BDS316
Reged: 09/16/09
Loc: Sol 3
16mm UO Konigs new
      #5540291 - 11/26/12 01:17 PM
This was one of my first eyepieces back in 1991. Bought it based on a rec from the first edition of "Backyard Astronomer's Guide" by D&D. It didn't work well with my f/4.5 Odyssey 10. I hung onto it because it worked really well when used in combination with my TV 1.8x Barlow, for a 9mm equivalent, serving up a view pretty close to a 9mm Type 1 Nagler that my observing buddy had.
I think the 16 Konig works better in f/10 inch scopes like SC's.
I never got around to selling or trading mine although it sees little use these days. I keep it partly for sentimental reasons and as a conversation piece.
Do you still own one, and how often does it get time in your focuser?
RGM
Reged: 09/15/03
Loc: Burks Falls, Ontario, Canada
Re: 16mm UO Konigs new [Re: BDS316]
      #5540892 - 11/26/12 07:41 PM
I still have mine. I think I bought it sometime in the 80's. Have not used it for at least 5 years.
I just pulled it out of storage because of this thread and will try it again. I think the reason I have not been using it is the tight eye relief.
Jaimo!
Reged: 10/11/07
Loc: Exit 135 / 40° North
      #5541284 - 11/26/12 11:18 PM
I use them on occasion, usually as a grab-n-go set with my 80mm f/6.9 refractor in conjunction with a 2.8x Klee barlow. It offers a wide magnification range and as they are "normal" sized eyepieces, they fit in pockets nicely. I took the set out this evening with my Intes 150mm f/12 Mak to check out Jupiter after reading this thread. What a fine view. The 12mm gave about 150x in this scope and it was the best observing of Jupiter I have had this season. The planet was crisp to the edge with the 12mm requiring a little focus adjustment occasionally. These eyepieces matched up very nice with this focal length scope yielding magnifications of 75x, 113x, & 150x. I may have to compare them to some plössls or orthos as another planetary option...
Jaimo!
moynihan
Reged: 07/22/03
Loc: Lake Michigan Watershed
Re: 16mm UO Konigs [Re: BDS316]
      #5541351 - 11/26/12 11:48 PM
Yes, and yes. Use it either my 6" f/8 newt or one of my small Maks. got mine in the mid-1980's.
Edited by moynihan (11/26/12 11:49 PM)
BDS316
Reged: 09/16/09
Loc: Sol 3
Re: 16mm UO Konigs new [Re: Jaimo!]
      #5541609 - 11/27/12 07:37 AM
With only four elements the Konig gives very nice planetary views....on axis. Off axis in faster scopes can be less satisfying.
21 registered and 26 anonymous users are browsing this forum.
Moderator:  ausastronomer, droid, Scott in NC
