lcd1080
Reged: 06/03/10
Loc: Maryland, USA
Jupiter and Io on Thanksgiving night new
      #5539065 - 11/25/12 04:35 PM
I left early from my Thanksgiving dinner party because we haven't had good seeing since Nov 11 and I didn't want to miss any chances this close to opposition; here's Jupiter and Io on Thanksgiving night, Nov 23 at 0419UT with my C11 at F/25. If I stare at Io long enough I can convince myself that it has a 3D quality relative to Jupiter. Thanks Glenn for giving me some good ideas on how to process my images in AS!2 and Reg6!
Pete
Edited by lcd1080 (11/25/12 04:44 PM)
Freddy WILLEMS
Reged: 11/13/05
Loc: Hawaii, Honolulu
Re: Jupiter and Io on Thanksgiving night new [Re: lcd1080]
      #5539090 - 11/25/12 04:43 PM
Great capture Pete !
Kokatha man
Reged: 09/13/09
Loc: "cooker-ta man" downunda...
Re: Jupiter and Io on Thanksgiving night [Re: Freddy WILLEMS]
      #5539142 - 11/25/12 05:38 PM
Good effort with some nice detail there Pete..!
A lot of folks do a seperate rgb alignment on the Gallilean Moons because quite often they won't come into alignment when the disk of Jupiter is.....you then "recomposite" the moon back in when aligned.
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
      #5539356 - 11/25/12 08:07 PM
Good work Pete! Jupiter looks a little blue, but one thing I noticed is that it seems to be blurred in the direction of rotation. Maybe the videos were too long in duration?
Glenn
bunyon
Reged: 10/23/10
Loc: Winston-Salem, NC
Re: Jupiter and Io on Thanksgiving night new [Re: DesertRat]
      #5539373 - 11/25/12 08:25 PM
Looks great. I was in Silver Spring with family and it looked like a great night. Alas, I had no scope.
BKBrown
Reged: 08/23/09
Loc: Northern Virginia, USA
      #5539488 - 11/25/12 10:07 PM
Nice shot Pete
Clear Skies,
Brian
sfugardi
Reged: 09/30/06
Loc: CT
Re: Jupiter and Io on Thanksgiving night new [Re: BKBrown]
      #5539593 - 11/25/12 11:09 PM
Pete, excellent shot! Try realigning the color on Io, the R looks 1px shifted up. You can also try aligning only to Io in AS2!, but you need to click on 1 point alignment, then manually draw the box. Thanks for posting
Steve
DesertRat
Reged: 06/18/06
Re: Jupiter and Io on Thanksgiving night new [Re: sfugardi]
      #5539660 - 11/26/12 12:02 AM Attachment (11 downloads)
Pete the alignment may need some work. Hope you don't mind but here is my stab at it. First I selected the whole planet and did a white balance correction in MaximDL. Then I aligned the color planes as shown, also in MaximDL. Its not meant to be the definitive fix, I did it in a hurry. Of course this throws things off for Io, it has to be treated separately.
Glenn
lcd1080
Reged: 06/03/10
Loc: Maryland, USA
      #5540116 - 11/26/12 11:09 AM
Thanks Freddy, Darryl, Glenn, Paul, Brian and Steve! Glenn, the image time from start to finish was about 3 minutes (173 seconds) which was probably too long. I'll try to figure out how to use WinJupos to derotate the images. Thank you for doing the white balance correction and color plane alignment, the color looks much better. Today I'm going to reprocess the image from the beginning; first I'm going to follow Steve's suggestion of aligning only Io in AS!2 with the single point alignment, then I'm going to fine tune the wavelets for Jupiter in R6 using new Denoise and Sharpen parameters, perform a new deconvolution in AI3.0SI and finally attempt to derotate the images with WinJupos. I'll try to post the result later today or tomorrow at the latest. The help you all have offered is so great, I really appreciate it!
Here are the R, G, and B TIF files that resulted from the original run in AS!2. They're resampled up to 250%. If anyone wants to play with them please do!
Thanks again for all your helpful suggestions!
Pete
Edited by lcd1080 (11/26/12 11:22 AM)
swalker
Imaging Editor - Sky & Telescope
Reged: 01/22/07
Loc: 42.9225°N, 71.2242°W
      #5540132 - 11/26/12 11:15 AM
Nice result.
lcd1080
Reged: 06/03/10
Loc: Maryland, USA
Re: Jupiter and Io on Thanksgiving night new [Re: swalker]
      #5540704 - 11/26/12 05:29 PM
Thanks Sean!
Today I reprocessed my Jupiter image by derotating it in WINJUPOS thereby reducing the blurring that Glenn mentioned; also I aligned Io in AS!2 as Steve suggested and "recomposited" the moon back in as Darryl mentioned. I still have to redo the wavelets in Reg6 using new Denoise and Sharpen parameters but for now this is where the image stands:
Pete
Edited by lcd1080 (11/26/12 07:26 PM)
7 registered and 16 anonymous users are browsing this forum.
Moderator:  Boot, bilgebay
