Privacy Policy |
Please read our Terms
of Service | Signup and
Eddgie
Reged: 02/01/06
Re: Mirror moving when focusing
[Re: Sarkikos]
#5540001 - 11/26/12 09:52 AM
Is it possible that focus is changing due to thermal contraction of the OTA?
And approaching CCW is not just the way to deal with the problem, it is actually the best way to focus regardless of you are having this problem or not. Approaching from CCW allows you to most easily get the best focus possible because it allows your eye to accomdate the view if you overshoot slightly.
If your focus is changing though, and the image is not moving, perhaps you are having some other problem that has nothing to do with the mirror movement.
SCTs and MCTs use a very powerful negative mirror for the secondary. Even a very tiny change in spacing causes the focus to shift.
Try putting the scope out for a few hours before observing but if the temp is falling fast, it could be that if this is the problem (tube contracting) you may not resolve it.
This was the reason Celestron shipped Carbon fiber tubes for a while. As I recall, they said that the Carbon Fiber would not expand or contract the way the metal OTAs did so that for long period images, the focus would not change.
Could be your problem??
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland, USA
[Re: Eddgie]
#5540081 - 11/26/12 10:55 AM
I'm talking about the focus not holding steady immediately after I set the focus. The focus slips as I watch. That's exactly what it does. And when it starts slipping, it tends to repeat that performance whenever I refocus. Could this be due to thermal contraction of the OTA? It's not a gradual change in focus, but a sudden slip out of focus that is repeatable.
Why couldn't it be due to mirror movement? I do see a lateral shift in the image when I go from far-out-of-focus to a focused image. That's the nature of this little beast (in contrast to my 150mm Mak, which shows no lateral image shift at all when I turn the focus knob).
But that is not what I'm talking about. What I'm talking about is a spontaneous defocusing of the image. If I watch this long enough, there may be some lateral shifting of the image, also. But I don't let it progress that far before I try to refocus the image to sharpness again.
I let the Mak acclimate on my porch for about an hour the first night I noticed this focus slip. That ought to be good enough for a 90mm Mak. This last Saturday night, I took the scope directly outside from my warm house. As I said, Saturday night I did not see any focus slip until I had been outside for about a half-hour. Again, that indicates this problem may be at least partly temperature related.
You got me. I have no idea. This is definitely a metal tube. No carbon fiber anything in my house. But to make myself clearly understood again, this does not involve "long period images." Here is what I see: I focus the image, and almost immediately the image slips out of focus (there is no obvious lateral shift of the image), and I need to turn the focus knob again to refocus the image. Sounds like the problem the OP had, in that the image in my scope slips out of focus, also.
Sarkikos
Reged: 12/18/07
[Re: Sarkikos]
#5546374 - 11/29/12 10:28 PM
A friend of mine told me today that his SCT also shows focus slip sometimes. He has a CPC 1100.
So focus slip is not an uncommon problem among Maks and SCTs? This is something I have never experienced with Newts and refractors.
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
[Re: rigel123]
#5546535 - 11/30/12 12:50 AM
I was surprised since I don't experience this "shift" at all with my LS6. Could be newer, lighter scope though.
Which "shift" are you talking about? The sideways shift while you're focusing or the focus slipping after you've focused? Let's don't be ambiguous.
I don't see either, no sideways motion when focusing and no drift after getting the object in focus.
Some scopes are just better mechanically than the rest. My M14 has almost zero image shift when focusing (under 10 arcsec), and no shift after focusing. It does need a little refocusing when I slew, though. I'll settle for that without complaint.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
[Re: Rick Woods]
#5546559 - 11/30/12 01:22 AM
Yea, Rick, that's true. Over the years we've all seen various levels of mirror shift. And it's not surprising, really, when you move the mirror something is gonna shift.
I consider myself fortunate my current Mak can focus on stars at upwards of 100x per inch and remain in the FOV. Easily. I doubt the star shifts more than the diameter of it's first ring, about 2.4" arc. That may change as it get's used, but for now no worrying about approaching focus from either direction.
Though, slewing across the meridian does require a slight retouch. Like you, I can easily live with that. Would probably have refocused, anyway.
stanislas-jean
Reged: 10/22/08
[Re: Asbytec]
#5546579 - 11/30/12 01:48 AM
All the compact scopes has focusing problems. 2µm of thermal expansion on the metal tube involves 40µm at focus point. The degradation is sensitive. Regarding these views the steel tube is better than aluminium, the resin sensibly better and carbon well selected also better. This contribute to anneal this movement. The problem is that the optical glass also are not so stable and contributes to a focus point move, sensitive on some nights of great temperature gradient. After the menusque too with a temperature difference between outersurface colder than the inner. If you push the analysis deep you can find source of troubles, one can be the air currents inside the tube that cause aberration and focus point movements. If you quantify each and combine them in some scenario, you will conclude to avoid the SCT use and you will built something completely different than a sct. After you will find 2 schools, open tube the klevtov, the closed tube a newtonian with a flat closure glass. The cost will be quite different with stable glasses, 0 expansion, material neutral as carbon or resin, perfect alignment and simple to do, almost no focus point parasitic movements. Returning back on sct the great improvement will be a resin or carbon tube, thermally expansion un-existant, better thermal exchanges with outer air. For the rest all other troubles will exist but a step gain. The fixation of the main mirror is a must, so no shifting in any case, also. Stanislas-Jean.
Sarkikos
Reged: 12/18/07
[Re: Asbytec]
#5546801 - 11/30/12 08:43 AM
Norme et al,
I want to emphasize a distinction here between "mirror shift" - an apparent sideways movement of the image when focusing - and what I call "focus slip." "Focus slip" occurs when you have finished focusing the telescope and then the image slips out of focus. A sideways "mirror shift" of the image may or may not occur at the same time as the "focus slip." These are two different problems.
My Bosma 150mm Mak has never shown either mirror shift or focus slip. It comes to a focus with no lateral shifting of the image while I'm turning the focus knob and with no defocusing after I've finished turning the focus knob. Or at least I've never noticed either of these conditions. So if they are present, it is very minor.
On the other hand, my 90mm Mak always shows some mirror shift when I'm focusing. But I've only noticed focus slip recently when I've taken the little Mak out during near freezing temps.
The mirror shift really doesn't bother me. It's the focus slip that's a PITA. When I'm trying to catch various lunar features, I don't want to have to keep fiddling with the focus. If there's some way to correct this problem by taking the 90mm apart and maybe regreasing it or doing something else, I'd be interested. Otherwise, I might only take it out when the temps are well above freezing.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
[Re: Sarkikos]
#5546829 - 11/30/12 09:06 AM
Mike, yea, the difference is noted. Mine has a tiny bit of either. But, if your 90 Mak is "slipping" losing focus simply slewing around the moon, that's not normal. I believe this focus slip is caused by the primary feeling the force of gravity and flopping a bit. It's probably tilting a tiny bit against the primary baffle as the scope changes it's orientation. Mirror shift is the primary being forced out of true by the focuser knob itself - during focus. Ideally, the primary should probably rest on the focuser knob and "lean" against the baffle.
For either, has anyone ever tried a very thin shim between the primary and the baffle? Just tighten up that play by a few hundredths(?) of a inch, just enough slide easily and not to bind or become tight. Not sure what you could use, but surely something very thin could be slipped into the gap and reduce the slop between the primary mirror and the baffle. Re-grease it.
Sarkikos
Reged: 12/18/07
[Re: Asbytec]
#5546989 - 11/30/12 11:15 AM
Norme,
Another finer qualification of what I mean by "focus slip"... In the case of my 90mm Mak, it will slip out of focus when I am not slewing or moving the OTA at all. All I have to do is point at the ecliptic, keep the OTA stationary, and focus the scope. It will spontaneously begin to defocus. As I said, I have only seen this happen when the temps are around freezing.
Maybe I should put antifreeze in the grease?
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
[Re: Sarkikos]
#5547130 - 11/30/12 12:39 PM
Okay, well, heck. Try it? (Na! Don't...) Not sure what would cause that. Maybe the grease is very thick and when you draw back the focuser knob it kind of holds onto the primary? The mirror is slow to settle back onto the focuser because the grease is thicker and the mirror sticks to it? Just guessing.
Sarkikos
Reged: 12/18/07
[Re: Asbytec]
#5547184 - 11/30/12 01:03 PM
Yes, it does seem as if something like that is happening. Eddgie mentioned that Celestron had problems with focus slip due to contraction in metal OTAs at low temps. Is that the problem or the grease or both or ? It makes sense to me that a change in viscosity of the grease due to low temps could very well cause the focusing mechanism or the mirror to slip when held toward vertical.
I've never taken apart an SCT or Mak, so they are pretty much a black box to me, besides a basic understanding of the optics involved. I break down my Newts all the time to clean them or do some upgrades. But open up my Maks? I'm very reluctant to do that.
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
[Re: Sarkikos]
#5547953 - 11/30/12 10:04 PM
Well, certainly a contracting tube would reduce the mirror spacing and change focus. But, it seems like it would do so very slowly at first, then stabilize as the temps changed more slowly. I just can't see it happening each time you pointed the scope toward the Zenith. That sounds like a gravity problem.
I wonder if the focuser actually pulls the mirror back, at least on one side. I had my Mak torn apart and forgot to study at the focusing mechanism. It seems it should push and pull the mirror, it probably does. In fact, thinking about it...it has to as the focuser itself does not move in or out. So, maybe the off-focuser side is sticking a bit.
Sarkikos
Reged: 12/18/07
[Re: Asbytec]
#5548503 - 12/01/12 09:58 AM
The OP was talking about the exact same problem with his C8 as I have with my 90mm Mak: focus slip after setting the focus. Eddgie also mentioned that some Celestron Cats were having this problem: focus slip after setting the focus. It seems that it's not all that unusual in Cat World.
Eddgie said it would be "easier to remove the focuser and just pull the drive screw in and out a dozen times." I don't know about that. I'm adverse to removing anything involved with the internals of a Mak.
Does anyone know some solution besides exercising the focus knob or only setting focus CCW? They seem to help somewhat in my case, but didn't seem to completely solve the problem. Maybe I will need to take the Mak apart. But then do what?
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
[Re: Sarkikos]
#5548543 - 12/01/12 10:28 AM
Well, actually he described both problems, the image jumping all over the field during focus and drifting out of focus.
I dunno, if you cannot redistribute the grease, well nothing will make the gap between the primary and the baffle get any tighter. Maybe a shim for the worst cases, if one can be inserted without binding the primary during focus.
Maybe take it apart and look at it. Figure out what's going on. Mark your mirror and corrector orientations. If the Mak meniscus comes off while still in it's cell, that's cool. Mine did and I never had to worry about loosing or misplacing shims.
Sarkikos
Reged: 12/18/07
[Re: Asbytec]
#5548657 - 12/01/12 11:56 AM
I don't like the idea of sticking a shim anywhere inside the OTA. I'd be concerned that the shim would come loose and foul the optics.
Maybe a different type of grease is what's needed? Many Chinese manufacturers apparently get it wrong when it comes to picking the best lubricant for many types of telescopes. I've used Diff Oil Pure Silicon #3000 for refractor focusers to improve the motion. Perhaps that would work for Cats?
Sarkikos
Reged: 12/18/07
[Re: Sarkikos]
#5548660 - 12/01/12 11:59 AM
I think I'll follow Orion61's suggestion to PM him for more options.
gcfboulder
Reged: 09/27/07
Loc: CO
[Re: rigel123]
#5550346 - 12/02/12 01:29 PM
Anyone out there wanting the ability to do manual fine- focus with a Crayford-style focuser on their SCT scope, I have a JMI event focuser for sale. See my CN ad under focusers.
14 registered and 15 anonymous users are browsing this forum.
Moderator: Cotts, Starman27
