Astrojensen
Reged: 10/05/08
Loc: Bornholm, Denmark
Re: Measuring the Baader Glasspath correctors new [Re: ewave]
      #5239431 - 05/25/12 06:01 PM
OK can someone tell me what this is:
Part # ORJ-R : 2" Refractor/SCT 1.8X Glasspath Corrector (needs T2 Diagonal)
It's this one:
http://www.baader-planetarium.de/sektion/s32/bilder/2456305_gross.jpg
A 2", 1.8x GPC for fast refractors and SCT's. Haven't tried it. Perhaps Tammy has one?
Clear skies!
Thomas, Denmark
Tamiji Homma
Reged: 02/24/07
Loc: California, USA
Re: Measuring the Baader Glasspath correctors new [Re: Astrojensen]
      #5239488 - 05/25/12 06:30 PM
Hi Thomas,
Yes, I have one.
I use this with refractors:
I use this configuration with MakNewt MN-86:
Tammy
ewave
Reged: 05/16/09
Loc: northwest NJ
Re: Measuring the Baader Glasspath correctors new [Re: Tamiji Homma]
      #5239560 - 05/25/12 07:14 PM
wow...ok the 2" looks like it will add quite a bit of focus travel? Perhaps will work with my fast APO?
Tammy, any travel distance numbers figured out yet for the 1.8x?
Tamiji Homma
Reged: 02/24/07
      #5239657 - 05/25/12 08:17 PM
When you attach the 1.8x Barlow lens, it pushes focuser about 65mm outward to reach focus.
I use it with f/5.5 refractor. It works well.
Tammy
tomcody
Reged: 07/06/08
Loc: Titusville, Florida
      #5239700 - 05/25/12 08:43 PM
It's this one:
Clear skies!
Thomas, Denmark
Here is a link to it on Alpine Astro:
http://www.alpineastro.com/Binoviewers/binoviewers.htm#ORJ
Rex
ewave
Reged: 05/16/09
Loc: northwest NJ
Re: Measuring the Baader Glasspath correctors new [Re: tomcody]
      #5239815 - 05/25/12 10:00 PM
It's this one:
Clear skies!
Thomas, Denmark
Rex
I think thats for the newtonians
ewave
Reged: 05/16/09
Loc: northwest NJ
      #5239817 - 05/25/12 10:01 PM
Tammy
Thanks Tammy
Peter Natscher
Reged: 03/28/06
Loc: Central Coast California
      #5538944 - 11/25/12 03:19 PM Attachment (22 downloads)
Sorry I'm late to this post but I used the 2.6X GPC in my Mark V last night with my AP 175EDF and it seemed to work fine. Upon reading this post today, I attempted to reverse the 2.6X GPC by inserting it reversed into the Baader prism diagonal and the attaching this assembly to the Mark V front end. It doesn't attached well. The GPC takes up some of the space needed for the BP6 ring to attached properly to the Mark V flange. See photo.
Yes, there is a diagram on the Astro-Physics site that shows the correct orientaton. Its on the AP site , Baader Mark V page, in the corrector paragraph.
Rex
Thanks to Rex. Here's a link:
http://www.astro-physics.com/products/accessories/baader/Binoviewer%20Glasspa...
Clear skies!
Thomas, Denmark
DaveJ
Reged: 01/07/05
Loc: NE Ohio
Re: Measuring the Baader Glasspath correctors new [Re: Peter Natscher]
      #5539014 - 11/25/12 04:00 PM
Rex
Clear skies!
Thomas, Denmark
Well, it's *almost* installed correctly. Before installing the 2.6 GPC, you need to remove the Quick Change adapter. The 2.6 GPC then screws directly into the diagonal and THEN you attach the Quick Change adapter by screwing it back in place.
Peter Natscher
Reged: 03/28/06
Re: Measuring the Baader Glasspath correctors new [Re: DaveJ]
      #5539049 - 11/25/12 04:26 PM
Ah... got it! thanks!! So, if my views with the 2.6X were ok last night at 330X with two 11mm TV Plossels, then I've got to try this new 2.6X reverse mounting setup tonight at the same 330X and 11mm TV PLs on Jupiter during an Europa shadow transit. I hope it doesn't cloud over.
Rex
Clear skies!
Thomas, Denmark
DaveJ
Reged: 01/07/05
Loc: NE Ohio
Re: Measuring the Baader Glasspath correctors [Re: Peter Natscher]
      #5539143 - 11/25/12 05:38 PM
In my scopes, there's a very obvious difference in the clarity of view when the 2.6 GPC is installed in its proper orientation vs. the view when installed backwards. Just to make myself clear, you've got it in the correct orientation in your photo above, just not on the correct side of the Quick Change adapter. I am quite interested in hearing your impression following your viewing tonight. I predict that you'll be stunned at the improvement.
Moderator:  TG, Geo557
