davelid
Reged: 06/05/12
Astrotech Voyager Mount Bolt new
      #5542221 - 11/27/12 02:18 PM
Hi - anyone know the tripod mounting bolt size on the AT Voyager mount. I have heard M10, but it seems to be larger than that. Also, does anyone know of adapters to mount the Voyager on a surveyor tripod like the Oberwerk?
Dave
Reged: 06/16/04
Re: Astrotech Voyager Mount Bolt new [Re: davelid]
      #5542238 - 11/27/12 02:25 PM
Dave
David:
Hello and Welcome to Cloudy Nights...
I don't know the actual diameter, I thought they used the standard 3/8-16 Bogen Tripod mount thread. ???
davelid
Reged: 06/05/12
Re: Astrotech Voyager Mount Bolt new [Re: Jon Isaacs]
      #5542262 - 11/27/12 02:45 PM
Nope, it is larger than that. I miked it at .484"
RTLR 12
Reged: 12/04/08
Loc: Capistrano Beach, Ca
      #5542471 - 11/27/12 04:56 PM
.484 is 12 mm.
Stan
davelid
Reged: 06/05/12
Re: Astrotech Voyager Mount Bolt new [Re: RTLR 12]
      #5542503 - 11/27/12 05:16 PM
Yep, 12mm. Wondering about thread pitch, etc.
RTLR 12
Reged: 12/04/08
      #5542729 - 11/27/12 07:57 PM
If it's a very coarse thread, it's probably 1.75, but there is 1.5 and 1.0 as well.
Stan
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #5543772 - 11/28/12 12:28 PM
I used a cast iron end cap from an old weight bench as an adapter to put my Voyager on a Oberwerk tripod. It was a perfect fit. The star shaped spin on end caps from the modern barbells I use would have worked as well. David
Agatha
Reged: 06/04/12
Loc: Minneapolis, MN
      #5544109 - 11/28/12 03:37 PM
I just measured the bolt from my Voyager mount. I have the very earliest version of the mount and I am assuming that the mounting bolt size is the same as the current version. It is a 10mm x 1.5. As for an adapter, I don't think there is anything ready to go. I know that there was a long thread about the Voyager quite a while back that had some really good info regarding adapting it to an Oberwerk tripod. Some BIG washers and a strong mending strip and a drill should do the job. Good luck.
Best, Linda B.
BSJ
Reged: 12/22/08
Loc: Grand Isle, VT
Re: Astrotech Voyager Mount Bolt new [Re: Agatha]
      #5544131 - 11/28/12 03:52 PM
I just used some big washers.
http://www.cloudynights.com/ubbthreads/showthreaded.php/Cat/0/Number/5016694/...
slack
Reged: 05/02/12
Re: Astrotech Voyager Mount Bolt new [Re: BSJ]
      #5545751 - 11/29/12 03:54 PM
Mine was M10.
davelid
Reged: 06/05/12
Re: Astrotech Voyager Mount Bolt new [Re: slack]
      #5547464 - 11/30/12 04:20 PM
Finally went to the big box store and tried the bolt, it is M10x1.5. Thanks Slack.
NOW the question is - does anyone know of an adapter that I could use so I can put AT Voyager on a Manfroto tripod with the 3/8-16 bolt?
Manny Myles
Reged: 11/29/05
Loc: Far South of the flyover city ...
Re: Astrotech Voyager Mount Bolt [Re: davelid]
      #5547696 - 11/30/12 07:02 PM Attachment (15 downloads)
This is the spacer I made to fit my Oberwerk tripod.
m2
28 registered and 43 anonymous users are browsing this forum.
