Privacy Policy | Please read our Terms of Service | Signup and Troubleshooting FAQ | Problems? PM a Red or a Green GuÖ uh, User
Observing >> Variable Star Observing and Radio Astronomy
Michael Rapp
Reged: 04/27/04
Loc: Dickinson, TX
Is there enough uncertainty out there for visual? new
      #5532197 - 11/21/12 12:42 PM
Hi all,
I am curious about observing variable stars. A while back while sweeping through the Milky Way in Cassiopeia, I happened to stumble upon this dark red star. Most stars upon first glance appear white to me, so this star looked like a small ruby in a sea of diamonds.
I did some research and discovered that this star, WZ Cas, is a carbon star and that carbon stars are variable stars. Moreover, Iíve learned that carbon stars can be quite challenging to do visual magnitude estimates on due to their deep red color and the purkinje effect.
Iíve always been curious about variable star and the AAVSO. Many observers, such as David Levy, are active observers and seem to really, really enjoy it.
I already know that one of the aspects of variable star observing I would really enjoy: the star hopping. I love finding those needles in haystacks.
Reading about variable stars, periodic variables have not captured my interest. It seems to me that such stars like Cepheids and Miras are well understood and the periodicity of their variability is well established. Please correct me if I am wrong on this.
The stars that seem to interest me are the unpredictable ones, the irregulars, if you will. Observing a star that might brighten or dim unpredictably is fascinating to me. Here, this seems much more fun that recording observations of a star that has had the same light curve for centuries. (Of course, I can clearly see how starting off with Cepheids or Miras is great practice due to their known and predictability.)
So my question is this: are there enough irregular or otherwise unpredictable stars within the range of a small refractor to form a decent visual observing program?
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
Re: Is there enough uncertainty out there for visual? new [Re: Michael Rapp]
      #5532915 - 11/21/12 08:24 PM
Hi Michael:
Visual estimates are valuable because many variables reach magnitudes that are too bright for CCD observation. Its not the CCD, its the fact that comparison stars may not be in the same FOV and most amateurs do differential rather than all-sky photometry. So during the minimums CCD rules while when they are bright visual rules. DSLRs with wide fields or CCDs using lenses are exceptions but you do have to worry about scintillation effects. There is room for all. Naturally you need training and practice and the Miras are perfect training stars. BTW, Miras can change their periods, so continuing observations are scientifically valuable.
Ed
Michael Rapp
Reged: 04/27/04
Loc: Dickinson, TX
Re: Is there enough uncertainty out there for visual? new [Re: Ed Wiley]
      #5533033 - 11/21/12 10:12 PM
Hi Ed,
Thanks for replying. I never thought of the small FOV of the CCD as being as issue, but it makes perfect sense.
I've picked two stars to estimate to see if I stick with this: Delta Cephei and Beta Persei. They seem to have short enough periods that I should be able to match up my observations with a light curve to see how far off I am from others' estimates.
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
      #5533075 - 11/21/12 10:44 PM
Good luck, Michael; visual estimates are still valuable and it sounds like you are on your way. I assume you have downloaded the AAVSO visual manual and checked the AAVSO site for information. BTW, you do not need to be an AAVSO member to submit observations and (I think) download manuals.
Clear skies and good measures,
Ed
Hubert
Reged: 09/26/06
Loc: Belgium
      #5533246 - 11/22/12 01:16 AM
Hi Michael, you were asking about unpredictable variable stars. It's true that mira stars change periods and amplitude but the real unpredictable stars are the cv's and R CrB stars. They have sudden outbursts and some go faint in a few days or weeks. For most of them you need a large telescope like minimum a 8".
You can find a program for these stars at the cv section of the AAVSO.
https://sites.google.com/site/aavsocvsection/
Hubert
Rich (RLTYS)Moderator
Reged: 12/18/04
Loc: New York (Long Island)
      #5533465 - 11/22/12 07:32 AM
There are enough variables observable with a small refractor to keep you busy a dozen lifetimes.
Miras are well understood but there max and min can vary during each cycle. You can have a nice variable star program with binoculars.
I also enjoy semiregulars and irregulars.
Rich (RLTYS)
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
Re: Is there enough uncertainty out there for visual? new [Re: Rich (RLTYS)]
      #5534058 - 11/22/12 02:40 PM
Michael:
I don't know if this will work for you, but here is how I started.
I learned how to use the AAVSO nightly planner. I looked at Miras to begin with and those with recent observations.
I learned how to look up the recent observations.
I then picked some stars within my magnitude range so that I could compare my results with both the recent observations and the trend. I then downloaded the appropriate AAVSO finder charts and tried my hand at estimating magnitude.
That way I could build confidence that my observations were in line with more experienced observers. I did not worry about particular stars at first, only whether my results were similar to reported results.
Once I gained some confidence I felt I could branch out.
Good measures!
Ed
Keith g
Reged: 02/13/05
Loc: Waterford/Cavan Ireland
      #5536716 - 11/24/12 07:29 AM
Hi all, just to add to this Michael, you could also consider using the 'Binocular Variable' star program here:
http://www.aavso.org/aavso-binocular-program
Granted, there are a lot of Mira's and other predictable stars, but also some interesting one's too. Some would certainly suit your refractor.
Also, you could consider looking for a nova, or indeed revisit older novae of the pat that just may blow again. There are a lot of details here:
http://www.cbat.eps.harvard.edu/nova_list.html
I hoe that this helps.
Keith.
Michael Rapp
Reged: 04/27/04
Loc: Dickinson, TX
Re: Is there enough uncertainty out there for visual? [Re: Keith g]
      #5537161 - 11/24/12 12:16 PM
Thanks Ed, Keith!
Ed - I going to use your suggestion to help me pick stars for which I can easily compare my estimates with others afterwards. This estimating is more challenging that it initially seems. David Levy in his variable star book has an exercise in which you take the stars of a constellation or asterism and sort them according to brightness. This is not as easy as it seems for stars that are relatively close in brightness.
Keith - yes, I stumbled upon the binocular program last night and this seems great. Here are stars that are relatively easy to find in an instrument that I can easily take out often. In fact, I'm considering using my binoculars more often as dealing with mirror-reversed charts drives me crazy.
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
      #5538043 - 11/24/12 11:29 PM
Good luck Michael. Practice, practice. Levy's book is a good start with some "easy" and interesting pairs.
Ed
nytecam
Reged: 08/20/05
Loc: London UK
      #5571316 - 12/14/12 06:44 PM
Cataclysmic variables [cv] may float your boat for unpredictability and keep you on your toes but they can be quite faint even at max and most need a large aperture scope. An announced outburst may get the pro turning their scopes/spectroscopes on them as they 'flicker' away before fading back to min over a few days
MG1962
Reged: 08/13/11
Re: Is there enough uncertainty out there for visual? new [Re: nytecam]
      #5576753 - 12/18/12 02:16 AM
Observing variable stars is very much drudge work designed to create data points measured in generations. I concentrate exclusively on long period variables - with particular focus on the legacy program that will have observations going back 150 years
There is a chronic shortage of observers and many variable stars are simply neglected and could have had major changes in their light curve that have gone completely undetected.
Most importantly you need to find the type of variable star you enjoy observing. Especially if that motivates you to get out and use your equipment. Any variable star observation is better than none
Michael Rapp
Reged: 04/27/04
Loc: Dickinson, TX
Re: Is there enough uncertainty out there for visual? new [Re: MG1962]
      #5576970 - 12/18/12 09:11 AM
Still exploring and getting familiar with variable stars. I'm actually at the point where I'm still practicing with Algol!
One thing that helps is that I've become very honest with my observing time and observing habits. The instrument with which I'm able to get out and observe with any frequency are my 7x50 binoculars. I've been doing some careful measurements with the Pleadies near the meridian and have determined that my limiting magnitude with that instrument is about 7 to 7.5. Not much, but one works with what one has.
So, I'm really starting to look at the AAVSO's binocular program. And, of course, as a tripod helps (is required for?) for accurate magnitude measurements, stepping up to a set of binoculars with a greater light grasp is a possibility.
MG1962
Reged: 08/13/11
      #5577172 - 12/18/12 11:39 AM
Michael one of the things I did when starting was to measure a star then check the data on the AVVSO website to see how close I was getting. Once I had the confidence I was getting in the ballpark with other observers I began to report my measurements
Moderator:  Rich (RLTYS)
