JasonBurry
Reged: 04/27/12
Loc: Cape Spencer, NB, Canada
Some thoughts on a Transit of Io
#5540082 - 11/26/12 10:55 AM
Friday night brought about 30% clouds, mediocre transparancy and quite good seeing, along with a 20km wind and unusually warm (+9C at 11pm) temperatures. After supper, I set out my 8" dob and my 4.5" newt and started them cooling. In 10 years of observing, somehow I'd never actually caught a Jovian moon in transit, and this was to be the night.
I did the bulk of the observing with my 8", the 4.5 was just there because the transit would be a fun test of its contrast and resolving abilities, with its near-spherical primary.... The 8" dob was running a 12.5mm plossl and 2x barlow, for about 200x. The 4.5" had a 4mm Huygens of very low quality, giving 225x.
The GRS turned out of view a little before Io's shadow contacted Jupiter's disk. The seeing was uncommonly good, with all 4 of the moons showing clean disks, with a faint spray of glare around each. Knowing Io's angular dimension, the seeing was generally well under 1".
As the shadow bit Jupiter's limb, I was astounded by the "3d-ness" of the spectacle. Fascenating to see the limb reach around the back side of the shadow, until it was a black spot on Jupiter's face rather than the bite it had been moments before. A look through the 4.5" newt showed the shadow quite well too, not quite so vividly, but easily observable. An pleasing view, when the planet was well centered in the FOV, as the cheap eyepiece had tons of false colour off-axis.
The real magic hadn't yet begun, however. Back to the 8". As Io approached Jove's limb, it seemed to take on a 3d aspect in its own right, a yellowish pearl. Its glide into the face of Jupiter's disk was astounding.... I was surprised how clearly the tiny disk stood out from the otherwise similar colourscape of the Jovian cloudtops. I was also able to see Io's disk in transit thru the 4.5" scope, but it was much harder to resolve.
Over the next hour or so, I began to notice something very peculiar about Io, and it is this that is the real subject of this post.
Now, Io has a diameter in the 1.5" range (I don't have the figure here), and an 8" scope has a resolution on the order of 0.5".
I could swear that in my telescope, while in transit, Io appeared to be elongated in the equatorial direction. It was my impression that it appeared to be about 3:2, seemingly squashed pole to pole.
Now I know that Io's effectively spherical. I also have read (in the imaging forum), that Io often appears "football" shaped in their images, aparently due to albedo (seems Io's poles are darker, and blend into the Jovian cloudtops more).
So, did I genuinely see this effect, or am I (once again, LOL) a victim of the "aperature of my own mind"? I was aware of this effect (the "Io Football") before I made my observation, but one cannot put the genie back into the bottle.
Anyway, it was a great blast watching the first half of this transit (before the skies went to pot), and one of the more memorable sights I've seen thru my scopes. What a beautiful season this has been for Jupiter. I've never seen it like this!
J
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: Some thoughts on a Transit of Io
[Re: JasonBurry]
#5540227 - 11/26/12 12:22 PM Attachment (41 downloads)
First off, thank you for the fascinating account of a typical, yet magical, Jovian transit.
If the football effect is visible to the human eye, contrast wise, then you very well could have seen it. As to whether you are engaged in "aperture of the mind" or not, I have no way of knowing without evaluating your response to some ink blots.
That you know of the effect or not may not matter. Question is, did you see the elongation or not? You'll have to tell us. I don't know, but judging from the highly processed, yet distinct contrast, it looks doable under very good conditions necessary on that scale - IMO.
So true.
Edit: Sorry, image credit goes to...
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5520980/Main...
Edited by Asbytec (11/26/12 12:23 PM)
JasonBurry
Reged: 04/27/12
[Re: Asbytec]
#5540245 - 11/26/12 12:36 PM
Yes, that image matches what I believe I saw, a very similar elongation of Io's brightness on the face of Jupiter.
I tend to think I DID see it...
Does that make it my first successfull detection of a surface feature (ie the dark poles of Io) on a Jovian satellite? I'm gonna contend that it does!
J
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
[Re: JasonBurry]
#5540278 - 11/26/12 01:06 PM
You know, that's an amazing feat. Pete was asking recently about any success on Galilean moons other than Ganymede. Here's one potential observation for him to chime in on.
It would be interesting to know more about the surface of Io. Does it indeed have darker poles? Or is it some sort of effect caused by uneven illumination of a sphere. Or is it an image processing effect? (I hope not.)
Again, just accounting for the image above, the contrast between the poles and the equator looks significant. Possibly enough to differentiate visually. But, maybe another observation or two would confirm it. Or if you held the elongation for a period of time, then it seems more real.
Another question that just popped up, does Io exhibit the same football effect against the black of space. If so, or if not, what does the answer mean? Does this effect require Jovian could tops to pull off. And if so, what does THAT mean? Are there images of Io against the black of space that show this pole darkening? Or is the pole darkening simply an "effect" requiring a Jovian backdrop.
In any case, it's a stunning observation. I am inclined to believe, if you saw elongation...well, then you saw elongation. I've never seen it, but I have never tried. Maybe I should, others should.
http://www.spacetelescope.org/images/opo9913c/
JasonBurry
Reged: 04/27/12
[Re: Asbytec]
#5540370 - 11/26/12 02:04 PM
I'd observed the transit for an hour or so, from when Io first broached Jupiter's limb. I began to notice the elongation a few minutes after it was fully inside the planet's disk, and noted it repeatedly (I was bouncing from my 8" to my 4.5", but only noted this in my 8") over the first half hour/45 minutes of the transit.
Once Io had made it about 1/4 of the way across the disk, I went inside for a bit, and put away the 4.5" instrument. An hour or so later, when I returned to the eyepiece, Io was nearly halfway across the planet's disk, and much more difficult to resolve against the clouds. The seeing had deteriorated, the wind was rising and the clouds were thickening.
Just looking at some HST images of Io, and the poles do seem to be subtly darker than the equatorial region in many photos. I'd guess that what I may have observed might be a subtle colouring difference between the poles and equator that is all but blown away from my eye when seen against the blackness of space. But Io and Jupiter's colours are quite similar, so against the giant's disk, the more subtle detail in Io is more easily noted.
Or, I'm a victim (again) of the complex interaction between eye and brain. It's easy to have an idea in one's head, and to force the "eye" to see supporting evidence. I'm not sure if I saw what I saw or not, but I'm certainly gonna try to repeat the observation.
J
MikeBOKC
Reged: 05/10/10
Loc: Oklahoma City, OK
[Re: JasonBurry]
#5540405 - 11/26/12 02:21 PM
Well Io is the closest large moon to Jupiter and the tidal forces on it from Jupiter's massive gravity are said to be responsible for the sulphur volcanoes detected by Voyager. Those forces would almost certanly also pull the planet's mass into a somewhat elliptical (vs. spherical) shape, would they not? Not that it is visibly an actual football shape, but even a minor aberration from a sphere might be exaggerated in certain views, just as the moon or Jupiter itself can appear squat and out-of-round when viewed low in the earth's atmosphere.
Eddgie
Reged: 02/01/06
[Re: JasonBurry]
#5540496 - 11/26/12 03:17 PM
a yellowish pearl.
This is almost exactly how I described Io during the night about two weeks agon when Ios shadow transited the GRS. I saw Io as a pale pearl. Interesting that we both came up with the same analogy, but like you, I found that the similarity was striking!
And in that post, I attributed it to some very slight albedo effects!
And I noted the exact same oblate-ness but again, felt that both the pearl texture and the oblate appearance were due to albedo features on Io.
Anyway, I am of course quite sure that they would be visible to you.. I was using a C14 but my seeing was not great that night, so with better seeing it would not at all be a surprise to have someone report this using an 8" aperture.
And yes, the shadow transits have been great. Norme caught on where the shadow was on the Oval BA, and there have been images of both of these events.
Looking at images posted on CN though you can see that Io is indeed showing albedo features in most of the images these day.
But the "Pearl" analogy is again exactly what I reported, so that says that the effect is very real and more than ust an "Impression." When two different observers on two different nights use the same term to describe it, that kind of says that it isn't their imagination.
Nice report.
JasonBurry
Reged: 04/27/12
[Re: Eddgie]
#5540515 - 11/26/12 03:26 PM
Eddgie, I read your report, LOL. Suspect that's what planted that "pearl" into my mind... It seemed hokey when I'd read it, but upon seeing it with my own eye, I might well have actually exclaimed something audible...
"By the gods, it does look like a pearl!"
J
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
[Re: JasonBurry]
#5540989 - 11/26/12 08:33 PM
Well, we're all a victim of our senses, our perception is reality. I wish I had a cold, impartial computer-like detection and interpretation of the world. Ah, no I don't.
It's interesting, however, that Io is football shaped against the planet. Thinking out loud, it if has the same color scheme, more or less, it might appear camouflaged against Jupiter except for it's brightness.
Could be volcanic activity that gives Io it's perceivable contrast. It probably does look pearl-like. Need to observe it more closely.
Hmmm...
Eddgie
Reged: 02/01/06
[Re: JasonBurry]
#5541144 - 11/26/12 09:58 PM
Well, worse case then it is good to have someone else "Confirm" my report that Io did not look like a simple bright disk against the Jovian clouds.
But I am thrilled that someone else not only enjoyed the sight the way I did, but agreed that the "Pearl" look I reported was in fact visiable.
Very happy that you saw it and reported it....
Cool, isn't it? Way cool. And really beautiful to see.
azure1961p
Reged: 01/17/09
Loc: USA
[Re: Asbytec]
#5541175 - 11/26/12 10:18 PM
My inclination with regard to Io in perceiving it as a football probably varies with reason depending on aperture. I believe large aperture 12" or more might get an albedo config strong enough to suggest a flattend pole producing an oblate looking orb. Its plausible anyway. What I think is the greater reason is simply the vageries of atmospheric refraction. On Jupiter and individual details this serves to soften the image and erase finer lines and such but on the moons they are seen to move bodily, extending, flairing and so on and so this is perhaps the football. Howmany times have we seen a sharp jupiter image with a nearby galillean moon blurred or elongated? I would guess this elliptical or football appearance is that. I dont believe for a second though that tidal forces are squishing this very round object into an ellipse of torture. Its got its own hellish unrest due to Juptiers pull but it is forever as round as round can be for a moon anyway. If its out of round and ultimatley they all are its nothing wed actually ever see.
Id like to think this is a toe hold on Io discerning albedo in its own peculiar way or effect but Id be more in line with seeing vagueries and the manipulation these fine orbs are subject to through atmospheric lensing.
My .02! Pete
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
[Re: azure1961p]
#5541480 - 11/27/12 03:16 AM
Well, I get an Io transit tonight near around 11PM local. Jupiter is near the zenith, and if seeing holds...we'll take a gander.
azure1961p
Reged: 01/17/09
Loc: USA
[Re: Asbytec]
#5541581 - 11/27/12 07:14 AM
I look forward to the report.
Pete
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
[Re: azure1961p]
#5541982 - 11/27/12 12:07 PM
The night was tense.
Okay, just observed Io and Jupiter for nearly 3 hours from 27/1330 to 1630UT. My scope was perfectly collimated. I know because in 9/10 seeing I tweaked the Poisson spot about half an arc second to dead center at about 1 wave de-focus. In focus was perfect.
If observing this elongation had a chance, it was tonight as Jupiter was approaching the zenith. Europa was on the other side of Jupiter, but Callisto was just 1' arc trailing Io. So, I had two good references for what round looks like. One in the same high power field of view.
Normally, I'd make you read the entire account, but I gotta say Jason might be onto something. I'll explain why below. But, this brings one question to mind. Why is this not common knowledge already? I mean, surely we're not doing ground breaking amateur observations, here. Surely someone has reported this before.
Okay, now the boring account. A bit before Io's shadow touched Jupiter's limb, I observed it at 320x (6mm TMBII.) I wanted to observe it against the black of space. At this magnification, nothing really struck me but I did get a curious feeling about it. Not curiosity, I already had that. But a, "hey, hmmm, that's curious moment."
So zipping up to 380x (8mm TMB II and 1.6x Barlow) there sat Io against a pretty dark background, for all intents and purposes. My first impression was, "Hey, that does kind of look like a tiny bright dash." But, always on guard for the mind's aperture effect, I noted it and kept observing. Over time, Io bounced and blurred slightly. It was sometimes circular, sometimes not. Inconclusive on the elongation, but that nagging feeling it might be hung in there. Glancing at Callisto, then back to Io several times gave the impression Io might not be exactly circular. But I wasn't sure.
Okay, well, let's see if atmosphere is causing this tiny elongated impression. Slewed over to observe Europa. In the same seeing conditions, it was pretty much a clean disc. It bounced and blurred a bit, but it never gave any hint of elongation. Okay, so Io gave some hint of elongation, Europa nor Callisto did. Now, I am becoming somewhat convinced Io might actually be, and just barely detectable as elongated. The same observations were made at "stupid" 520x (6mm TMB II and 1.6x barlow.) Same results, but bigger disc.
The shadow drug itself over the limb, and Io struggled to keep up. It made contact with Jupiter's limb. And you know what? The elongation effect seemed a touch more convincing. Still not enough to really call it with utter confidence of a WWF wrestler picking a match in a school playground. But, interesting never the less.
Okay, not convinced, but cannot deny it's not elongated. That was the verdict at this point. By the way, I managed to follow Io all the way across the planet. It was in the darker SEB southern edge just preceding the GRS. In fact, Io with it's shadow just ahead of it (a few arc seconds) was just preceding Oval BA and it's companion. The whole entourage (BA, Dark spot, GRS, Io and shadow) marched across the disc. I got a sketch of it. Sweet.
So, anyway, after the sketch was done and Io approached the preceding limb, it deserved another look. Back up to stupid 520x for another look. Now! This was the most convincing elongation. In fact, I'd almost bet my Christmas gifts it's elongated. It just looked like a tiny bright dash mark.
So, yea, I really think Jason and Eddgie are onto something. I think it certainly can be glimpsed as elliptical or kind of like a small bright dash. It was way to small for me to even say whether it was 3:2 or any other ratio. Just that it did not really look circular all the time.
In fact, 72 Pegasi was clearly elongated at 0.56" arc (380x), and Io was a tougher to see elongation. Just to give you some idea, some scale of how hard this observation really was.
That's my report. Your turn! (Forgive the lack of editing...tired.)
JasonBurry
Reged: 04/27/12
[Re: Asbytec]
#5542026 - 11/27/12 12:30 PM
Interesting, and in step with what I think I may have seen. I genuinely enjoyed your report.
When I was observing it, at 200x, the seeing was such that the moon's disk was quite clean and round, though it would jump about by about half its diameter once in a while, presenting a reasonably clean and stable image for maybe 50-70% of the time. As good a night as I can hope for, here at sea level on the east coast.
I'm going to remain skeptical of my observation, but with some cautious optimism regarding it. It seems now we've got 2 folk who are seeing this curious effect, and that breeds hope! I'd love to hear some more accounts, successful or not. Skepticism is entirely warranted, I think, when we're attempting to observe some form of detail/albedo on a disk that is a little more than 2x our scope's resolving limit.
Last night held 50km winds for me, and Orion's bright stars were twinkling mightily when I looked out. With luck, the coming days may afford me another chance to observe this.
Thanks for your thoughts!
J
azure1961p
Reged: 01/17/09
Loc: USA
[Re: JasonBurry]
#5542058 - 11/27/12 12:48 PM
Well maybe your observations aren't groundbreaking Norme but I have it from first hand observation that the little spot between the GRS &BA is a monolith. So far my drawings show it to be of exacting dimensions. I should mention my scope spoke to me and said its name is Hal.
There.
Pete
JasonBurry
Reged: 04/27/12
[Re: azure1961p]
#5542066 - 11/27/12 12:51 PM
Great! I was asking about the dark spot's name in a recent post... Well met, Hal the Spot!
J
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
[Re: JasonBurry]
#5542083 - 11/27/12 12:59 PM Attachment (16 downloads)
Jason, I plopped into bed of course still rehashing the observation. First correction, 0.5" arc was way more collimation needed to be prefect. Just a hair, just enough to brighten the NW section of the first ring a bit.
Then it dawned on me, is this even possible in a 6" with an Airy disc 1.84" arc? Io, according to JPL sim is only 1.2" arc. But, it is not a point source, it's an extended object. So, maybe more than a few tiny spurious discs overlapping at magnitude 5 might give it the edge into doable territory. I really don't know.
By no means was my observation conclusive, either. I was equally convinced Io was not circular as I was unconvinced it was elongated. Something like that. I was torn to whether it was or wasn't. The thing that struck me was, I was not torn about Europa in the same way. And not nearby Callisto either. It was that close, it was that difficult. Maybe the power of suggestion runs deep.
I dunno what to make of it. Like I mentioned, there was no doubt 72 Peg was elongated. Absolutely none. It's 0.5" arc. It was easy in comparison to detecting elongation in Io.
Surely it becomes easier in larger apertures, and I remain convinced it's doable, as you and Eddgie reported. I am convinced you might well have seen it. I mean, I am that close to believing I did, too. I just hope it's theoretically and practically even possible with 150mm aperture. If not, well, I must have experienced the power of suggestion. Surely that's always a possibility, especially when you are operating at the very absolute limits of our senses...pushing the envelop. You can bet I'll look again.
Thanks for pointing Io's effect out. I noticed it on images, but just thought it was an artifact of motion.
Edited by Asbytec (11/27/12 01:01 PM)
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
[Re: Asbytec]
#5542090 - 11/27/12 01:03 PM
Okay, Hal...yea, that was funny.
"What are you doing, Pete?" Any more powers of suggestion you want to inflict in my head? Next time I sketch that spot (tomorrow), look for some very tiny corners on it. And maybe an ape nearby.
I might just add them for fun, though. A small monolith would be easy. I might can draw a monkey using about 8 pixels...
Edit: On a sad note, I /think/ I discovered a small cataract in my left (dominate) eye. I am of age to have them. Thankfully it's not directly on axis, but very occasionally, if I look at Jupiter at some specific angle it blurs pretty bad and has a small diffuse darkening imposed on it. My observing eye seems to be clear in this regard. And it seems a bit sharper and more sensitive. Gotta stick with it, I guess. Anyone else run across this?
Edited by Asbytec (11/27/12 01:26 PM)
JasonBurry
Reged: 04/27/12
[Re: Asbytec]
#5542138 - 11/27/12 01:31 PM
I observe with my left eye that has less astig., but a floater nearly on-axis. A minor PITA and usually avoidable.
My right eye never turns in a good performance with optics, despite it being dominant, generally floater free and not much worse in astig than my left. No cataracts yet, thankfully, though my mother has developed'em.
J
1 registered and 11 anonymous users are browsing this forum.
Moderator: RLTYS
