Observing >> Solar System Observing
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | (show all)
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: Some thoughts on a Transit of Io new [Re: fred1871]
      #5569992 - 12/13/12 09:33 PM
Fred, have been quietly following the rule of thumb thread, if that's the one you mean.
From the math above, I am wondering if somewhere near 0.4" arc (about 1/4th Airy disc) is at or near a limit for the 6". Below that separation seems to be the realm of point sources. According to the math, anyway. Curious...but seems consistent with some observations you mentioned.
I am at 16 degrees North and Jupiter passes pretty much through the Zenith. In our tropical climate upper air flow from the Pacific Ocean is pretty much laminar, the 6" really hits a sweet spot here. The first diffraction ring is nearly always visible and very steady much of that time. It bounces around from time to time, but generally it's very nicely presented.
azure1961p
Reged: 01/17/09
Loc: USA
Re: Some thoughts on a Transit of Io new [Re: Asbytec]
      #5570075 - 12/13/12 10:31 PM
The first diffraction ring in ct is cause for a gazzoo.
Pete
fred1871
Reged: 03/22/09
Loc: Australia
      #5570172 - 12/14/12 12:01 AM
Sounds as if you've got near-ideal conditions for high-res visual images, Norme. I don't get the laminar airflow, being somewhat inland from the wrong (east) coast. And Jupiter's rising only a bit over 30 degrees from my horizon.
Yes, I'd think 0.4" might/should be possible with 6-inch scope, as Burnham and a few others have seen elongation on even pairs at that separation. It also fits Christopher Taylor's experience, scaled from his 12.5-inch.
I'll make attempts on Io as weather allows. Should be interesting. I'm inclined to be doubting of Pickering's claim re 4-5-inch telescopes, but as I have a 5.5-inch (140mm) and it's a refractor I'll see what's possible. I've been surprised before by seeing things I'd thought needed a bigger scope.
Re Pete's last note - ummm, not sure what the slanguage means.
azure1961p
Reged: 01/17/09
Loc: USA
      #5570226 - 12/14/12 12:56 AM
As the other post mentioned, I can confirm with you folks on Ios egg shape. Europa near it made the comparison clear - on color too. Nice pale peach on Io and a nice pale yellow for Ganymede. Europa just appeared off white. At anyrate Europs tighter and symmetrical circle-dot made for good contrast to Io s Egg look.
Never never would e seen had I not specifically looked for it. Confirmed at 364x.
Pete
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: Some thoughts on a Transit of Io new [Re: azure1961p]
      #5570275 - 12/14/12 02:59 AM
Fred, I have been literally stunned at what good seeing can allow. Six inches of aperture does not disappoint in the least. I would be pleased if you got stunned by Io, too. We can all add that one to our growing list of stunning sights, even if Pickering was, well, wrong about other things.
Pete, exactly. If Europa is in the same FOV, the comparison get's easier. Europa is the definition of round and there is no question, no doubt in my mind it's round. Io ("effect") is reasonably questionable in comparison. Sometimes it just hits you as elongated during the best moments. Over the cloud tops should be much easier.
So glad you caught that, Pete. You're part of a growing alumni. And you're right, you never would have noticed it at 30x per inch observing Jupiter.
Still trying to understand Io's extended nature and why it's difficult to see elongation visually a 1.2" arc - more so that 72 Pegasi at 0.56" arc, for example.
azure1961p
Reged: 01/17/09
Loc: USA
      #5570398 - 12/14/12 07:18 AM
That is a good question.
Pete
azure1961p
Reged: 01/17/09
Loc: USA
Re: Some thoughts on a Transit of Io new [Re: JasonBurry]
      #5844954 - 05/07/13 06:08 AM
Eddgie, maybe this will help your explanations. I'm a CAD operator in real life, and I used CAD to do a rough simulation of the diffraction effects involved in our observations of Io. I humbly submit it here for discussion. This models an 8" telescope with no CO, giving an Airy disc of 0.68". I've laid multiple airy discs over a grid laid on the face of "Io", with equatorial region discs shown bright, and polar discs shown darker.
It's a good likeness to what I observed, allowing for my crude simulation.
J
Hi Jason,
Reading through this in another link led me to question the diagram
you attached. While I agree with the diagram in principle as to how diffraction defines a small orb like Io through an 8" scope it would seem its also exaggerated heavily. The image of Io would infact bloat like that beyond its physical apparent size if it had the surface brightness to fill it out like that. This diagram works better when the target is a star for example where its surface brightness is exceedingly high . Then if you had a point source like a star now filling in the size of IOS apparent size with all those infinite points it'd be dazzling. Infact it'd be so bright you wouldn't want to look at it and if you did it would indeed be bloated glaring and soft edged.
Such as it is those per infinite point Io is far dimmer and doesn't swell as you've shown.
The diagram does show how the ovular shape is affected by diffraction and the lesser surface brightness on the poles but its misleading to . I'm convinced at Ios brightness level there is no swelling visible beyond its observed physical size.
Pete
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5845640 - 05/07/13 01:38 PM
Its a good question, Pete. I was reviewing Vald's explanation of point sources...how big they have to be to start expanding the Airy pattern. Turns out, about 1/4th the Airy disc diameter offers a point source PSF. Any bigger, then the edge of the spurious disc begins expanding markedly.
Now, at Io's angular diameter near opposition, it's well over 1/4 the Airy disc diameter. It is, indeed, an extended object with an enlarged PSF. But, how it behaves is very complicated.
I'd have to review Vlad's site, again, to speak to the question. But it does seem it acts as a series of point sources (1/4 x Airy diameter), some of which are brighter than others. After all, it's "football" shape does show very well in images for a reason (contrast and diffraction, I'd imagine.)
I'd like to know more, too.
In fact, I was just reading Sidgwick, he mentioned the apparent elliptical appearance of Jupiter I (Io) and 4 (Callisto.) Not sure what that's all about...LOL. Let me find and reread his statement.
Edit: found it. Sidwick's Amateur Atronomer's handbook, section 26.10, Scales of Seeing, subparagraph (b), page 465. He describes one of Pickering's seeing scales, the "eliptical outline of Jupiter I and IV" that disappears in large enough telescopes. Remember, he urged amateurs to observe Io with a 5" glass, so that is probably the aperture range this seeing scale is intended.
Jupiter IV is Callisto! Who's game? LOL
azure1961p
Reged: 01/17/09
Loc: USA
      #5846710 - 05/07/13 09:53 PM
I think Callisto is a case that's a lot like the canals on Mars. First there's a few detached markings, a mistranslation and all over the globe people are seeing canals. With Io we have it so much like the contagious canals spreading like a virus so too, the Galilean moons all suffered the same fever and Pickering and his pal getting each other worked up over it - though on a much smaller scale. Its sobering how expectations can fuel results that are completely false and with fervor.
I'm still undecided on the Io - is it the real limb or diffraction. I mean what if the poles are just merely too close to the background sky glare to show it seperated and whole disc? I'm straddling diffraction and contrast here with question marks. I know they are intertwined but still .
Pete
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5846881 - 05/07/13 11:20 PM
Well, I dunno if it's real limb or diffraction, either. That's what I want to know.
You may be right about fervor and seeing Io as an elliptical orb. Still, I do believe I observed it. Of course, it is not obvious. It is difficult. It did require stable seeing and maybe it even required fervor to undertake such a difficult observation. So, fervor might have been an attribute, not something creating an illusion. It really helped to have Europa in the FOV for comparison. High power was a big help, too. But, sure enough...with patients and fervor (lol) it can be done.
Now, how and why are still a bit of a mystery. I believe it is diffraction effects, as Eddgie says. Io is small enough, still, to be dominated by it. Ganymede, in my 6" scope, is right about the angular dimension where it begins to become a true extended source. It's PSF is greatly expanded at opposition.
I'd have to review Vlad's take on this point source and extended object boundary. It's complicated, but that doesn't mean Io's elongation is any less real.
azure1961p
Reged: 01/17/09
Loc: USA
      #5847258 - 05/08/13 07:45 AM
No no no - Norme in the case of Io - a lot of us observed it (I don't - maybe just several this is a fairly under wraps thing it would seem). My contention is that in the case of Callisto that was erroneous with Io kicking it all off and the mind having at it. Io was real Callisto and other moons by Pickering was him and his buddy running away with themselves.
Pete
JasonBurry
Reged: 04/27/12
Loc: Cape Spencer, NB, Canada
      #5847297 - 05/08/13 08:27 AM
LOL, I agree Pete.
Also, my "simulation" is extremely crude. I'm sure it falls short on many levels.... My understanding of diffraction is limited.
J
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
      #5848079 - 05/08/13 03:59 PM
Ah, ok, Pete...ya, I agree on Callisto. You got me rethinking the whole Io thing, I didn't understand your question, I guess. However, Callisto has become more interesting...LOL
Classic8
Reged: 04/12/06
Loc: Naperville, IL, USA
      #5860424 - 05/14/13 05:05 PM
Does it actually look football-shaped? Or just slightly out of round? If, as 1 or 2 people said, that Io looked darker near the poles, couldn't that make the top and bottom less visible, thus making it look flattened and oblong slightly?
azure1961p
Reged: 01/17/09
Loc: USA
Re: Some thoughts on a Transit of Io new [Re: Classic8]
      #5861108 - 05/14/13 10:28 PM
Its slightly out of round and you need, or it certainly helps to have Europa nearby in that its a great comparator . Io is evvveeerrr so slightly depressed or tad flat at the poles in appearance. When you do see it its a very certain thing - just very subtle.
Pete
JasonBurry
Reged: 04/27/12
      #5861618 - 05/15/13 08:17 AM
Classic8, yes, exactly, especially when Io's in transit in a dark cloud band... The poles blend into the background, leaving the brighter equatorial region only showing in modest instruments.
I've not seen the effect with Io not in transit, though Pete (and doubtless others) has, and for that case, having a round reference (Europa) in view really helps with the comparison.
Good luck!
J
azure1961p
Reged: 01/17/09
Loc: USA
      #6351419 - 02/02/14 02:55 PM
David Knisley posted the following . Because he commented as well the lunar forum was not the place for this topic Ive transplanted it here. Here's what David had to say:
Over the past 46+ years since my first view of Io way back in 1967 in my first telescope (3" f/10 Newtonian), it has never appeared as anything other than a dot or a small disk. It never appears out of round, and even in my 14 inch, it just shows its pale dirty yellowish disk. The only time I ever got to see any major detail on that disk was during the Nebraska Star Party using a 30 inch Newtonian at over 500x. Even then there wasn't a lot of detail to see. The polar regions were only very slightly darker (and *not* uniformly so) than the rest of the moon's disk with rather low contrast. Sorry, but elongation of that moon just hasn't been in the cards for me (and Pickering's observations are not worth commenting on, as they clearly represent something other than a true level of detail or resolution). Imaging to support "elongation" also has some problems, as the transiting Io will tend to have adjacent linear detail change the shape of the dot of Io in a way that is not necessarily matched visually. Again, the resolution of the disks of the moons of Jupiter and any detail they might show would be best done on a different forum. Clear skies to you.
David W. Knisely . . . . . . "If you aren't having fun in this hobby, you aren't doing it right."
Hi David,
Just to be clear Im not suggesting Ive seen dark poles on Io or anything on Io infact and up until I made a concerted effort a year ago or more Id never noticed this moon as anything but a round 1" dot. In inspecting it at over 300x with the information put fourth in this thread I gave a look see. At first it was just well, a golden warm toned dot indeed. Studying it though it was conceivable how it could be seen to appear somewhat full around the belt line, ie; equator. It was one of those hmmm moments. What clinched it was Europa just next to it and granted the sizes are slightly different but the circularity of Europa gave away this subtle oblate nature of Io that had been discussed. Had Europa been behind Jupiter I may have said " undecided but suspicious of oblate nature" or something to that effect . Io appeared rotund - a strange word for a round body but that was the knee jerk impression. Its fullness was the effect of its brighter middle averaged out with its darker poles as ever so slightly ovular. The face of Io was blank as always - its profile was in question here. By contrast it never showed the hard perfect roundness of Europa.
I don't doubt on 46 years its never been but a dot and had I not tried on a decent night it'd be another 46 for me (actually 30).
The experience you have had with some very large aperture wouldn't be revealing here because the oblate profile is a diffraction effect of medium aperture. At 14" Ed Moreno had agreed the disc would appear round and not oblate because by that point the angular resolution and contrast would be sufficient to reveal Ios truer spherical nature. If anything David something like a 6" off axis mask would be revealing than large aperture because you'd be introducing the lower resolution diffraction effects responsible here. Timo as well as Sheehan, Pickering, Barnard all have realized greater aperture does not show the ovular profile but it was never a physical attribute of Io to begin with.
I would say this - if you get a night of 6-7 Pickering and stop down your scope to 6" , use at least 250x and time it with a close grouping if Io and Europa and Im certain you'll see the effect. The moon will be forever blank but its profile will appear, again, slightly rotund. A low res diffraction effect.
I appreciate you as a very careful, informed and responsible observer but I KNOW you'd see it under the suggested conditions. This is a call that needs a "control" close by to make a confident call.
Pete
David Gray
Reged: 08/06/12
Loc: Co. Durham UK
      #6352666 - 02/03/14 07:40 AM Attachment (8 downloads)
As I am coming in on this (a little against my better judgement!) but just get this out of the way:-
In the first place I do not think I/we are getting anything more than indications of real features on these bodies with our ‘backyard’ scopes. For myself I am not trying to supersede NASA mapping . Simply satisfying that curiosity of what is presented at borderline contrasts/resolution i.e. a bit of fun – no pretensions/delusions of doing great things for science…….!
In actuality I have done less than a dozen drawings showing detail on those moons – not counting in-transit efforts since my first attempt in 1965. None of the former have I ever submitted to the BAA Jupiter Section to which I have contributed since 1969 when W.E. Fox was in charge. I have seen/suspected such detail on many nights: 1964-78 10” f/8 Newtonian and ’78-on with the 16.3” D-K but only very occasionally do I go for a drawing. In particular I find some Ganymede-features quite contrasty with x365 and that can lure me to check out the form of these with more magnification.
John Rogers makes no bones about his position on such drawings; though he is more acceptant of views of transits and such. In fact on page 326 of his book “The Giant Planet Jupiter” he shows a number of Io transit views including one I got in 1989. An SEB fade was in progress at the time and offered an ideal light, near-featureless, backdrop which allowed me to get darker poles and a duskier f. side of the satellite.
I have to confess I never really checked for any elongation with Io until I saw mention by Norme & Pete. What I report here does not contradict their impressions at all. But I further got the impression that the major axis of the apparent ellipse does not always line up with the angle of Jupiter’s belts being (so far) seen to vary as much as perhaps +/-20º. This subject to further good views of course. In keeping with their practice the other satellites are checked for any out-of-roundness. No astigmatism was apparent with myself or the optics – easily checked by rotating the viewing angle or the eyepieces.
Norme is aware of some of my above-mentioned efforts as I show with this PM I sent him on Jan. 14.
Sent to: Asbytec
Hi Norme,
I’ve been caught up with more ‘90s Saturn reporting – 86 dates this time so have stepped back somewhat from CN as I don’t want to look as though I’m ignoring folks…! So herewith a PM that I resisted putting on your thread.
Had a look at Io on Jan 9 (19:25-50 UT) & Jan 11 (20:45-21:40) and I am very assured of the elongated aspect on both dates. Certainly with a 6” off-axis on the D-K (x365 - binovu & x415-monovu). Not only that but also with the full 16.3” when the image is dimmed suitably – apodizer, filters and/or thin cloud. Further I find that the elongation major axis on these dates is not in line with the Jovian belts but slanted some 20º say toward p.a. 110º-290º: consistently – other moons looked quite round.
Further to that I find it is more marked in green filters than any other which suggests that the reddish polar caps are indeed the culprit.
I really need better seeing to follow-up however as on these dates with more ‘normal’ seeing. I find it a little peculiar in that I’m getting Pickering 6-7 with my focus-check- double Eta Gem (BU 1008); and the moons themselves come to that – but Jovian features relatively ill-contrasted for Antoniadi III/II-III!!
Maybe a project here into following apparitions and perhaps use such as WinJupos to plot against Io-CM when enough observations to hand…..
Also got a light polar region with Ganymede on the 11th with both apertures.
Dave.
azure1961p
Reged: 01/17/09
Loc: USA
Re: Some thoughts on a Transit of Io [Re: David Gray]
      #6352710 - 02/03/14 08:28 AM
David,
Thanks for the account and kudos to Norme for keeping this under wraps!!
Its interesting that you see the brighter equatorial region offset at an angle differing from jupiters belts and to that end - well that's high res for you. Interestingly I never considered using filters - but at 8" while I can see ios color Id wonder if it'd stand up to a 58 green I have. A curious thing is I actually saw an image in one if the links that was in the Plato thread that does infact show the offcenter limb brightness of Io - both as it sits with Jupiter as a back drop but to a decidedly lower res image after it regains the backdrop of dark space.
Any chance you can qoute Rogers feelings on submitting drawings of the moons? I'm guessing his feelings are its too wrought with poor seeing effects and such and tough to do reliably.
I've got to get the book. Nice post David and thanks for weighing in.
Pete
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: Some thoughts on a Transit of Io [Re: azure1961p]
      #6352854 - 02/03/14 09:47 AM
David, I am simply floored by your work.
Yea, this is not ground breaking science to dispute NASA, it's just an observation other amateurs can enjoy. Add one more Jovian moon to the list of exciting moons. Something to extend common knowledge in the amateur community, a challenging observation for us to get excited about and check off.
Long ago, Pete pushed me toward Ganymede. I thought there was no way, can't be done. Too small, diffraction resolution, etc. Turns out, it can be done...that was exciting. Its observations like this that keep it interesting.
3 registered and 7 anonymous users are browsing this forum.
Moderator:  Rich (RLTYS), star drop, dr.who
