orlyandico
Reged: 08/10/09
Loc: Singapore
Bronze bearing lubrication?
      #5543605 - 11/28/12 10:46 AM
Posted in ATM forum - http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5543275/page...
But seems there are more readers here.
In short - I have massive stiction on my declination axis which runs on a bronze bearing/bushing.
Suggestions for lubrication?
zerro1
Reged: 08/02/09
Loc: Smokey Point , 48.12°N 122.25°...
Re: Bronze bearing lubrication? new [Re: orlyandico]
      #5544900 - 11/29/12 01:04 AM
Superlube synthetic grease. what mount?
Edit: never mind
Edited by zerro1 (11/29/12 01:09 AM)
Midnight Dan
Reged: 01/23/08
Re: Bronze bearing lubrication? new [Re: zerro1]
      #5545199 - 11/29/12 09:54 AM
I would try the recommended Lubriplate 105. It can be purchased at many auto parts stores, or online.
-Dan
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #5545253 - 11/29/12 10:27 AM
Make sure that all the metal to metal surfaces are as smooth and highly polished as possible. As always, a very thin coating of lube only (put the lube on, put it together and turn it around, take it apart and wipe the lube off one of the two pieces, put it back together again). This will help regardless of what lube you use.
cloudmagnet
Reged: 12/04/08
Loc: Georgetown, Texas
Re: Bronze bearing lubrication? new [Re: EFT]
      #5545439 - 11/29/12 12:16 PM
Not familiar with the mount, but am with bearings. If they are sintered bronze, They have been impregnated with lubricant during manufacture. Any additional oils, etc, usually do more harm than good. If they are simply solid bronze bushings, then a light oil is best- and as suggested above, inspect the mating surfaces to make sure they are absolutely smooth and free of scratches, etc.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Bronze bearing lubrication? new [Re: cloudmagnet]
      #5546127 - 11/29/12 07:42 PM
how to tell if the bearings are sintered bronze or just bushings?
since AP recommends lubriplate on them, i'd assume they are not sintered..
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
      #5546135 - 11/29/12 07:45 PM
While I have not seen these, I suspect that they are machined, not sintered metal (probably brass).
orlyandico
Reged: 08/10/09
Loc: Singapore
      #5546203 - 11/29/12 08:36 PM
hi Ed,
I have some pics here
I realized that I could/should have it hypertuned by you. Except shipping it back to the US (and back) is cost prohibitive.
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
      #5546285 - 11/29/12 09:26 PM
hi Ed,
I saw the pictures in the your other thread when you first posted. Basically, if it is a bright gold color, then it is most likely machined brass. The best thing is work work on the fit and finish. You have to be careful, but these should just fit together smoothly without any lube and once lubed, they will tighten up a little bit.
If you ever buy a used scope from the states, you can have it shipped to me first.
Lt 26
Reged: 02/19/09
Loc: Northwest Illinois
      #5546858 - 11/30/12 09:28 AM
As for the brass clean with warm soap and water then polish it with metal polish not car wax. The Teflon rings glide better with nothing on then. Wash them in warm soap and water then spray with Turtle Wax Express Shine and wipe dry. Clean and do the same to the surfaces they contact. Slip sliding away.
Dereck
20 registered and 31 anonymous users are browsing this forum.
