Privacy Policy |
Please read our Terms
of Service | Signup and
Mirzam
Reged: 04/01/08
Loc: Lovettsville, VA
Re: 12" GSO mirror removal and re-mounting
[Re: tag1260]
#5538804 - 11/25/12 02:10 PM
You can also use a flexible plastic ring cut from a file folder or other flexible plastic sheet. Just attach with double sided tape. There is a picture at the beginning of this thread in the ATM forum:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5538444/page...
JimC
acochran
Reged: 06/19/08
Loc: So. CA
[Re: Mirzam]
#5538975 - 11/25/12 03:35 PM
I am a beginner. so take my advice with a grain of salt: I used tape made from a slippery plastic similar to Teflon. I think the product is called slick tape or slick strips. I bought it online.
tag1260
Reged: 10/07/12
Loc: Ohio, USA
[Re: acochran]
#5546328 - 11/29/12 09:55 PM
OK. Here's where I am. On the mirror mount I cleaned the sticky pads off and replaced them with felt sliders. Then I tied the three mounting plates together, with 30 lb Spiderwire fishing line to keep the sort of aligned. They still can move but are restricted considerably. Also installed some cork pads around the inside of the mirror mount to keep from having mirror to mount contact. I'm going to install two nylon screw "bearings" in the side when my mirrors get back and I can measure the thickness to find their locating.
Speaking of my Mirrors, I talked to Jeff at "Majestic Coatings" today. I can't believe my mirrors arrived Monday and were shipped back out on Wednesday!!!! I"ve heard nothing but good about him and now I can attest to it myself!!!
When it gets here, I have the center mark to install (Catseye). Again, Kudos to another vendor, Jim Fly at Catseye talked to me and explained his opinion on what I needed and didn't treat me like the idiot I felt like. Even after I ordered and changed my mind, he went out of his way to accommodate me.
Anyways, I'll post up a couple of pics as I finish up my project and hope I'm not being a pain but I've never really worked on anything like this. I know I couldn't be doing this without everyone here's input.
Thanks Tag
tag1260
Reged: 10/07/12
Loc: Ohio, USA
[Re: tag1260]
#5546816 - 11/30/12 08:54 AM Attachment (11 downloads)
here's a picture of what I've done so far. All I need to do is drill and tap the holes for the side "bearings and I'm good to go.
David Castillo
Reged: 09/09/06
Loc: Carmel Valley, Ca
[Re: tag1260]
#5548279 - 12/01/12 04:26 AM
Before you break out the tap and dye set, try the mirror out in the cell with a star test. I don't think you need need to go that far- the mirror isn't that thin, and I'll bet a star test will confirm it. It's a big hunk of glass, dude!!I don't think you need to follow the lemmings. ---- Dave
Mirzam
Reged: 04/01/08
[Re: David Castillo]
#5548483 - 12/01/12 09:46 AM
Looking again at your mirror cell, you may be fine just using shims of cork or wood at the 90 degree edge positions. Because the rim around the mirror cell periphery only comes up about halfway on the mirror, it may not allow the nylon bolts to be placed at the right position (which is just a little under halfway up). As the previous commenter says, your mirror has enough thickness to get away with a minimalist edge support. Just be sure that the mirror is not pinched in the cell, or so loose as to cause problems with collimation. When you set the telescope up for viewing, raise the scope all the way to zenith and then lower it down to about 10 degrees above horizon. Then raise it to 45 degrees and collimate. This will ensure that the mirror is consistently seated in the cell and is collimated at an average viewing angle.
JimC
tag1260
Reged: 10/07/12
Loc: Ohio, USA
[Re: Mirzam]
#5549271 - 12/01/12 07:12 PM
Thanks for all the replies. Well, I do already have the cork mounted (In 6 positions as shown in the picture) all around the cell. Do you think I should remove the one at app. 6 o'clock and allow that area to be unsupported?
Thanks again Tag
Mirzam
Reged: 04/01/08
[Re: tag1260]
#5549361 - 12/01/12 08:27 PM
Probably won't matter one bit. Just be sure the mirror isn't scrunched tightly into the cell. You want the triangles to float the mirror, which will not work if the sides are held tightly by friction.
JimC
tag1260
Reged: 10/07/12
Loc: Ohio, USA
[Re: Mirzam]
#5555378 - 12/05/12 09:55 AM
Ended up taking out the cork and letting the mirro ride on the rubber mounts from the factory. There just isn't enough room for anything in there. I "may" go ahead and put the screws in at a later time but for now the factory mounting will have to work.
I center marked my mirror with a Catseye from Catseye Collimation. I also got Jim's Catseye Chelshire eyepiece. I don't think I'll use a laser anymore. I also have an Orion Collimating eyepiece but never felt comfortable with it.
Another added addition was an Antares Twist lock Adapter for the eyepiece, getting rid og the set screw type.
Now I can't wait until a clear night (they say tonght!!!!) to try out my newly re-coated mirror and new collimation.
Thanks for listening to me throughout all of this.
Tag
Edited by tag1260 (12/05/12 09:57 AM)
13 registered and 27 anonymous users are browsing this forum.
Moderator: Jarad, ausastronomer, okieav8r
