Pistorbanic
Reged: 11/06/12
Loc: Ohio, USA
DSLR and filters
#5523605 - 11/16/12 11:10 PM
Hello.
I use a Cannon DSLR attached to my reflector scope where the eyepiece would go(Prime Focus?). If I want to use filters while snapping pics, what type do I use? I can't use an eyepiece filter because I'm not using an eyepiece. Confused.
NeilMac
Reged: 09/25/10
Loc: MedHat, AB, Canada
Re: DSLR and filters
[Re: Pistorbanic]
#5523680 - 11/17/12 12:05 AM
The Adaptor has threads inside ?
Pistorbanic
Reged: 11/06/12
Loc: Ohio, USA
[Re: NeilMac]
#5523686 - 11/17/12 12:09 AM
It doesn't. Just checked.
guyroch
Vendor (BackyardEOS)
Reged: 01/22/08
Loc: 3rd rock from the sun, Canada
[Re: Pistorbanic]
#5523725 - 11/17/12 12:45 AM
You can use an eos clip in filter. These filters are mounted in the body cavity.
Guylain
TopherTheME
Reged: 02/11/11
Loc: Rochester, MI
[Re: guyroch]
#5524087 - 11/17/12 10:26 AM
I use an Orion field flattener on my scope which doesn't have threads for filters. To get around this I flocked the inside of the focuser barrel so I can slide in an eyepiece barrel and it wills stay put. This way I can mount filters on eyepiece barrels (without actual eyepiece of course) and just slide them in in front of the field flattener.
bouffetout
Reged: 11/21/12
Loc: Canada
[Re: TopherTheME]
#5544121 - 11/28/12 03:46 PM
I use Astronomik CLS clip-in filter...google it ,it's good quality stuff !
mmalik
Reged: 01/13/12
Loc: USA
[Re: Pistorbanic]
#5544125 - 11/28/12 03:48 PM
This... is what I use. Thx
Phil Wheeler
Reged: 12/31/05
Loc: 3 miles WNW of Celestron
[Re: mmalik]
#5547083 - 11/30/12 12:14 PM
Is that a plain nose piece or a reducer-flattener on your 60Da?
jsines
Reged: 09/06/11
Loc: Berkley. Michigan
[Re: Phil Wheeler]
#5547226 - 11/30/12 01:28 PM
How is your dslr going into the eyepiece holder? I'm assuming you're using a t-adapter, and the t-adapter is held in the eyepiece holder? I use a t-adapter that has rings on the inside so I can use filters attached to the t-adapter. I have an Orion SkyGlow filter that is always attached to my t-adapter, which then attaches into the scope eyepiece holder.
mmalik
Reged: 01/13/12
Loc: USA
[Re: Phil Wheeler]
#5547515 - 11/30/12 04:50 PM
Just the plain nose piece. Thx
