flava
Reged: 07/30/09
Uranus 2012 compilation
      #5544145 - 11/28/12 04:03 PM
This year I was lucky to catch captures of Uranus in good conditions.
The image below is a compilation with the Baader IR685 filter. This filter is a very well suited for Uranus and got me details several times. My favorite is the capture of 14/09.
Camera-wise, Basler ACE is easier to use and gives brighter videos with it's higher gain. You have the satellites at FD27.
The IDS is more sensitive but darker (less gain). It has lower noise too. When the conditions are very good, the result is slightly better.
I also added a RGB from 20/09 RGB, when the Astronomik R filter R got some details too:
MrJones
Reged: 09/15/10
Loc: Indiana
Re: Uranus 2012 compilation new [Re: flava]
      #5544293 - 11/28/12 05:46 PM
Very nice. Is the "dot" on the 04/09 shot from processing?
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
      #5544384 - 11/28/12 06:50 PM
Very good work Flavius! Looks like you captured some real banding in some of those captures. Well done!
Glenn
Sunspot
Reged: 03/15/05
Loc: Surprise, AZ
      #5544562 - 11/28/12 09:12 PM
What is astounding is that this is done with a 10" scope. I'm totally speechless.
Paul
Freddy WILLEMS
Reged: 11/13/05
Loc: Hawaii, Honolulu
Re: Uranus 2012 compilation new [Re: Sunspot]
      #5544576 - 11/28/12 09:20 PM
Just wonderful, how do you process these Avi's to bring out the detail Flavius ?
flava
Reged: 07/30/09
Re: Uranus 2012 compilation new [Re: Freddy WILLEMS]
      #5544977 - 11/29/12 05:07 AM
Thank you all.
The dot on the image from 04/09 is most probably a processing artefact. I had to process quite hard as the conditions were not optimal.
The processing can be very basic. Mono point stacking with Autostakkert.
For long time captures (over 15 minutes) what helps a bit is the AltAz derotation with Winjupos. Thank you Mr. Grischa Hahn !
With the IDS camera the result is better with dark substraction. That can be done with any software (Registax, Autostakkert). What works BEST with the IDS camera is dark substraction during AltAz derotation with Winjupos. Again, thank you Mr. Grischa !
With the Basler the dark substraction is not needed.
Anyway, even witout derotation and/or dark substraction the result is good when the seeing is good.
After stacking, wavlets with Registax or unsharp mask with Iris. Not very hard, the data breaks down easily with Uranus. Global contrast enhancement or gamma adjustment for a nicer final image.
Brian Albin
Seeker
Reged: 08/22/06
Loc: Western Oregon
      #5546594 - 11/30/12 02:01 AM
Thank you, Flava for sharing these. I am always fascinated to see detail on Uranus.
And to see an affordable aperture size scope bringing in the detail is always thrilling.
It is interesting to me to see how quickly the cloud patterns change on Uranus. Much faster than on Jupiter.
Kokatha man
Reged: 09/13/09
Loc: "cooker-ta man" downunda...
Re: Uranus 2012 compilation new [Re: Brian Albin]
      #5546618 - 11/30/12 02:58 AM
These are really great sets of images, and also effort taken Flava - congratulations..!!!
CPellier
Reged: 08/07/10
Re: Uranus 2012 compilation new [Re: Kokatha man]
      #5546631 - 11/30/12 03:36 AM
Outstanding work Flavius on Uranus, especially with a 10"
stanislas-jean
Reged: 10/22/08
      #5546650 - 11/30/12 04:23 AM
Cloud pattern change can be a concern for discussion.
There are some variabilities for sure but the conditions for taking this under a narrow survey need an excellent site observation and mostly almost steady images on the observation period.
Access of big guns at valuable sites are so limited.
Anyway this present opposition was a profitable one with great results, a step above.
Stanislas-Jean
ZielkeNightsky
Reged: 10/01/06
Loc: Denmark
Re: Uranus 2012 compilation new [Re: stanislas-jean]
      #5547156 - 11/30/12 12:51 PM
Fantastic set of images Flava. You have pushed the limits for what I thought was possible.
Thanks for posting this outstanding work.
azure1961p
Reged: 01/17/09
Loc: USA
Re: Uranus 2012 compilation new [Re: ZielkeNightsky]
      #5547783 - 11/30/12 07:53 PM
You truly redefine the 10" reflector.
Astonishing actually.
Pete
3 registered and 18 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
