MHamburg
Reged: 06/21/06
Loc: Brooklyn, NY/Berkshires, MA
RA Slop Tolerance?
      #5537531 - 11/24/12 04:58 PM
Just finished an Ed Thomas hypertune and am left with a bit of slop in the RA axis. Adjusted this as best as I could with the mount balanced (weighted slightly to the east) and fully loaded (Edge 11 HD), but could not get all the wiggle out. Motor sounds fine at slew rate 9, But I haven't gotten a chance to test it out under the stars yet. How obsessive should I be? What is tolerable?
Michael
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: RA Slop Tolerance? new [Re: MHamburg]
      #5537569 - 11/24/12 05:21 PM
I have no idea. What's the mount?
The best measure would be to look at the RMS error when guiding. Too much slop or too tight a worm engagement would affect the RMS guiding error.
On my CGEM using a 200mm finder, the best I can get is about 0.18 pixels RMS. This amounts to a bit less than 2" of error. Yes it's not too great...
RTLR 12
Reged: 12/04/08
Loc: Capistrano Beach, Ca
Re: RA Slop Tolerance? new [Re: orlyandico]
      #5537876 - 11/24/12 09:26 PM
Did you adjust the worm gear shaft end play?
Stan
MHamburg
Reged: 06/21/06
Re: RA Slop Tolerance? new [Re: RTLR 12]
      #5538741 - 11/25/12 01:38 PM
Sorry to omit it is a CGEM. Yes I believe I eliminated the worm gear shaft end play (but now I am doubting myself.) I would like to avoid tearing down the mount again.
Michael
RTLR 12
Reged: 12/04/08
      #5539163 - 11/25/12 05:47 PM
There is no tear down required to check or adjust the end play. Just pull the cap off the end of the axis shaft so you can see the end of the shaft and wiggle the RA axis back and forth. Look for movement at the end of the shaft. If there is movement you need to adjust the slotted bearing retaining nut until the play is gone.
Stan
MHamburg
Reged: 06/21/06
      #5539994 - 11/26/12 09:43 AM
Stan, once again many thanks for your advice!
Mich ael
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #5541805 - 11/27/12 10:27 AM
Once you get the worm mesh as tight as the mount will allow (i.e., just slightly backed off from binding), then whatever slop is left really can't be reduced any further. The amount of slop can vary considerably from mount to mount with some mounts being quite tight while others are loose. The slop is simply backlash between the worm and ring gear and is not necessarily a bad thing. RA slop can be easily accounted for by a slight off-balance of the axis to keep the gears consistently loaded to one side.
TxStars
Reged: 10/01/05
Loc: Lost In Space
      #5543147 - 11/28/12 12:43 AM
Depending on the maximum room there is between the retainer and worm you may be able to add a thrust bearing which can reduce binding:
http://www.vxb.com/page/bearings/PROD/Thrust/Kit8670
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
Re: RA Slop Tolerance? new [Re: TxStars]
      #5543157 - 11/28/12 12:54 AM
While there might be room on one side of the worm, there is no room on the other side since the standard bearings sit right against the cap with no spare room. It would be nice if the system were designed with enough space on each side for a thrust bearing. It is precisely because of this that the bearings are almost always installed too tightly in the first place which damages the bearings and adds to PE.
MHamburg
Reged: 06/21/06
Re: RA Slop Tolerance? new [Re: EFT]
      #5543526 - 11/28/12 10:04 AM
Thanks for the info, Ed and TxStars. I am waiting for clear skies here in the East so I can actually adjust and calibrate the mount.
Ed- I really learned a lot from the Hypertune DVDs.
Michael
TxStars
Reged: 10/01/05
Loc: Lost In Space
      #5543579 - 11/28/12 10:34 AM
In that case the standard bearings could be replaced by tapered roller bearings and then they could be set "Snug" and cure the problem.
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
      #5543722 - 11/28/12 11:56 AM
For the most part it is still a space problem. While tapered bearings in this size are no impossible to find (they are used in some medical equipment), they are uncommon and expensive. I'm not sure if there would be sufficient benefit to switch to them. Standard bearings are OK in this application as long as they are not over tightened. Taper bearings would have the same problem to some extent in that, if they were installed with too much preload, they would still not work well. However, they night not be as easily damaged since they are designed for the axial load. Another possibility might be angular contact bearing, but again you get into more specialized bearings when you go that way.
TxStars
Reged: 10/01/05
Loc: Lost In Space
      #5544259 - 11/28/12 05:27 PM
Well a single ball on center at each end of the worm to reduce play would be cheap and be easily replaced.
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
      #5548595 - 12/01/12 11:12 AM
I have found a source for angular contact bearings of the correct size and am ordering a couple sets to try them out and see if I think there is sufficient advantage to switch to them for this application.
MHamburg
Reged: 06/21/06
      #5548822 - 12/01/12 01:39 PM
Please keep us posted, Ed.
Michael
10 registered and 17 anonymous users are browsing this forum.
