 2" eyepiece you want, though the optimal would be eyepieces with field stop of 38mm. Wider than this and the very edge of the field will loose faint stars. But that only matters if it matters to you.
Tom and Beth
Reged: 01/08/07
Loc: Tucson, AZ
      #5536468 - 11/23/12 11:47 PM
What Eddgie said. A TV 35 Pan has a 38.7MM field stop, yet I doubt you would notice the slight narrowing of the field of view. My speadsheet shows you'll have a tad over a full degree field of view at 58X with this EP.
Eddgie
Reged: 02/01/06
      #5536825 - 11/24/12 08:54 AM
If you want to stay with 1.25", a 24mm Pan, Es, or Hyperion with a 6.3 reducer will work or just the eyepieces.
7 registered and 10 anonymous users are browsing this forum.
Moderator:  Cotts, Starman27
